02-09-2006, 05:12 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Age: 54
Member: 105625 Status: Offline Thanks Meter: 44 | BUG REPORT: Smart-card detection problems |
02-16-2006, 09:34 | #3 (permalink) | |
Freak Poster Join Date: Jul 2004 Location: Liverpool, UK Age: 40
Member: 75232 Status: Offline Thanks Meter: 12 | Quote:
scooter... | |
02-19-2006, 02:20 | #5 (permalink) |
Member: 105625 Status: Offline Thanks Meter: 44 | But it always works if i close other applications that uses smart-cards... - even without reinserting card. In other words - it doesn't detect the card, if any other application is using cards. |
02-19-2006, 03:14 | #6 (permalink) | |
No Life Poster Join Date: Jul 2002
Member: 13737 Status: Offline Sonork: 100.100725 Thanks Meter: 194 | Quote:
if ur system have multi ports usb than make sure always connect dongle where its connect first time same if using HUB second solution is install the driver manually if u know how to install martech on Xp ( insteed of uniusb installed already) | |
02-20-2006, 00:18 | #7 (permalink) |
Member: 105625 Status: Offline Thanks Meter: 44 | Why is that a solution when the dongle is working fine, and drivers are installed fine? This is a bug in LG software, not problem with dongle. If you don't believe me, do the following: 1. Start LG_1_51SC.exe - working fine 2. Close application 3. Start SEtool (or Cruiser) 4. Start LG_1_51SC.exe - PROTECTION CARD ERROR 5. Close SEtool/Cruiser 6. Start LG_1_51SC.exe - working fine again. |
02-20-2006, 04:45 | #8 (permalink) |
No Life Poster Join Date: Sep 2001 Location: GSM-TOOL Age: 52
Member: 6328 Status: Offline Thanks Meter: 3,595 | It is no bug in the software. This security measure was necessary. The VygisToolbox software works with the card-dongle in exclusive mode. This means it will not start if it don't have absolute - exclusive control of the Smartcard. This is for the softwares security, not letting the door open for crackers to try emulating the smartcard by any dll or server --> closing by this security wholes. regards, Gobi |
02-20-2006, 08:37 | #9 (permalink) |
No Life Poster Join Date: Aug 2004 Age: 47
Member: 76522 Status: Offline Thanks Meter: 30 | but can u make differend drivers or something else because 1st. we must use 4 vygis soft stanalone comuter ( cruiser and sst also use smartcard dongle but work whis each other fine) 2nd we cant use at the same time 2 programs from vygis! ( i must closed lg module when i need acer and etc. ) p.s. can u made combined modules 4 differen models and make multiport flashing 4 them. sometimes is needed 2 flash 2 and more several models like cruiser do. |
02-20-2006, 11:20 | #10 (permalink) |
Member: 6328 Status: Offline Thanks Meter: 3,595 | lool, depends what you prefer: different independent working modules --> then cracked software working on server basis (like digital television cardcrack), or like it is now ? |
02-21-2006, 08:25 | #13 (permalink) |
Member: 6328 Status: Offline Thanks Meter: 3,595 | You are talking verry easy about more then 1 Month work for the author in order to remake actually all modules in one software: Even if he would not have to remake everything, but to make it secure and working good it will take this much time or more And still final result would be: - no updates for over 1 Month = crying people here - decreasing the security level of the software ==> a lot of crackers just waiting for that. And then same people asking here for this decreasing will come and accuse us that the software was cracked. - by remaking all sw modules in one software --> a lot of bugs will apear = decreasing the software quality, dead phones and mad customers And all this just in order to let few people use the same time 2 or more software modules or different softwares? It is not my call and not my decision, but i don't think it is worth to decrease the software security level and quality (Bugs & Co) just for that. What we have now is a software ''cleaned'' of bugs during few years for some modules allready, and where the author has increased all the time the security. We should not compromise that . regards, Gobi |
02-21-2006, 20:47 | #14 (permalink) | |
Member: 105625 Status: Offline Thanks Meter: 44 | Quote:
And do you say that all other are making "unsafe" protection? And what prevents it to get exlusive access to it's own card? I assume other applications are only using their card - not vygis-card? | |
02-21-2006, 21:25 | #15 (permalink) |
Member: 6328 Status: Offline Thanks Meter: 3,595 | Loool, you don't know the difference between the smartcard used in Vygis - Setool - Thunderstrom ... protection and the one used in USB Smart --> but you try to make conclusions here .... Well, you will need to find somebody having more free time then me to stay and explain you all from beginning ... However the thread subjhect was explained more then necessary in details. Whoever has understand - ok ; whoever has not understand ... it is not our fault. regards, Gobi |
MX Bug Report: Change E-mail button. | khunv | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 12-24-2009 07:47 |
Smart Card Help....really old smart card cannot detect | hafftrak | Infinity-Box | 5 | 04-23-2009 23:14 |
5.05 bug on smart card driver | andrew14 | UST Pro II | 0 | 07-15-2007 07:35 |
Cruiser Smart-Card detection method is not optimal... | FractalizeR | Cruiser Suite | 9 | 09-29-2005 15:46 |
Bug report: Direct Unlock Disabled on ALL Models | evan_silbert | Cruiser Suite | 2 | 11-29-2004 21:13 |
