Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > VygisToolbox
Old 11-21-2007, 22:25   #1 (permalink)
Burnt Cobba's Avatar
Member: 11325
Thanks Meter: 266
Question How to connect to a U310?
hi mates.
Am trying to connect to a U310? is there some procedure to connect to this one pls? Must i set some parameters before i can do this?
thanks
Old 11-22-2007, 19:43   #2 (permalink)
Member: 4458
Thanks Meter: 25,853
Nothing special with U310 connecting-read "Unlocker Help.txt" how to connect to it.
Regards,Vygis
Old 11-22-2007, 19:54   #3 (permalink)
Member: 11325
Thanks Meter: 266
how is it i cant make it connect using the box through the K800 cable? It should work. In fact the Green LED flickers.
really strange. thanks for any help
Old 11-22-2007, 20:02   #4 (permalink)
Member: 4458
You still don't read "Unlocker Help.txt".Here I attach it-read first few lines in it.
Regards,Vygis
Old 11-22-2007, 20:21   #5 (permalink)
Member: 11325
Thanks Meter: 266
no mate i read it . installed everything and everything is set up ok. the only different thing is that i am using the RJ45 cable connected to the box instead of the USB. Is this the only way to connect? its stragne as the RX led is flickering when trying to connect.
thanks
Old 11-22-2007, 20:25   #6 (permalink)
Member: 4458
Only one way-to use USB cable.
Regards,Vygis
Old 11-22-2007, 20:30   #7 (permalink)
Member: 11325
Thanks Meter: 266
oh i c that explains everything. Thought it could be done using the box.
thanks mate
how to repair damaged GDFS when cuiser dont want to connect to phone? Br0k3R_PL Cruiser Suite 12 07-17-2007 19:52
How to connect to sws-sag server Papa Jyde Redbox 3 10-16-2005 10:55
How to connect to USB? (VB) 3xsms GSM Programming & Reverse Engineering 2 01-16-2003 07:19
T192 how to connect to a full emmi box?? maher_teamoo Motorola Old Legacy (EMMI) 1 08-19-2002 17:54
How to connect to internet with T20? 1aitunon Old Ericsson Phones & Sony Phones 0 06-11-2001 19:59
Page generated in 0.15536 seconds with 10 queries
