12-02-2008, 17:24 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Age: 54
Member: 105625 Status: Offline Thanks Meter: 44 | KU990 - can't connect after flashing was interupted So i have to try again, and i set the phone to Emergency download, and now I can't connect in vygis... I connect port, then i connect phone, but the status just says "Connecting ..." Phone is visible in device manager and all drivers are installed fine. |
12-02-2008, 17:52 | #2 (permalink) |
Member: 105625 Status: Offline Thanks Meter: 44 | Never mind, it worked after i changed USB-port and reinstalled drivers. But what port am i supposed to select in the top of the interface? Why do I even have to select a port when it's using USB anyway? |
12-02-2008, 20:50 | #3 (permalink) |
No Life Poster Join Date: Jul 2008
Member: 818352 Status: Offline Thanks Meter: 266 | Auto Find Port Doesnt Work In case of Driver Conflict, Where as u can select manually based On port ur lg is connected in device manager If Ur lg is not auto detected by software Then u may experince Problems in case of flashing Where is manual u can Use Service Settings in Software without any problems Regards,Trigger |
KU990 no network after flash | TERP | FuriousGold | 15 | 09-12-2013 09:17 |
Bleu 251x cal can't connect after unlock | Benzee76 | Infinity-Box | 0 | 06-11-2009 08:37 |
Ku990 camera restart after flash | TERP | FuriousGold | 0 | 09-23-2008 18:09 |
Help... 2310 can't connect after full erase error | Enigma82 | J.A.F. By Jafsupport.com | 2 | 05-08-2008 08:25 |
Oxygen 2.4.0.5 - can't connect after removing the phone | Kalin72 | Nokia Multimedia | 0 | 06-02-2005 20:16 |
