08-18-2008, 15:29 | #1 (permalink) |
No Life Poster Join Date: Nov 2002
Member: 17424 Status: Offline Thanks Meter: 15 | KP235 text message problems I unlocked a Kp235 few days ago, customer came back today saying he can not read/write or even open text messages. I checked the phone and all it does it says 'please wait' and then goes back to text message menu. phone details before flashing : (after unlock) Phone type : LG-KP235 Phone version : KP235AT_V10b Flash type : Intel - 32 Mb IMEI : 352127-02-086687-2 Please plug cable to phone.Phone must be OFF.If bootloading not starts - press power ON and keep it pressed until boot loading will be finished. ------------------------------------------------ Loading boot... OK Flash ID : 8916 Flash type : Intel - 32 Mb ----------------------------------------------- Reading phone info ... OK I flashed the phone with LG-KP235_KP235AT-00-V10c-EUR-***_EN_FR_GER_IT_ES_NL_GR_SW_NO_DA_FIN_FW.crb LG-KP235_KP235AT-00-V10c-EUR-***_EN_FR_GER_IT_ES_NL_GR_SW_NO_DA_FIN_FULL_#2.crb from support but problem still remains. Any ideas would could be wrong? br msa |
08-18-2008, 15:56 | #2 (permalink) | |
No Life Poster Join Date: Jul 2008
Member: 818352 Status: Offline Thanks Meter: 266 | Quote:
after flash make reset Best regrds Unlock Trigger | |
08-18-2008, 16:54 | #3 (permalink) | |
Member: 17424 Status: Offline Thanks Meter: 15 | Quote:
Thanks Allready flashed with lowest baud rate (it defults to lowest when you start programe) and yes I did reset the phone as it instructed 2945#*#. any more ideas ? br msa | |
08-19-2008, 15:33 | #6 (permalink) |
No Life Poster Join Date: Mar 2004 Location: Nederlands / Germany / Danmark Age: 51
Member: 60001 Status: Offline Sonork: 100.106474 Thanks Meter: 151 | sorry can`t edit my last post, so i must start new seems that flashfiles from support are broken...??? i use my own files and all is ok now http://rapidshare.com/files/13849834...IN_FULL__2.rar http://rapidshare.com/files/13849834..._DA_FIN_FW.rar try it |
08-19-2008, 18:52 | #7 (permalink) |
Member: 17424 Status: Offline Thanks Meter: 15 | Hi I solved my problem by writing LG-KP235_KP235AT-00-V10a-ORG-XX_EN_FR_IT_GER_PT_PL_RO_SLO_ES_CAT_NL_FULL_#2 LG-KP235_KP235AT-00-V10a-ORG-XX_EN_FR_IT_GER_PT_PL_RO_SLO_ES_CAT_NL_FW After flashing I reset the phone as sugested by the software using 2945#*# When tried to go into new messages the phone switched off and would not power up agian untill I took the battery out and put back again. I restarted the phone and went into factory setting via menus and reset 'ALL' . After that phone worked fine. It looks like 2945#*# factory reset does not clear all the memory hence problem with messages etc. I hope it helps. br msa |
Nokia 1650 text message problem | majidm | Nokia Hardware & Hardware Repair | 5 | 01-23-2010 18:51 |
Windows Mobile Text messages Backup - Backup windows mobile text messages to computer | Judy00 | HTC & PDA WM( With Touchscreen) | 0 | 12-28-2009 03:59 |
E570 text message problem | CLord | Samsung Hardware Repair | 0 | 08-03-2008 21:21 |
w600 text message problem | ExTrEmE99 | Sony Ericsson | 0 | 10-18-2006 05:19 |
Maxon O2X1 problem sending text message | LEE5K | Various | 2 | 08-20-2004 01:34 |
