09-24-2006, 08:16 | #1 (permalink) |
Insane Poster Join Date: Apr 2005 Age: 45
Member: 141287 Status: Offline Thanks Meter: 5 | kg 810 cant connect to vygis,pls help!!!!!!!!!! please power on phone -------------------------------------------------- prepairing boot....ok loading boot.... then comeout with phone not respond.but i try with kg800 all is ok.is only kg 810 cant be connect.any advice????????advance thanx |
09-24-2006, 20:42 | #2 (permalink) |
No Life Poster Join Date: Sep 2001 Location: GSM-TOOL Age: 52
Member: 6328 Status: Offline Thanks Meter: 3,595 | Pleaswe tell us if you are using as Comport the VygisUSBrs232 driver, or are you using emulated Com port (Com ..)? This will help mr Vygis to check in thesoftware if there is any problem, even for many other people was working .. Also KG810 is different from KG800. regards,Gobi |
09-25-2006, 14:48 | #3 (permalink) | |
Member: 141287 Status: Offline Thanks Meter: 5 | Quote:
02-24-2007, 14:04 | #5 (permalink) |
No Life Poster Join Date: Jan 2005 Age: 54
Member: 105625 Status: Offline Thanks Meter: 44 | Can you please fix KG810 unlocking? It's not working! Can you please fix KG810 unlocking? It's not working - no matter what - it says "Phone not respond" after loading boot. And it's definately a software fault. Cables are 100% OK (tested both UFS and Vygis cable - works fine with KG800 in vygis), and phone is also 100% ok, cause Multi-box can unlock it without any problems - even with Vygis cable. Tested with two different phones. Using vygis box, all different speeds tested. I'm not the only one with this problem So please try to fix this problem... Last edited by James_S; 02-24-2007 at 14:17. |
02-26-2007, 18:25 | #6 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Brazil
Member: 232960 Status: Offline Thanks Meter: 419 | I already had this problem with kg810, but it 's very simple to solving: Maintains the finger in power button even the unlock to do visible. It's have solved my problem in kg810, mg810 phones in others models dont needed. try. regards |
02-26-2007, 21:35 | #7 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: YODAFON
Member: 75392 Status: Offline Sonork: 100.81199 Thanks Meter: 136 | Quote:
In short words, press power, until Phone info is written completly. (not like other LG's, when connecting battery is enogh for booting it...) | |
02-26-2007, 23:25 | #8 (permalink) | |
Member: 232960 Status: Offline Thanks Meter: 419 | Quote:
excuse my bad english... rgds | |
02-27-2007, 18:48 | #10 (permalink) | |
I think that you trying how in the old ones, its dont works!!! | |
02-28-2007, 17:50 | #11 (permalink) |
Member: 105625 Status: Offline Thanks Meter: 44 | Of course i do it properly. How hard can it be to hold a button pressed? If i didn't know how to do that, i wouldn't be able to unlock any phones, like KG800. "Phone not responds" message is shown BEFORE i release the power button. |
02-28-2007, 19:26 | #12 (permalink) |
Member: 232960 Status: Offline Thanks Meter: 419 | Then I had good luck in my versions, small chance but, try in other universal box that u have by comport1 + cable kg8xx +vigys conected in usb+ 115kbps. good luck. |
08-21-2008, 05:29 | #14 (permalink) |
Insane Poster Join Date: May 2005 Age: 38
Member: 148218 Status: Offline Thanks Meter: 5 | I'm starting to get this problem also, have been unlocking the KG810 for awhile but now all of a sudden can't get any to unlock. Box and cable are working fine as I'm able to unlock other lg's just not the KG810 |
cant connect to server....pls. check | FMC_GSM | Smart-Clip | 1 | 01-14-2010 09:21 |
Help!My box cant connect to any phone using 13.20 installer??? | DAVI | Cruiser Suite | 1 | 08-21-2008 08:48 |
cant connect to support area Help! | delo | SonyEricsson (USB-Smart) | 2 | 05-11-2006 15:53 |
