04-10-2007, 09:40 | #1 (permalink) |
No Life Poster Join Date: Jun 2001 Location: UAE Age: 43
Member: 5019 Status: Offline Sonork: 100.110196 Thanks Meter: 69 | big problem with vygis flashing... P7200, KG920 , S5200 first time connect without problem, after writing full flash it stops in 97% and after that, phone will not connect to vygis anymore, see the picture below. this KG920 connected to vygis succesfully for first time, after wrting full flash for the first time, fullflash goes to 97% writing and then PHONE NOT RESPOND appeared on the screen. after than I disconect and connect the phone again, and all times i get PHONE NOT RESPOND message, after pressing CONNECT button. Last edited by Gobi; 04-11-2007 at 22:29. |
04-10-2007, 10:15 | #3 (permalink) |
Member: 5019 Status: Offline Sonork: 100.110196 Thanks Meter: 69 | i did it, same result and here is another picture, after i tried manytimes to connect finally succeeded one time, but now you see PHONE NOT RESPOND messaage while flashing phone. Last edited by Gobi; 04-11-2007 at 22:29. |
04-11-2007, 07:33 | #5 (permalink) |
Member: 5019 Status: Offline Sonork: 100.110196 Thanks Meter: 69 | battery is fully charged, and have 4.11Volt it's common problem on vygis full flashing... i tried arround 50 times. same result. please vygis fix it. |
04-11-2007, 22:28 | #6 (permalink) |
No Life Poster Join Date: Sep 2001 Location: GSM-TOOL Age: 52
Member: 6328 Status: Offline Thanks Meter: 3,595 | It seems to happen only for you. Try also on another PC . If it still gives error, then possible contact problem in your box or cable, i think. regards, Gobi P.S. - Edit your pictures to HIDE YOUR DONGLE ID !!! |
New user big problem with Vygis | louischara | VygisToolbox | 1 | 08-04-2007 20:51 |
big probleme with 350 flashing... | summer_20xx | ThunderStorm Box | 4 | 08-25-2006 20:45 |
Big problems with Vygis Smart Card under Win XP SP2 | mcgsm | VygisToolbox | 1 | 12-13-2005 09:07 |
big problem with ufs3 flashing SE phones | ttpower | UFS2 + UFS3-Tornadoflasher | 1 | 12-21-2004 15:54 |
