07-04-2007, 03:13 | #1 (permalink) |
No Life Poster Join Date: Dec 2001 Location: Prussia
Member: 7844 Status: Offline Thanks Meter: 182 | pls help unlock vk 1100 pls help unlocking for vk 1100 using vk4000 pinouts i cannot connect to phone windows detects vk multi download driver when i connect it on usb it installs but i cannot seem to find its port number under device manager in vygis prog should i choose usb-r232 by vygissoft? |
07-04-2007, 06:18 | #4 (permalink) |
Product Supporter Join Date: Mar 2007 Location: GSD Pro (Dongle) Age: 38
Member: 460762 Status: Offline Sonork: 100.1592082 Thanks Meter: 3,104 | *#79# - SW version *#85*364# (*) - hold menu 855855# without SIM (VG107) 85558555#(*)-hold 4268#(*)-hold (VG207) |
07-04-2007, 07:31 | #5 (permalink) | |
No Life Poster Join Date: Sep 2001 Location: GSM-TOOL Age: 52
Member: 6328 Status: Offline Thanks Meter: 3,595 | Quote:
Use the RJ45 cable that connects to VygisToolbox, and NOT the phone USB cable. regards, Gobi | |
08-13-2007, 08:46 | #10 (permalink) |
Member: 7844 Status: Offline Thanks Meter: 182 | hi i created RJ45 cable from attachment given . when i load VK i choose 1100 and click on connect , it will then thisplay : "Press power ON button and keep it pressed" for how long shall i keep on holding power button ? on VK toolbox RTS LED is ON and CTS LED is blinking , did i build the cable wrong ? |
08-13-2007, 10:10 | #11 (permalink) |
Member: 6328 Status: Offline Thanks Meter: 3,595 | Your cable musty be wrong. Probably you have connected wrong Rx and TX. REMEMBER Tx of Phone you have to connect to Rx of box and so on .. regards, Gobi |
Pls Help my nokia 1100 has no signal! | redge | Nokia Hardware & Hardware Repair | 3 | 05-25-2006 10:54 |
Pls help unlock Nokia 3530 | maxdu | Phone Unlocking Codes & Maps | 2 | 04-29-2003 19:27 |
Pls help unlock MW3026 | ivanich | Phone Unlocking Codes & Maps | 0 | 02-13-2003 04:24 |
M35v20 locked....pls help unlock it !!!! | GsmNut | x1x to x45/x50 | 2 | 12-30-2002 09:29 |
Pls help unlock my gd90! | unidencek | Panasonic | 3 | 08-14-2001 10:10 |
