11-09-2004, 11:10 | #1 (permalink) |
Freak Poster Join Date: May 2002 Location: ************* Age: 47
Member: 11660 Status: Offline Thanks Meter: 7 | Z1010 network problems after unlock with multiserver yesterday i unlock one Z1010 phone using your server version of sw 1.33 unlock procedure was successful acording to server ... but phone registers to network 284-05 but cant make calls! with other network 284-01,register and make call customer is not happy about ... both networks are on 900 mhz how can we solve the problem? |
11-09-2004, 18:16 | #3 (permalink) |
Member: 11660 Status: Offline Thanks Meter: 7 | phone is from sweden:-) no i can not try with another operator , we have only 2 operatos phone was locked to some sweden operator ... "3" i think |
11-09-2004, 19:22 | #4 (permalink) |
Insane Poster Join Date: Oct 2004 Location: www.rekan.tk Age: 45
Member: 88480 Status: Offline Thanks Meter: 1 | I think the problem is that the phone is ment to be an "3g" phone that uses the UMTS-network in first choice. if thats not working it will try an 2 g network. the case in sweden with comviq-operator ( correct me guys if i'm wrong) is that the comviq cashcard users doen't have access to the UMTS-network and the phone kind of ****s up and you can get it to connect to 2g network, but only in 1-2 min. then you can't make any calls or recive them so if you have an sim card from your operator that give you access to use the UMTS network i guess it would work fine for you. otherwise, you need to wait until Sonyericsson see that this is an bug and release an new firmware ..and i might have missunderstood this, but if i have. please make an reply |
12-03-2004, 19:59 | #6 (permalink) |
Freak Poster Join Date: May 1999 Location: Bulgaria
Member: 38 Status: Offline Sonork: 92879:sid Thanks Meter: 82 | Same problem with Z1010 from Italy 3 I have same problem with phone from Italy: works just fine with MTel card 284 01, but with Globul 284 05 only incoming calls can be received, outgoing - no luck Software info: R1J005 prgCXC125685_EU_6_V Customization: CDA102239/43 R15A cxc125677 R1J005 THREE dsimka: have U found a solution for this problem ? Post you software info please! BR, [email protected] |
12-03-2004, 21:07 | #7 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | He, he ... here nice company - i have also another one my own Z1010 - unlocked with GT server - same problem - Globul /285-05/ is not working!!! S h i t - look like the Ericsson-s are still ericssons - no more good working phones are maded after GH768 !!! P.S. phone come from Italian 3G provider. |
12-03-2004, 22:53 | #8 (permalink) |
Freak Poster Join Date: May 2004 Age: 63
Member: 65039 Status: Offline Thanks Meter: 13 | I, am coming in your group, Also same problem, z1010 unlocked, debranded from 3G-Italy, working on 294-02(Cosmofon), but can't make and reseiving calls on 294-01(Mobimak) from Macedonia. Some body is tel me that with new version of software will be ok, but I don't now when? |
12-04-2004, 11:02 | #10 (permalink) | |
No Life Poster Join Date: Aug 2004 Location: Stockholm www.sumpansmobil.se Age: 57
Member: 79724 Status: Offline Thanks Meter: 15 | Quote:
It will be around 15/12 | |
12-04-2004, 15:09 | #12 (permalink) | |
Member: 79724 Status: Offline Thanks Meter: 15 | .. Quote:
Working on 2G and 3G It says 64K on card instead off 32K | |
01-07-2005, 14:45 | #13 (permalink) |
Freak Poster Join Date: Jul 2004 Location: Burgas, Bulgaria Age: 55
Member: 75528 Status: Offline Thanks Meter: 5 | i had same problem, 1 Z1010 dont work on BG Globul and work only on BG MTEL, and 1 Z1010 dont work at all in Bulgaria, in some cities were have 1800 mhz network - phone work, but on this band network here is weak and dont work good unlocking 1800 mhz and flashing with R1K010 not help i hope that will be some resolution of this problem in the future |
08-06-2005, 17:40 | #14 (permalink) |
Freak Poster Join Date: Jan 2005 Age: 51
Member: 105268 Status: Offline Thanks Meter: 1 | z1010 network problem check this. i have one also that works with a 3g card and also works ona2g card but after some time it just stop working with the 2g card, but it takes the 3g card. all i did was to work on the network ic and it started working again. try it may be it will work for you. |
sharp 902sh network problem after flash with USB smart | doberman | Sharp | 2 | 12-02-2006 11:51 |
8120 network problem after flashing with cruiser | gsmindia | Cruiser Suite | 1 | 04-25-2006 12:34 |
Z1010 network problems after unlock | osama | HWK | 8 | 10-15-2005 19:48 |
Z1010 Network Problem After Flash Please Help Need Solition ! | yildirim | Cruiser Suite | 1 | 07-11-2005 08:15 |
Problem After Unlock with Z1010 | Maurone | FuriouS II | 4 | 02-23-2005 10:34 |
