06-18-2009, 16:52 | #1 (permalink) |
Insane Poster Join Date: May 2009
Member: 1038927 Status: Offline Thanks Meter: 8 | Lg kp500 unlock problem......help I used KE500 Cable for it.... I connect the port.....After pressing connect phone .......IT says power on phone.......But its no working...... All other models are accepted except this one...... could any one correct me if I am doing something wrong |
The Following User Says Thank You to inti11 For This Useful Post: |
06-18-2009, 19:00 | #3 (permalink) | |
Freak Poster Join Date: Mar 2008 Location: Quetta
Member: 728887 Status: Offline Sonork: 100.1625878 Thanks Meter: 18 | Quote:
its very easy you can just use KE500 cable and then reply | |
06-18-2009, 19:19 | #4 (permalink) |
Freak Poster Join Date: Apr 2008 Location: inside my SOFTWARE ROOM
Member: 761864 Status: Offline Thanks Meter: 63 | USE KE500 rj45 cable man... it doesent work on usb-cable, if you dont have ke500 cable in rj45 type you need to improvised ke500 rj45 cable. then press read codes if supported, if not direct unlock.. |
06-19-2009, 11:18 | #5 (permalink) | |
Member: 1038927 Status: Offline Thanks Meter: 8 | Quote:
I think I have written clearly That I am using "KE500 cable" not Usb cabe........ And have changed the cable too.....I got two ke500 cables.......... that's why i am confused............what would be the problem............?????. any idea;....????? | |
06-19-2009, 11:52 | #6 (permalink) |
Freak Poster Join Date: Dec 2006 Location: philippines
Member: 406299 Status: Offline Sonork: none Thanks Meter: 280 | try this sir... speed 115200....select port usb- rs232 by vygis soft..then connect port.. connect cable to unit...tick connect phone...then put batery to unit..then press power...phone must be connect... then tick unlock..phone open.. |
06-19-2009, 14:36 | #7 (permalink) | |
Registered User Join Date: Sep 2006
Member: 347110 Status: Offline Thanks Meter: 34 | Quote:
LG KU990ig UNLOCK PROBLEM HELP | brokendreem | FuriousGold | 5 | 11-20-2009 14:45 |
LG U890 UNLOCK PROBLEM help. | baig65 | FuriousGold | 2 | 10-13-2009 14:55 |
kp500 unlock problem pls help | THE GREAT ONE | FuriousGold | 4 | 08-22-2009 09:38 |
LG-kp500 Big problem | Ralfe | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 20 | 05-13-2009 02:49 |
LG CG225 unlock problem. help! | davilixian | FuriousGold | 2 | 03-18-2008 09:30 |
