07-31-2012, 12:14 | #256 (permalink) |
No Life Poster Join Date: Apr 2010 Location: Uzbekistan Age: 45
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | 30.07.2012 10:35:11 > ---------------------------------------------------------- 30.07.2012 10:35:11 > If you can't connect using USB cable do next : 30.07.2012 10:35:11 > - enter "DEBUG MENU" in next way : 30.07.2012 10:35:11 > - type ##000000# in dial window 30.07.2012 10:35:11 > - enter like password phone code 30.07.2012 10:35:11 > - default is "0000" 30.07.2012 10:35:11 > - select "COMM.ENVIRONMENT" 30.07.2012 10:35:11 > - set "DM Port" to USB 30.07.2012 10:35:11 > - if you see baudrate - set it to 115200 30.07.2012 10:35:11 > - set "DS Port" to USB 30.07.2012 10:35:11 > - if you see baudrate - set it to 115200 30.07.2012 10:35:16 > For phone connecting do next : 30.07.2012 10:35:16 > - enter "System info" menu by typing 30.07.2012 10:35:16 > "4433366368791" in dial window 30.07.2012 10:35:16 > - select "SIO MODE" 30.07.2012 10:35:16 > - select "Port Map" menu item 30.07.2012 10:35:16 > - set "Diag Monitor" to "USB CDC" value 30.07.2012 10:35:16 > - rest items in this menu set to "NULL DEV" 30.07.2012 10:35:32 > Port COM70 connected 30.07.2012 10:35:38 > Connecting ... 30.07.2012 10:35:38 > Connecting ... OK 30.07.2012 10:35:38 > Connected in NORMAL MODE 30.07.2012 10:35:38 > ---------------------------------------------------------- 30.07.2012 10:35:38 > Phone type selected : SPH-W7700 30.07.2012 10:35:38 > IMEI : 353630-03-531506-5 30.07.2012 10:35:38 > Bluetooth Addr : A8:F2:74:C0:61:2D 30.07.2012 10:35:38 > Phone version : M6281A-KLRZ-4.0.9565T 30.07.2012 10:35:38 > Compilation info : Mar 30 201022:05:14May 05 30.07.2012 10:35:38 > 200808:00:00SPH-W770 30.07.2012 10:35:38 > Phone code : 1234 30.07.2012 10:35:40 > ---------------------------------------------------------- 30.07.2012 10:35:40 > Unlocking ... 30.07.2012 10:35:40 > Switching to DL Mode ... 30.07.2012 10:35:44 > Switching to DL Mode ... OK 30.07.2012 10:35:44 > Reading security area 1 ... 30.07.2012 10:35:45 > Reading security area 1 ... OK 30.07.2012 10:35:45 > Writing security area 1 ... 30.07.2012 10:35:46 > Writing security area 1 ... OK 30.07.2012 10:35:46 > Restarting phone ... 30.07.2012 10:35:46 > Restarting phone ... OK 30.07.2012 10:35:46 > ======== Process completed ======== 30.07.2012 10:35:46 > Operation time - 00:06 30.07.2012 10:35:46 > Port COM21 disconnected |
07-31-2012, 12:15 | #257 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | 30.07.2012 12:50:44 > Software version : LGQ_1_91SD.exe 30.07.2012 12:50:44 > ---------------------------------------------------------- 30.07.2012 12:51:32 > Port COM86 connected 30.07.2012 12:51:34 > Connecting ... 30.07.2012 12:51:35 > Connecting ... OK 30.07.2012 12:51:35 > Connected in NORMAL MODE 30.07.2012 12:51:37 > ---------------------------------------------------------- 30.07.2012 12:51:37 > Phone type selected : SU910 30.07.2012 12:51:37 > IMEI : 352667-03-274753-7 30.07.2012 12:51:37 > Bluetooth Addr : 01:12:10:E5:25:00 30.07.2012 12:51:37 > Phone version : 30.07.2012 12:51:37 > SU910905_M6280A-KLRZ-4.0.95T 30.07.2012 12:51:37 > Compilation info : May 22 200911:35:00Aug 14 30.07.2012 12:51:37 > 200719:00:00SU910905 30.07.2012 12:51:37 > Flash ID : ADBA 30.07.2012 12:51:37 > Flash type : H8ACS0SJ0MCP 30.07.2012 12:51:37 > Flash size : 0B700000 30.07.2012 12:51:37 > Flash pages count : 00016E00 30.07.2012 12:51:37 > Flash page size : 00000800 30.07.2012 12:51:37 > Flash block size : 00020000 30.07.2012 12:51:39 > ---------------------------------------------------------- 30.07.2012 12:51:39 > Unlocking ... 30.07.2012 12:51:39 > Reading NVM backup ... 30.07.2012 12:51:43 > Reading NVM backup ... OK 30.07.2012 12:51:43 > NVM backup saved to file : 30.07.2012 12:51:43 > NV_SU910_352667-03-274753-7_2012_7_30_12 30.07.2012 12:51:43 > _51.nv2 30.07.2012 12:51:43 > Continue unlocking ... 30.07.2012 12:51:43 > Continue unlocking ... OK 30.07.2012 12:51:43 > Reseting phone ... 30.07.2012 12:51:43 > Reseting phone ... OK 30.07.2012 12:51:43 > ======== Process completed ======== 30.07.2012 12:51:43 > Operation time - 00:04 30.07.2012 12:51:43 > Port COM86 disconnected |
07-31-2012, 12:15 | #258 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | 30.07.2012 14:22:46 > Software version : SAM_1_28SD.exe 30.07.2012 14:22:46 > ---------------------------------------------------------- 30.07.2012 14:22:46 > For phone connecting do next : 30.07.2012 14:22:46 > - enter "System info" menu by typing 30.07.2012 14:22:46 > "4433366368791" in dial window 30.07.2012 14:22:46 > - select "SIO MODE" 30.07.2012 14:22:46 > - select "Port Map" menu item 30.07.2012 14:22:46 > - set "Diag Monitor" to "USB CDC" value 30.07.2012 14:22:46 > - rest items in this menu set to "NULL DEV" 30.07.2012 14:23:01 > For phone connecting do next : 30.07.2012 14:23:01 > - enter "System info" menu by typing 30.07.2012 14:23:01 > "4433366368791" in dial window 30.07.2012 14:23:01 > - select "SIO MODE" 30.07.2012 14:23:01 > - select "Port Map" menu item 30.07.2012 14:23:01 > - set "Diag Monitor" to "USB CDC" value 30.07.2012 14:23:01 > - rest items in this menu set to "NULL DEV" 30.07.2012 14:23:47 > Port COM144 connected 30.07.2012 14:23:48 > Connecting ... 30.07.2012 14:23:48 > Connecting ... OK 30.07.2012 14:23:48 > Connected in NORMAL MODE 30.07.2012 14:23:48 > ---------------------------------------------------------- 30.07.2012 14:23:48 > Phone type selected : SCH-W550 30.07.2012 14:23:48 > IMEI : 354530-02-011060-5 30.07.2012 14:23:48 > Bluetooth Addr : 00:212:E8:23:5C 30.07.2012 14:23:48 > Phone version : SAMSUNG Electronics 30.07.2012 14:23:48 > Compilation info : May 22 200913:01:59May 05 30.07.2012 14:23:48 > 200808:00:00SCH-W550 30.07.2012 14:23:50 > ---------------------------------------------------------- 30.07.2012 14:23:50 > Unlocking ... 30.07.2012 14:23:50 > Switching to DL Mode ... 30.07.2012 14:23:55 > Switching to DL Mode ... OK 30.07.2012 14:23:55 > Reading security area 1 ... 30.07.2012 14:23:57 > Reading security area 1 ... OK 30.07.2012 14:23:57 > Writing security area 1 ... 30.07.2012 14:24:00 > Writing security area 1 ... OK 30.07.2012 14:24:00 > Restarting phone ... 30.07.2012 14:24:00 > Restarting phone ... OK 30.07.2012 14:24:00 > ======== Process completed ======== 30.07.2012 14:24:00 > Operation time - 00:09 30.07.2012 14:24:00 > Port COM144 disconnected 30.07.2012 14:27:13 > Port COM144 connected 30.07.2012 14:27:14 > Connecting ... 30.07.2012 14:27:14 > Connecting ... OK 30.07.2012 14:27:14 > Connected in NORMAL MODE 30.07.2012 14:27:14 > ---------------------------------------------------------- 30.07.2012 14:27:14 > Phone type selected : SCH-W550 30.07.2012 14:27:14 > IMEI : 354530-02-011060-5 30.07.2012 14:27:14 > Bluetooth Addr : 00:212:E8:23:5C 30.07.2012 14:27:14 > Phone version : SAMSUNG Electronics 30.07.2012 14:27:14 > Compilation info : May 22 200913:01:59May 05 30.07.2012 14:27:14 > 200808:00:00SCH-W550 30.07.2012 14:27:16 > ---------------------------------------------------------- 30.07.2012 14:27:16 > Repairing phone NVM area ... 30.07.2012 14:27:54 > Repairing phone NVM area ... OK 30.07.2012 14:27:54 > Restarting phone ... 30.07.2012 14:27:54 > Restarting phone ... OK 30.07.2012 14:27:54 > ======== Process completed ======== 30.07.2012 14:27:54 > Operation time - 00:38 30.07.2012 14:27:54 > Port COM144 disconnected |
08-01-2012, 11:41 | #259 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | Readed user code 01.08.2012 13:30:08 > Software version : SAM_1_28SD.exe 01.08.2012 13:30:08 > ---------------------------------------------------------- 01.08.2012 13:30:26 > For phone connecting do next : 01.08.2012 13:30:26 > - enter "System info" menu in next way : 01.08.2012 13:30:26 > - enter to phone menu 01.08.2012 13:30:26 > - long press "0" till password window will appear 01.08.2012 13:30:26 > - enter password "0821" 01.08.2012 13:30:26 > - select "SIO MODE" 01.08.2012 13:30:26 > - select "Port Map" menu item 01.08.2012 13:30:26 > - set "Diag Monitor" to "USB CDC" value 01.08.2012 13:30:26 > - rest items in this menu set to "NULL DEV" 01.08.2012 13:32:48 > Port COM142 connected 01.08.2012 13:32:49 > Connecting ... 01.08.2012 13:32:51 > Can't connect phone 01.08.2012 13:32:51 > Operation failed 01.08.2012 13:32:54 > Port COM142 disconnected 01.08.2012 13:32:56 > Port COM142 connected 01.08.2012 13:32:57 > Connecting ... 01.08.2012 13:32:57 > Connecting ... OK 01.08.2012 13:32:57 > Connected in NORMAL MODE 01.08.2012 13:32:57 > ---------------------------------------------------------- 01.08.2012 13:32:57 > Phone type selected : SHW-A280K 01.08.2012 13:32:57 > IMEI : 355692-04-376000-3 01.08.2012 13:32:57 > Bluetooth Addr : D4:878:22:C6:A9 01.08.2012 13:32:57 > Phone version : SAMSUNG Electronics 01.08.2012 13:32:57 > Compilation info : Oct 18 201114:20:45Oct 18 01.08.2012 13:32:57 > 201114:20:45SHW-A280 01.08.2012 13:32:57 > Phone code : 7140 |
08-01-2012, 14:27 | #260 (permalink) |
Freak Poster Join Date: Sep 2006
Member: 353717 Status: Offline Sonork: 1001647526 Thanks Meter: 147 | 31/07/2012 3:23:29 CH > Phone type selected : EV-W470 31/07/2012 3:23:29 CH > Bluetooth Addr : 00:00:00:00:00:00 31/07/2012 3:23:29 CH > Phone version : EV-W470_W470.327.0 31/07/2012 3:23:29 CH > Compilation info : Apr 29 200913:45:14Apr 29 31/07/2012 3:23:29 CH > 200912:00:00DP1 31/07/2012 3:23:29 CH > Phone code : 1913 31/07/2012 3:23:33 CH > ---------------------------------------------------------- 31/07/2012 3:23:33 CH > Unlocking ... 31/07/2012 3:23:33 CH > Entering DL mode ... 31/07/2012 3:23:35 CH > Entering DL mode ... OK 31/07/2012 3:23:35 CH > Loading main loader ... 31/07/2012 3:23:36 CH > Loading main loader ... OK 31/07/2012 3:23:36 CH > Executing loader, please wait ... 31/07/2012 3:23:40 CH > Executing loader, please wait ... OK 31/07/2012 3:23:40 CH > Authorizating loader ... 31/07/2012 3:23:40 CH > Authorizating loader ... OK 31/07/2012 3:23:40 CH > Initialing NAND ... 31/07/2012 3:23:40 CH > Initialing NAND ... OK 31/07/2012 3:23:40 CH > Continue operation ... 31/07/2012 3:23:40 CH > Reading security area 1 ... 31/07/2012 3:23:53 CH > Reading security area 1 ... OK 31/07/2012 3:23:53 CH > Writing security area 1 ... 31/07/2012 3:23:55 CH > Writing security area 1 ... OK 31/07/2012 3:23:55 CH > Restarting phone ... 31/07/2012 3:23:55 CH > Restarting phone ... OK |
08-04-2012, 04:52 | #261 (permalink) |
Freak Poster Join Date: Jun 2012 Location: viet nam
Member: 1776297 Status: Offline Thanks Meter: 53 | Phone type selected : SKY-IM-U570K IMEI : 359152-03-073669-4 Bluetooth Addr : 00:153:93:C9:F1 Phone version : M6290A-KPRZL-2.4.0135T Compilation info : Mar 16 201016:38:46Dec 05 200911:00:00S0827160 Phone code : 0314 Connecting ... OK Connected in NORMAL MODE ---------------------------------------------------------- Unlocking ... Reading NVM backup ... OK Continue unlocking ... OK Restarting phone ... OK ======== Process completed ======== Operation time - 00:04 |
08-04-2012, 05:31 | #262 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | 03.08.2012 10:42:48 > Software version : SAM_1_28SD.exe 03.08.2012 10:42:48 > ---------------------------------------------------------- 03.08.2012 10:42:48 > For phone connecting do next : 03.08.2012 10:42:48 > - enter "System info" menu in next way : 03.08.2012 10:42:48 > - enter to phone menu 03.08.2012 10:42:48 > - long press "0" till password window will appear 03.08.2012 10:42:48 > - enter password "0821" 03.08.2012 10:42:48 > - select "SIO MODE" 03.08.2012 10:42:48 > - select "Port Map" menu item 03.08.2012 10:42:48 > - set "Diag Monitor" to "USB CDC" value 03.08.2012 10:42:48 > - rest items in this menu set to "NULL DEV" 03.08.2012 10:43:25 > For phone connecting do next : 03.08.2012 10:43:25 > - enter "System info" menu in next way : 03.08.2012 10:43:25 > - enter to phone menu 03.08.2012 10:43:25 > - long press "0" till password window will appear 03.08.2012 10:43:25 > - enter password "0821" 03.08.2012 10:43:25 > - select "SIO MODE" 03.08.2012 10:43:25 > - select "Port Map" menu item 03.08.2012 10:43:25 > - set "Diag Monitor" to "USB CDC" value 03.08.2012 10:43:25 > - rest items in this menu set to "NULL DEV" 03.08.2012 10:44:43 > For phone connecting do next : 03.08.2012 10:44:43 > - enter "System info" menu in next way : 03.08.2012 10:44:43 > - enter to phone menu 03.08.2012 10:44:43 > - long press "0" till password window will appear 03.08.2012 10:44:43 > - enter password "0821" 03.08.2012 10:44:43 > - select "SIO MODE" 03.08.2012 10:44:43 > - select "Port Map" menu item 03.08.2012 10:44:43 > - set "Diag Monitor" to "USB CDC" value 03.08.2012 10:44:43 > - rest items in this menu set to "NULL DEV" 03.08.2012 10:45:55 > Port COM39 connected 03.08.2012 10:46:01 > Connecting ... 03.08.2012 10:46:01 > Connecting ... OK 03.08.2012 10:46:01 > Connected in NORMAL MODE 03.08.2012 10:46:01 > ---------------------------------------------------------- 03.08.2012 10:46:01 > Phone type selected : SCH-W930 03.08.2012 10:46:01 > IMEI : 356746-03-024667-0 03.08.2012 10:46:01 > Bluetooth Addr : A8:F2:74:C4:92:8A 03.08.2012 10:46:01 > Phone version : SAMSUNG Electronics 03.08.2012 10:46:01 > Compilation info : Jan 25 201020:23:20Jan 25 03.08.2012 10:46:01 > 201020:23:20SCH-W930 03.08.2012 10:46:01 > Phone code : 0000 03.08.2012 10:46:17 > ---------------------------------------------------------- 03.08.2012 10:46:17 > Unlocking ... 03.08.2012 10:46:17 > Bypassing NVM security ... 03.08.2012 10:46:18 > Bypassing NVM security ... OK 03.08.2012 10:46:18 > Continue unlocking ... 03.08.2012 10:46:18 > Switching to DL Mode ... 03.08.2012 10:46:23 > Switching to DL Mode ... OK 03.08.2012 10:46:23 > Reading security area ... 03.08.2012 10:46:24 > Reading security area ... OK 03.08.2012 10:46:24 > Seeking patch signature ... 03.08.2012 10:46:58 > Seeking patch signature ... OK 03.08.2012 10:46:58 > Restarting phone ... 03.08.2012 10:46:58 > Restarting phone ... OK 03.08.2012 10:46:58 > Seeking phone, please wait ... 03.08.2012 10:48:00 > Operation failed 03.08.2012 10:48:00 > Restarting phone ... 03.08.2012 10:48:39 > Port COM22 disconnected 03.08.2012 10:48:39 > Port COM22 disconnected 03.08.2012 10:48:41 > Port COM39 connected 03.08.2012 10:48:42 > Connecting ... 03.08.2012 10:48:42 > Connecting ... OK 03.08.2012 10:48:42 > Connected in NORMAL MODE 03.08.2012 10:48:42 > ---------------------------------------------------------- 03.08.2012 10:48:42 > Phone type selected : SCH-W930 03.08.2012 10:48:42 > IMEI : 356746-03-024667-0 03.08.2012 10:48:42 > Bluetooth Addr : A8:F2:74:C4:92:8A 03.08.2012 10:48:42 > Phone version : SAMSUNG Electronics 03.08.2012 10:48:42 > Compilation info : Jan 25 201020:23:20Jan 25 03.08.2012 10:48:42 > 201020:23:20SCH-W930 03.08.2012 10:48:42 > Phone code : 0000 03.08.2012 10:48:45 > ---------------------------------------------------------- 03.08.2012 10:48:45 > Repairing phone NVM area ... 03.08.2012 10:49:14 > Repairing phone NVM area ... OK 03.08.2012 10:49:14 > Restarting phone ... 03.08.2012 10:49:15 > Restarting phone ... OK 03.08.2012 10:49:15 > ======== Process completed ======== 03.08.2012 10:49:15 > Operation time - 00:30 03.08.2012 10:49:15 > Port COM39 disconnected 03.08.2012 10:49:47 > Port COM39 connected 03.08.2012 10:49:48 > Connecting ... 03.08.2012 10:49:48 > Connecting ... OK 03.08.2012 10:49:48 > Connected in NORMAL MODE 03.08.2012 10:49:48 > ---------------------------------------------------------- 03.08.2012 10:49:48 > Phone type selected : SCH-W930 03.08.2012 10:49:48 > IMEI : 356746-03-024667-0 03.08.2012 10:49:48 > Bluetooth Addr : A8:F2:74:C3:1F:4E 03.08.2012 10:49:48 > Phone version : SAMSUNG Electronics 03.08.2012 10:49:48 > Compilation info : Jan 25 201020:23:20Jan 25 03.08.2012 10:49:48 > 201020:23:20SCH-W930 03.08.2012 10:49:50 > ---------------------------------------------------------- 03.08.2012 10:49:50 > Unlocking ... 03.08.2012 10:49:50 > Bypassing NVM security ... 03.08.2012 10:49:51 > Bypassing NVM security ... OK 03.08.2012 10:49:51 > Continue unlocking ... 03.08.2012 10:49:51 > Switching to DL Mode ... 03.08.2012 10:49:55 > Switching to DL Mode ... OK 03.08.2012 10:49:55 > Reading security area ... 03.08.2012 10:49:56 > Reading security area ... OK 03.08.2012 10:49:56 > Seeking patch signature ... 03.08.2012 10:50:31 > Seeking patch signature ... OK 03.08.2012 10:50:31 > Restarting phone ... 03.08.2012 10:50:31 > Restarting phone ... OK 03.08.2012 10:50:31 > Seeking phone, please wait ... 03.08.2012 10:51:09 > Seeking phone, please wait ... OK 03.08.2012 10:51:09 > Switching to DL Mode ... 03.08.2012 10:51:13 > Switching to DL Mode ... OK 03.08.2012 10:51:13 > Writing security area ... 03.08.2012 10:51:14 > Writing security area ... OK 03.08.2012 10:51:14 > Restarting phone ... 03.08.2012 10:51:14 > Restarting phone ... OK 03.08.2012 10:51:14 > ======== Process completed ======== 03.08.2012 10:51:14 > Operation time - 01:24 03.08.2012 10:51:15 > Port COM20 disconnected |
08-07-2012, 09:58 | #263 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | 04.08.2012 11:29:08 > Software version : SAM_1_28SD.exe 04.08.2012 11:29:08 > ---------------------------------------------------------- 04.08.2012 11:29:08 > For phone connecting do next : 04.08.2012 11:29:08 > - enter "System info" menu in next way : 04.08.2012 11:29:08 > - enter to phone menu 04.08.2012 11:29:08 > - long press "0" till password window will appear 04.08.2012 11:29:08 > - enter password "0821" 04.08.2012 11:29:08 > - select "SIO MODE" 04.08.2012 11:29:08 > - select "Port Map" menu item 04.08.2012 11:29:08 > - set "Diag Monitor" to "USB CDC" value 04.08.2012 11:29:08 > - rest items in this menu set to "NULL DEV" 04.08.2012 11:29:16 > For phone connecting do next : 04.08.2012 11:29:16 > - enter "System info" menu in next way : 04.08.2012 11:29:16 > - enter to phone menu 04.08.2012 11:29:16 > - long press "0" till password window will appear 04.08.2012 11:29:16 > - enter password "0821" 04.08.2012 11:29:16 > - select "SIO MODE" 04.08.2012 11:29:16 > - select "Port Map" menu item 04.08.2012 11:29:16 > - set "Diag Monitor" to "USB CDC" value 04.08.2012 11:29:16 > - rest items in this menu set to "NULL DEV" 04.08.2012 11:29:40 > Port COM21 connected 04.08.2012 11:29:42 > Connecting ... 04.08.2012 11:29:42 > Connecting ... OK 04.08.2012 11:29:42 > Connected in NORMAL MODE 04.08.2012 11:29:42 > ---------------------------------------------------------- 04.08.2012 11:29:42 > Phone type selected : SPH-W2500 04.08.2012 11:29:42 > IMEI : 354387-01-051692-3 04.08.2012 11:29:42 > Bluetooth Addr : 00:1A:8A:49:A1:7D 04.08.2012 11:29:42 > Phone version : M6275B-KMRZ-3.2.7123 04.08.2012 11:29:42 > Compilation info : Mar 19 200717:22:28Nov 15 04.08.2012 11:29:42 > 200611:00:00SPH-W250 04.08.2012 11:29:42 > Phone code : 1111 04.08.2012 11:29:42 > Flash ID : 9871 04.08.2012 11:29:42 > Flash type : toshiba_tya000bc 04.08.2012 11:29:42 > Flash size : 02100000 04.08.2012 11:29:42 > Flash pages count : 00010800 04.08.2012 11:29:42 > Flash page size : 00000200 04.08.2012 11:29:42 > Flash block size : 00004000 04.08.2012 11:29:47 > ---------------------------------------------------------- 04.08.2012 11:29:47 > Unlocking ... 04.08.2012 11:29:47 > Unlocking ... OK 04.08.2012 11:29:47 > Restarting phone ... 04.08.2012 11:29:48 > Restarting phone ... OK 04.08.2012 11:29:48 > ======== Process completed ======== 04.08.2012 11:29:48 > Operation time - 00:00 04.08.2012 11:29:48 > Port COM21 disconnected |
08-07-2012, 09:58 | #264 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | 07.08.2012 10:32:40 > Software version : LGQ_1_91SD.exe 07.08.2012 10:32:40 > ---------------------------------------------------------- 07.08.2012 10:32:46 > Port COM252 connected 07.08.2012 10:32:47 > Connecting ... 07.08.2012 10:32:49 > Connecting ... OK 07.08.2012 10:32:49 > Connected in NORMAL MODE 07.08.2012 10:32:50 > ---------------------------------------------------------- 07.08.2012 10:32:50 > Phone type selected : SU950 07.08.2012 10:32:50 > IMEI : 352526-04-031300-7 07.08.2012 10:32:50 > Bluetooth Addr : 64:99:5D:1B:CF:39 07.08.2012 10:32:50 > Phone version : 07.08.2012 10:32:50 > SU950019_8650B-SDCAOLYM-5040 07.08.2012 10:32:50 > Compilation info : Jul 24 201108:18:04Sep 01 07.08.2012 10:32:50 > 201011:00:00SU950019 07.08.2012 10:32:50 > Flash ID : ADB3 07.08.2012 10:32:50 > Flash type : HYNIX_H8BES0WU0MCR 07.08.2012 10:32:50 > Flash size : 00C00000 07.08.2012 10:32:50 > Flash pages count : 00001800 07.08.2012 10:32:50 > Flash page size : 00000800 07.08.2012 10:32:50 > Flash block size : 00020000 07.08.2012 10:32:57 > ---------------------------------------------------------- 07.08.2012 10:32:57 > Writing flash from file : 07.08.2012 10:32:57 > SU950_SU950015_01_EN_KOR.crc 07.08.2012 10:33:28 > Checking flash files ... 07.08.2012 10:33:46 > Checking flash files ... OK 07.08.2012 10:33:46 > ---------------------------------------------------------- 07.08.2012 10:33:46 > Reading NVM backup ... 07.08.2012 10:33:50 > Reading NVM backup ... OK 07.08.2012 10:33:50 > NVM backup saved to file : 07.08.2012 10:33:50 > NV_SU950_352526-04-031300-7_2012_8_7_10_ 07.08.2012 10:33:50 > 33.nv2 07.08.2012 10:33:50 > Entering DL mode ... 07.08.2012 10:33:55 > Entering DL mode ... OK 07.08.2012 10:33:55 > TIME CRITICAL PROCESS 07.08.2012 10:33:55 > NOT MAKE ANY OTHER OPERATIONS WITH PC! 07.08.2012 10:33:58 > ---------------------------------------------------------- 07.08.2012 10:33:58 > Writing ROM file ... 07.08.2012 10:33:58 > Writing AMSS ... 07.08.2012 10:34:01 > Writing AMSS ... OK 07.08.2012 10:34:01 > Writing APPS ... 07.08.2012 10:34:02 > Writing APPS ... OK 07.08.2012 10:34:02 > Writing DSP1 ... 07.08.2012 10:34:06 > Writing DSP1 ... OK 07.08.2012 10:34:06 > Writing LNX-0 ... 07.08.2012 10:34:08 > Writing LNX-0 ... OK 07.08.2012 10:34:12 > Writing LNX-1 ... 07.08.2012 10:36:31 > Writing LNX-1 ... OK 07.08.2012 10:36:37 > Writing LNX-2 ... 07.08.2012 10:36:37 > Writing LNX-2 ... OK 07.08.2012 10:36:37 > Writing MIBI ... 07.08.2012 10:36:38 > Writing MIBI ... OK 07.08.2012 10:36:38 > Writing FSBL ... 07.08.2012 10:36:38 > Writing FSBL ... OK 07.08.2012 10:36:38 > Writing OSBL ... 07.08.2012 10:36:38 > Writing OSBL ... OK 07.08.2012 10:36:38 > ---------------------------------------------------------- 07.08.2012 10:36:38 > Restarting phone,if phone won't restart in 10 07.08.2012 10:36:38 > sec. press power ON shortly ... 07.08.2012 10:36:55 > sec. press power ON shortly ... OK 07.08.2012 10:36:55 > Phone initialization, please wait ... 07.08.2012 10:37:20 > Phone initialization, please wait ... OK 07.08.2012 11:14:08 > ======== Process completed ======== 07.08.2012 11:14:08 > Operation time - 41:10 07.08.2012 11:14:09 > Port COM252 disconnected |
08-07-2012, 09:59 | #265 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | user code readed 07.08.2012 12:17:54 > Software version : SAM_1_28SD.exe 07.08.2012 12:17:54 > ---------------------------------------------------------- 07.08.2012 12:17:54 > For phone connecting do next : 07.08.2012 12:17:54 > - enter "System info" menu in next way : 07.08.2012 12:17:54 > - enter to phone menu 07.08.2012 12:17:54 > - long press "0" till password window will appear 07.08.2012 12:17:54 > - enter password "0821" 07.08.2012 12:17:54 > - select "SIO MODE" 07.08.2012 12:17:54 > - select "Port Map" menu item 07.08.2012 12:17:54 > - set "Diag Monitor" to "USB CDC" value 07.08.2012 12:17:54 > - rest items in this menu set to "NULL DEV" 07.08.2012 12:18:35 > For phone connecting do next : 07.08.2012 12:18:35 > - enter "System info" menu in next way : 07.08.2012 12:18:35 > - enter to phone menu 07.08.2012 12:18:35 > - long press "0" till password window will appear 07.08.2012 12:18:35 > - enter password "0821" 07.08.2012 12:18:35 > - select "SIO MODE" 07.08.2012 12:18:35 > - select "Port Map" menu item 07.08.2012 12:18:35 > - set "Diag Monitor" to "USB CDC" value 07.08.2012 12:18:35 > - rest items in this menu set to "NULL DEV" 07.08.2012 12:19:54 > Port COM21 connected 07.08.2012 12:19:55 > Connecting ... 07.08.2012 12:19:55 > Connecting ... OK 07.08.2012 12:19:55 > Connected in NORMAL MODE 07.08.2012 12:19:56 > ---------------------------------------------------------- 07.08.2012 12:19:56 > Phone type selected : SPH-W8300 07.08.2012 12:19:56 > IMEI : 354521-03-735493-0 07.08.2012 12:19:56 > Bluetooth Addr : F4:9F:54:E7:1F:71 07.08.2012 12:19:56 > Phone version : M6260A-KYRZ-2.5.1040T 07.08.2012 12:19:56 > Compilation info : Apr 29 201009:09:10Jan 22 07.08.2012 12:19:56 > 200905:00:00SPH-W830 07.08.2012 12:19:56 > Phone code : 4288 07.08.2012 12:20:44 > Port COM21 disconnected |
08-07-2012, 09:59 | #266 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | 07.08.2012 12:20:51 > Software version : LGQ_1_91SD.exe 07.08.2012 12:20:51 > ---------------------------------------------------------- 07.08.2012 12:21:39 > Port COM86 connected 07.08.2012 12:21:40 > Connecting ... 07.08.2012 12:21:42 > Connecting ... OK 07.08.2012 12:21:42 > Connected in NORMAL MODE 07.08.2012 12:21:43 > ---------------------------------------------------------- 07.08.2012 12:21:43 > Phone type selected : KU4000 07.08.2012 12:21:43 > IMEI : 354020-03-405860-2 07.08.2012 12:21:43 > Bluetooth Addr : 00:00:00:00:00:00 07.08.2012 12:21:43 > Phone version : 07.08.2012 12:21:43 > KU400911_M6281A-KLRZ-4.0.9530 07.08.2012 12:21:43 > Compilation info : Feb 10 201012:00:00Aug 05 07.08.2012 12:21:43 > 200805:00:00KU400911 07.08.2012 12:21:43 > Flash ID : 98CA 07.08.2012 12:21:43 > Flash type : toshiba_tya000bc00dogg 07.08.2012 12:21:43 > Flash size : 0CA20000 07.08.2012 12:21:43 > Flash pages count : 00019440 07.08.2012 12:21:43 > Flash page size : 00000800 07.08.2012 12:21:43 > Flash block size : 00020000 07.08.2012 12:21:46 > ---------------------------------------------------------- 07.08.2012 12:21:46 > Unlocking ... 07.08.2012 12:21:46 > Loading preloader... 07.08.2012 12:21:48 > Loading preloader... OK 07.08.2012 12:21:48 > Preparing main loader,please wait ... 07.08.2012 12:21:51 > Preparing main loader,please wait ... OK 07.08.2012 12:21:51 > Loading main loader ... 07.08.2012 12:21:53 > Loading main loader ... OK 07.08.2012 12:21:53 > Initialing NAND ... 07.08.2012 12:21:54 > Initialing NAND ... OK 07.08.2012 12:21:54 > Reading security area ... 07.08.2012 12:21:55 > Reading security area ... OK 07.08.2012 12:21:55 > Writing security area ... 07.08.2012 12:21:56 > Writing security area ... OK 07.08.2012 12:21:57 > Reseting phone ... 07.08.2012 12:21:57 > Reseting phone ... OK 07.08.2012 12:21:57 > ======== Process completed ======== 07.08.2012 12:21:57 > Operation time - 00:11 07.08.2012 12:21:58 > Port COM86 disconnected 07.08.2012 12:22:28 > Port COM86 connected 07.08.2012 12:22:30 > Connecting ... 07.08.2012 12:22:31 > Connecting ... OK 07.08.2012 12:22:31 > Connected in NORMAL MODE 07.08.2012 12:22:33 > ---------------------------------------------------------- 07.08.2012 12:22:33 > Phone type selected : KU4000 07.08.2012 12:22:33 > IMEI : 354020-03-405860-2 07.08.2012 12:22:33 > Bluetooth Addr : 00:00:00:00:00:00 07.08.2012 12:22:33 > Phone version : 07.08.2012 12:22:33 > KU400911_M6281A-KLRZ-4.0.9530 07.08.2012 12:22:33 > Compilation info : Feb 10 201012:00:00Aug 05 07.08.2012 12:22:33 > 200805:00:00KU400911 07.08.2012 12:22:33 > Flash ID : 98CA 07.08.2012 12:22:33 > Flash type : toshiba_tya000bc00dogg 07.08.2012 12:22:33 > Flash size : 0CA20000 07.08.2012 12:22:33 > Flash pages count : 00019440 07.08.2012 12:22:33 > Flash page size : 00000800 07.08.2012 12:22:33 > Flash block size : 00020000 07.08.2012 12:22:41 > Port COM86 disconnected |
08-07-2012, 10:00 | #267 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | 07.08.2012 12:48:34 > Software version : SAM_1_28SD.exe 07.08.2012 12:48:34 > ---------------------------------------------------------- 07.08.2012 12:48:34 > For phone connecting do next : 07.08.2012 12:48:34 > - enter "System info" menu in next way : 07.08.2012 12:48:34 > - enter to phone menu 07.08.2012 12:48:34 > - long press "0" till password window will appear 07.08.2012 12:48:34 > - enter password "0821" 07.08.2012 12:48:34 > - select "SIO MODE" 07.08.2012 12:48:34 > - select "Port Map" menu item 07.08.2012 12:48:34 > - set "Diag Monitor" to "USB CDC" value 07.08.2012 12:48:34 > - rest items in this menu set to "NULL DEV" 07.08.2012 12:49:18 > For phone connecting do next : 07.08.2012 12:49:18 > - enter "System info" menu in next way : 07.08.2012 12:49:18 > - enter to phone menu 07.08.2012 12:49:18 > - long press "0" till password window will appear 07.08.2012 12:49:18 > - enter password "0821" 07.08.2012 12:49:18 > - select "SIO MODE" 07.08.2012 12:49:18 > - select "Port Map" menu item 07.08.2012 12:49:18 > - set "Diag Monitor" to "USB CDC" value 07.08.2012 12:49:18 > - rest items in this menu set to "NULL DEV" 07.08.2012 12:49:31 > Port COM39 connected 07.08.2012 12:49:33 > Connecting ... 07.08.2012 12:49:34 > Can't connect phone 07.08.2012 12:49:34 > Operation failed 07.08.2012 12:49:37 > Port COM39 disconnected 07.08.2012 12:49:39 > Port COM39 connected 07.08.2012 12:49:42 > Connecting ... 07.08.2012 12:49:42 > Connecting ... OK 07.08.2012 12:49:42 > Connected in NORMAL MODE 07.08.2012 12:49:42 > ---------------------------------------------------------- 07.08.2012 12:49:42 > Phone type selected : SCH-W930 07.08.2012 12:49:42 > IMEI : 356746-03-344960-2 07.08.2012 12:49:42 > Bluetooth Addr : 8C:71:F8:63:A9:F4 07.08.2012 12:49:42 > Phone version : SAMSUNG Electronics 07.08.2012 12:49:42 > Compilation info : Dec 20 201019:27:30Dec 20 07.08.2012 12:49:42 > 201019:27:30SCH-W930 07.08.2012 12:49:42 > Phone code : 0000 07.08.2012 12:49:44 > ---------------------------------------------------------- 07.08.2012 12:49:44 > Unlocking ... 07.08.2012 12:49:44 > Bypassing NVM security ... 07.08.2012 12:49:44 > Bypassing NVM security ... OK 07.08.2012 12:49:44 > Continue unlocking ... 07.08.2012 12:49:44 > Switching to DL Mode ... 07.08.2012 12:49:49 > Switching to DL Mode ... OK 07.08.2012 12:49:49 > Reading security area ... 07.08.2012 12:49:50 > Reading security area ... OK 07.08.2012 12:49:50 > Seeking patch signature ... 07.08.2012 12:49:57 > Seeking patch signature ... OK 07.08.2012 12:49:57 > Restarting phone ... 07.08.2012 12:49:57 > Restarting phone ... OK 07.08.2012 12:49:57 > Seeking phone, please wait ... 07.08.2012 12:54:10 > Operation failed 07.08.2012 12:54:10 > Restarting phone ... |
08-07-2012, 13:23 | #268 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | 07.08.2012 15:15:59 > Software version : SAM_1_28SD.exe 07.08.2012 15:15:59 > ---------------------------------------------------------- 07.08.2012 15:15:59 > For phone connecting do next : 07.08.2012 15:15:59 > - enter "System info" menu in next way : 07.08.2012 15:15:59 > - enter to phone menu 07.08.2012 15:15:59 > - long press "0" till password window will appear 07.08.2012 15:15:59 > - enter password "0821" 07.08.2012 15:15:59 > - select "SIO MODE" 07.08.2012 15:15:59 > - select "Port Map" menu item 07.08.2012 15:15:59 > - set "Diag Monitor" to "USB CDC" value 07.08.2012 15:15:59 > - rest items in this menu set to "NULL DEV" 07.08.2012 15:16:05 > For phone connecting do next : 07.08.2012 15:16:05 > - enter "System info" menu in next way : 07.08.2012 15:16:05 > - enter to phone menu 07.08.2012 15:16:05 > - long press "0" till password window will appear 07.08.2012 15:16:05 > - enter password "6725" 07.08.2012 15:16:05 > - select "SIO MODE" 07.08.2012 15:16:05 > - select "Port Map" menu item 07.08.2012 15:16:05 > - set "Diag Monitor" to "USB CDC" value 07.08.2012 15:16:05 > - rest items in this menu set to "NULL DEV" 07.08.2012 15:16:11 > Port COM144 connected 07.08.2012 15:16:12 > Connecting ... 07.08.2012 15:16:12 > Connecting ... OK 07.08.2012 15:16:12 > Connected in NORMAL MODE 07.08.2012 15:16:12 > ---------------------------------------------------------- 07.08.2012 15:16:12 > Phone type selected : SCH-W270 07.08.2012 15:16:12 > IMEI : 354903-01-097452-2 07.08.2012 15:16:12 > Bluetooth Addr : 00:1C:43:98:02:BF 07.08.2012 15:16:12 > Phone version : M6275B-KMRZ-3.2.7133 07.08.2012 15:16:12 > Compilation info : Jul 04 200716:21:28Mar 06 07.08.2012 15:16:12 > 200723:00:00SCH-W270 07.08.2012 15:16:12 > Phone code : 9697 07.08.2012 15:16:12 > Flash ID : 9871 07.08.2012 15:16:12 > Flash type : toshiba_tya000bc 07.08.2012 15:16:12 > Flash size : 00D00000 07.08.2012 15:16:12 > Flash pages count : 00006800 07.08.2012 15:16:12 > Flash page size : 00000200 07.08.2012 15:16:12 > Flash block size : 00004000 07.08.2012 15:16:14 > ---------------------------------------------------------- 07.08.2012 15:16:14 > Unlocking ... 07.08.2012 15:16:14 > Unlocking ... OK 07.08.2012 15:16:14 > Restarting phone ... 07.08.2012 15:16:15 > Restarting phone ... OK 07.08.2012 15:16:15 > ======== Process completed ======== 07.08.2012 15:16:15 > Operation time - 00:00 07.08.2012 15:16:15 > Port COM144 disconnected |
08-08-2012, 05:12 | #269 (permalink) |
No Life Poster Join Date: Jul 2002 Location: sri lanka Age: 39
Member: 13932 Status: Offline Sonork: 100.1609876 Thanks Meter: 411 | hone type selected : SCH-W420 IMEI : 358168-01-318700-3 Bluetooth Addr : 00:211:EB:312 Phone version : SAMSUNG Electronics Compilation info : Apr 16 200910:10:34Jan 15 200824:00:00SCH-W420 Phone code : 1234 Connected in NORMAL MODE Flash ID : ECDC Flash type : samsung_kal00e00vm Flash size : 00800000 Flash pages count : 00001000 Flash page size : 00000800 Flash block size : 00020000 ---------------------------------------------------------- Unlocking ... OK Restarting phone ... OK ======== Process completed ======== Operation time - 00:00 |
08-15-2012, 13:10 | #270 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | 09.08.2012 12:40:11 > Software version : LGI_1_95SD.exe 09.08.2012 12:40:11 > ---------------------------------------------------------- 09.08.2012 12:40:18 > Port COM22 connected 09.08.2012 12:40:18 > Port COM22 connected 09.08.2012 12:40:19 > Please power ON phone 09.08.2012 12:40:19 > ---------------------------------------------------------- 09.08.2012 12:40:19 > Loading primary loader ... 09.08.2012 12:40:25 > Operation failed 09.08.2012 12:40:28 > Please power ON phone 09.08.2012 12:40:30 > ---------------------------------------------------------- 09.08.2012 12:40:30 > Loading primary loader ... 09.08.2012 12:40:30 > Loading primary loader ... OK 09.08.2012 12:40:31 > Loading secondary loader ... 09.08.2012 12:40:34 > Loading secondary loader ... OK 09.08.2012 12:40:34 > Loading certificate ... 09.08.2012 12:40:36 > Loading certificate ... OK 09.08.2012 12:40:37 > ---------------------------------------------------------- 09.08.2012 12:40:37 > Reading phone info ... 09.08.2012 12:40:44 > ---------------------------------------------------------- 09.08.2012 12:40:44 > Phone type : LG-GB110 09.08.2012 12:40:44 > Phone IMEI : 359039-02-120152-5 09.08.2012 12:40:44 > Phone version : GB110_V10k 09.08.2012 12:40:44 > Reading phone info ... OK 09.08.2012 12:41:13 > ---------------------------------------------------------- 09.08.2012 12:41:13 > Writing flash from file : 09.08.2012 12:41:13 > LG-GB110_GB110-00-V10c-CIS-XX-JAN-22-2009 09.08.2012 12:41:13 > _EN_RU_UKR_KZ.bin 09.08.2012 12:41:13 > ---------------------------------------------------------- 09.08.2012 12:41:13 > Checking flash file ... 09.08.2012 12:41:13 > Checking flash file ... OK 09.08.2012 12:41:13 > Writing flash ... 09.08.2012 12:54:36 > Writing flash ... OK 09.08.2012 12:54:36 > ======== Process completed ======== 09.08.2012 12:54:36 > Operation time - 0:13:23 |
Upload & Download Eprom | Lousangeles | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-24-1999 05:45 |
