06-29-2006, 16:20 | #1 (permalink) |
No Life Poster Join Date: Sep 2001 Location: GSM-TOOL Age: 52
Member: 6328 Status: Offline Thanks Meter: 3,595 | Gradiente Vibe,Ezio MP100 and Elson MP100 - FIRST IN THE WORLD SOLUTION Software goes as free addon for VPOWER BOX, and O2 software users and works with O2 reg file. Supported models : Gradiente Vibe,Ezio MP100 and Elson MP100. Software futures : - fast flash reading-writing at 812500 kb - fast unlock - "Mobile is blocked" repairing - phone code reset to default About connector: Until the chinese factories will release the cable, you can use a LG 18 pin connector, where you will need to cut little bit in order to fit in the 14 pin connector of this phones. Pinout is inside the software archive regards, Gobi Last edited by Gobi; 06-29-2006 at 17:14. |
06-29-2006, 17:15 | #3 (permalink) |
Member: 6328 Status: Offline Thanks Meter: 3,595 | About connector: Until the chinese factories will release the cable, you can use a LG 18 pin connector, where you will need to cut little bit in order to fit in the 14 pin connector of this phones. Pinout is inside the software archive regards, Gobi |
07-13-2006, 11:54 | #5 (permalink) | |
Insane Poster Join Date: Sep 2005 Location: Brazil-Bahia-Salvador Age: 49
Member: 179003 Status: Offline Thanks Meter: 8 | Quote:
Luciano ALÔ SERVICE TELECOM S/A Last edited by Aloservice; 07-13-2006 at 19:17. | |
07-13-2006, 17:24 | #7 (permalink) |
No Life Poster Join Date: May 2001 Location: Lithuania
Member: 4458 Status: Offline Thanks Meter: 25,853 | It is not mistake in pinout Simple all pinouts,that are on supports shows TX and RX signals from phone side.So TX signal from phone must go to RX signal at box,and RX signal from phone must go to TX signal at box. Regards,Vygis |
08-10-2006, 20:59 | #15 (permalink) |
Freak Poster Join Date: Aug 2004 Age: 47
Member: 77446 Status: Offline Thanks Meter: 8 | Mr. Gobi, I bought O2 reg file for my Vygis box, cause I need to unlock some this phones, but now I can´t enter support area to download software. I get always the following: Authorization error occured! You can't access this dir with current login details. Please relogin from appropriate software.(If you want to access LG support area - login from LG software etc.) What should I do to download Gradiente/Ezio/Elson software?? BR |
Infinity box : First in the World Solution to repair "BAD SOFTWARE" in Chinese phones | InfinityHelp | Main Sales Section | 0 | 08-16-2008 12:02 |
First in the world Solution again,.Smart solutions brought to you by Ultimate-sam | .:Spitfire:. | Ultimate-Sam | 0 | 07-10-2008 18:32 |
First in the world solutions by this tiny Thing? Also Raskals BB5 box in stock | .:Spitfire:. | Main Sales Section | 0 | 10-09-2007 21:26 |
>>>Again, First in the World solution, Check this out<<< | .:Spitfire:. | Main Sales Section | 0 | 05-14-2007 08:59 |
