Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > VygisToolbox
Old 09-08-2005, 13:59   #1 (permalink)
Gobi's Avatar
Member: 6328
Thanks Meter: 3,595
DONGLE REPLACEMENT STARTED; discussion thread
The replacement dongles have arrived at the main distributors or are on the way.
So, any Vygis software customer that have sentinel dongle (old LPT dongle or the one looking like in the picture on www.VygisToolbox.com) can ''replace'' his dongle with a new Smartcard Dongle.
[glow=red]Replacement instructions for VygisToolbox from Sentinel to Schlumberger Cyberflex Smartcard Dongle[/glow]
[glow=red]What is intentioned: [/glow]
1 - Saving one way delivery costs for the customers by using a logger system that creates a FIRST log from the dongle and the regfiles with the needed information.
Of course some people will try to cheat- crack even this log system  this make us to limit the replacement offer like this for 2 Months
2 - Making sure this reduced cost dongles will be used ONLY for replacement, and will NOT be sold to new customer by gready people.
This way for our existing customer should be assured stock.
Because of this, the replacement dongles, when the customer receive them, NEED TO BE ACTIVATED, by the author, using a SECOND LOG and new registration files.
3 - Keeping out the people using fake reg files, cracked vygis software, etc..
( http://forum.gsmhosting.com/vbb/showthread.php?t=211718 )
For this, wherever a fake reg file, usage of cracked Vygis software will be detected  That dongle will NOT be replaced and WILL BE DEACTIVATED.
Of course also the dongles (Dongle ID’s) used in crack software are Blacklisted.
(Warning for people NOT to give to anybody their reg files !!!)
4 - Customer will be able to use also the ‘’old’’ sentinel dongle, even if there will be no upgrades for this type of dongle anymore. It will still help a lot of people who have 2 shops, or 2 working places, a lot.
So, actually the honest existing sentinel dongle customer will have the oportunity to get a brand new VygisToolbox Smartcard dongle for a verry low price.
They will use the existing account on the www.VygisToolbox.com support site.
Also, since sentinel dongles has not been shipped out anymore from the distributors since about more then 1,5 monthes anymore  NEW accounts on the www.VygisToolbox.com support site will be activated ONLY for Schlumberger dongles.
[glow=red]Procedure[/glow]
Short description:
Step 1 – Making a first log from the sentinel dongle including also the reg files and sending to the reseller.
The reseller confirms if all is ok, then after receiving the payment will send the replacement dongle to the customer.
Step 2 – With BOTH dongles connected (old sentinel dongle and new Smartcard dongle) you make second log file and send it together with attcahed your reg files to your reseller or directly to [email protected]
Then just wait for the reg files.
Limitations: You can make LOG 1 and LOG 2 file only one time with same Sentinel dongle
and same PC.If you have few Sentinel dongles and want to make logs for them,you need to use other PC.
[glow=red]InDetails:[/glow]
- Resources:
Logger software, Sentinel Dongle drivers, Smartcard Dongle drivers, and Dongle ID reader are ALL avaiable on the support website. You need just to go there and download.
Please check if your drivers for the one or other dongle are installed correctly by reading the Dongle Id with the mentioned Dongle ID reader.
The logs can be made for 1 dongle ONLY on one PC/dongle and 1 time.
Step1:
- If sentinel dongle driver is not installed on the PC, then do it now, and check by reading the ID.
- Connect to PC your Sentinel dongle and start logger software.
- With button "Add regs" open all reg files,which you had for Sentinel dongle.
Opened reg files must appear in "Selected reg files" window. You can drag & drop reg
files to this window also
Check if you selected all reg files correctly,as you will can make LOG1 file only 1 times.
- Fill fields "Customer info","Reseller name", "Customers main mail" and if
you have second mail,please fill and "Customers second mail" field.
- Press button "Make LOG1" and wait until log file will be made.
If you get message like "Your dongle is dissabled"-it means,that you tried to include cloned reg files,or you have dongle with blocked ID,or you are trying to make logs using sentinel emulator.In all cases,you will not can make logs more and will not can use sentinel dongle also.
First log file looks like xxxx.log1,where xxxx is your Sentinel dongle ID.
Send this log file to your reseller.
The Reseller confirm, then after receiving the payment will send the replacement dongle to you.
Step2:
- For LOG 2 making you need to have connected to your PC both dongles-Sentinel and SmartCard dongle.
- Drivers for SmartCard must be installed also.If you use any software with Sclumberger e-gate card(SETools,Infinity,Cruiser, Thunderstorm or SST), then you don't need install the drivers for SmartCard dongle.
Also before LOG 2 making,please check if your SmartCard dongle can be detected correctly.For checking use SmartCard ID reader,if you can read dongle ID from SmartCard dongle,you can start LOG 2 making.
- Please check if you have all reg files selected in window "Selected reg files",
also please check if fields with Customer,Reseller and mail info are filled.
LOG 2 file can be made only one time,so all info must be correct before you make it.
If everything is OK,press "Make LOG 2" and wait until LOG 2 file will be created.
LOG 2 file looks like xxxx_000xxxxx.log2,where first 4 digits are Sentinel ID and
next 8 digits are SmartCard dongle ID.
Send LOG 2 file and ALSO all reg files atached DIRECTLY by mail to the author at [email protected] and wait for new reg files.
regards,
Gobi
P.S. Just to make sure all people know what we are talking about:
Please look at the pictures atached to identify if your USB dongle is SENTINEL or SMARTCARD DONGLE.
LPT Dongles where all sentinel donlges.
Old 09-08-2005, 15:00   #2 (permalink)
Fre3 Crack3r's Avatar
Member: 8784
Sonork: 100.63512
Thanks Meter: 31
great . .
But what about customer that buy this dongle from old time and reseller left this
buisness ?? who can make first setup for us ?
Regards . .
Old 09-08-2005, 15:03   #3 (permalink)
Registered User
the new's Avatar
Member: 36653
Thanks Meter: 336
Red face but for custumer that don't have resseiler !!!!
but for custumer that don't have reseeiler or can't contact resseiler (like he is in tunisie and resseiler in france) or in other country and he can't contact him whet should him do
Old 09-08-2005, 15:11   #4 (permalink)
aliwali's Avatar
Member: 7363
Thanks Meter: 24
u was buying your dungle from someone not reseller
u must contact him
if u're mine that welcome
u havn't listen when i told u must buy from reseller like aliwali in Tunisia
Old 09-08-2005, 15:19   #5 (permalink)
Registered User
the new's Avatar
Member: 36653
Thanks Meter: 336
Talking lol i can make this
u must contact him
lol I can make the exchbange with any resseiler of VYGIS and i think there is many resseiler in tunisie and I can contact other in any contry
think for you ansser
Old 09-08-2005, 15:19   #6 (permalink)
Gobi's Avatar
Member: 6328
Thanks Meter: 3,595
Friends -- you can choose ANY reseller that is providing this replacement service.
And also the resellers can provide replacement dongles for ANY customer.
regards,
Gobi
Old 09-08-2005, 15:39   #7 (permalink)
aliwali's Avatar
Member: 7363
Thanks Meter: 24
if u can why u ask than
show me anather reseller in tunisia
u must read what Mr Gobi have shared before
u're terribel
Old 09-08-2005, 15:45   #8 (permalink)
aliwali's Avatar
Member: 7363
Thanks Meter: 24
regards,
Gobi
@ aliwali
.. it has been confirmed that ali-valis mentioned dongles was actually smartcard dongles and don't need to be replaced ..
Gobi
all aliwali's vigys custumers no need to change their dungles
Old 09-08-2005, 15:47   #9 (permalink)
Gobi's Avatar
Member: 6328
Thanks Meter: 3,595
Mr Gobby
i was buy vygis dungle on the same for cracked
what i do
Please reformulate ...
I don't understand what you mean ...
regards,
Gobi
Old 09-08-2005, 15:50   #10 (permalink)
Member: 28559
Thanks Meter: 85
@Gobi who are the reseller that is providing this replacement service. are all resellers providing this service?
Old 09-08-2005, 15:54   #11 (permalink)
aliwali's Avatar
Member: 7363
Thanks Meter: 24
regards,
Gobi
i have bought 5 dungles on the same date when vygis was cracked
what i do
Old 09-08-2005, 15:59   #12 (permalink)
Gobi's Avatar
Member: 6328
Thanks Meter: 3,595
@ aliwali
@ gorgans
Any reseller that want to provide this service, can provide it.
regards,
Gobi
Old 09-08-2005, 16:32   #13 (permalink)
aliwali's Avatar
Member: 7363
Thanks Meter: 24
@ aliwali
Gobi
All aliwali's Vigys Custumers
No need the Remplacement for your Dungle
all are New card
thanks
(do not post dongle id number please)
Old 09-08-2005, 16:37   #14 (permalink)
Member: 7910
Thanks Meter: 57
Hi Gobi what is estimated price for replacement dongle
Old 09-08-2005, 16:54   #15 (permalink)
Member: 121508
blank mister Gobi because of the recent problems with the police my retailer is not reperibbile thing I must make? me aids I do not know as to make in order to change to the new chiave!il my retailer it is Luigi
BB5 Klip All Variants Discussions Thread Cake FuriousGold 144 12-14-2007 23:20
V300 to V550 possible??? discussion thread doktortelecom Motorola P2k 6 06-13-2007 06:59
FuriouS Online Servers DISCUSSIONS THREAD !!! .:hack3r2k:. FuriouS II 275 10-18-2005 14:30
FuriouS Dongle Lite DISCUSSIONS THREAD !!! .:hack3r2k:. FuriouS II 37 02-18-2005 14:05
Page generated in 0.27559 seconds with 10 queries
