Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > n-Box
Old 03-26-2010, 05:29   #16 (permalink)
MicrostarGSM®'s Avatar
Member: 18855
Thanks Meter: 1,938
24-03.2010 HWK Release UFS_DCTxBB5 v2.0.10.1
The Official release is ready in our download area Welcome to official UFS & HWK Website!
Please run the upgrade client after you have installed the software, follow the instructions careful.
The Update Client is launched after install, if you cancel without making the update, you can run the Update Client again, by selecting the shortcut on the Start Menu:-
Programs\SarasSoft\UFS\Utilities\Update Client
WARNING !!!
If the HWK is a "TRIAL" or affected by 3rd party tools, this software may not work properly, so use at your own risk.
Please make sure you un-install all old versions, first HWK Suite, then HWK Support Suite, you can then install the new software, first HWK Support Suite and then HWK Suite.
You MUST update your HWK using client 2.0.10.0, old client versions will no longer work.
You MUST be running HWK software 2.0.10.0 to access support.
1. RM-392,RM-393 (2680s-2,2680s-2b) v6.17 unlock bug fixed.
2. Box Init bug after BB5 flash fixed.
Do not use external VPP adapter with RX2 enabled cables, since this will put VPP direct to RX2 and its possible to KILL the phone.
HWK_Support_Suite_Setup_v02.0.10.000
HWK_Suite_Setup_v02.0.10.000
HWK_Suite_Setup_v02.0.10.001
Samsung / Qualcomm USB Drivers can be downloaded here:-
N-Box Old Software UFS Suite
Download Here
:: N-box.org - Home ::
GTS-Box.org
The Following 5 Users Say Thank You to MicrostarGSM® For This Useful Post:
Old 04-03-2010, 07:48   #17 (permalink)
Member: 18855
Thanks Meter: 1,938
HWK Release 27/03/2010
WARNING !!!
UFS_SAMs v2.0.10.2
SWIFT-AEROFONE
T239 added (CUNL,FL)
BROADCOM
Fixed UnFreeze Key Display.
HWK_Suite_Setup_v02.0.10.002
Download Here
Download Here
GTS-Box.org
The Following User Says Thank You to MicrostarGSM® For This Useful Post:
Old 04-26-2010, 08:38   #18 (permalink)
Member: 18855
Thanks Meter: 1,938
26-04-2010 (www.N-box.org & www.GTS-box.org) Support Site Update
26-04-2010 (:: N-box.org - Home :: & GTS-Box.org) Support Site Update
Note: For those which have HWK with activation code stick on the hwk module can activate their account at GTS-Box.org
(example: HWK-xxxxxxxxxx) Will Access Full Access Nokia Flash files.
(example: GTS-xxxxxxxxxx) Will Access Full Access Nokia Flash files.
(example: N-BOX-xxxxxxxxxx) Will Access only DCT-4 & DCT-4+ Flash Files
DCT4+ Flash Files & BB5 Flash Files Updates.
GTS-Box.org
Old 05-15-2010, 11:41   #19 (permalink)
Member: 18855
Thanks Meter: 1,938
12-05-2010 Hwk Support Suite v2.0.10.3
WARNING !!!
UFS_SAMs v2.0.10.3
V 2.1.0.3
TRIDENT
M628N added (DUNL,IM,FL)
SWIFT
A256,J218,S3600i,S3601C added (UNL,IM,FL)
SWIFT-3G
B2703 added (CUNL,FL,SECT,BT)
QUALCOMM
A747,C5510,C5510U,T929 UNLOCK and UNFREEZE added.
Improved Decryption algo, more models UNLOCK and
UNFREEZE supported by Default.
BROADCOM
S5230K,S5230R added (CUNL,FL,BRP)
B5310,S5620,S5628,S7070C added (FL)
Use Samsung Kies drivers for these models (B5310,S562x)
Fixed 'Cannot Find NandInfo !' on some models.
COMMON
Log to file fixed for Trident models.
Introduced New Extremely Fast Key Calculation Algorithm (DHLT)
Need few hours for Tables generation at First Software startup.
But after, Key calculation for Qualcomm, Broadcom and Trident
platforms will take few seconds. DHLT (c)SarasSoft.
HWK_Suite_Setup_v02.0.10.003
Users who not want to wait few hours for DHLT table generation can download the files from our Official Rapidshare mirror. The files should be placed into x:\Program Files\SarasSoft\UFS\UFS_SAMs\_DHT
_DHT Part1 _DHT Part1
_DHT Part2 _DHT Part2
_DHT Part3 _DHT Part3
_DHT Part4 _DHT Part4
_DHT Part5 _DHT Part5
_DHT Part6 _DHT Part6
Download Here
Download Here
GTS-Box.org
Old 07-09-2010, 07:57   #20 (permalink)
Member: 18855
Thanks Meter: 1,938
06-07-2010 Hwk Support Suite v2.0.10.4
WARNING !!!
LG GSM V 2.0.10.4
1. Infineon GB107,GB108,GB115,GS100,GS101,GS102,GS105,
GS106,GS107,GS108,KG289,KP109 added.
UFS_SAMs v2.0.10.4
TRIDENT VISION
B3210M added.
Bug in E2P Filename Display fixed.
OM(SYSOL)
On the Fly E2P Patch added to keep Original IMEI number.
SWIFT
C3212i added(UNL,IM,FL)
SWIFT-AEROFONE
E1080i,E1086,E1086L,E1170,T139 added (CUNL,PUNL,PIM,FL)
On the Fly MCU Patch added to bypass MSL security for MSL3
(MSLC16) products (E1080,E1080i,E1086,E1150,E1160, ...)
after is possible Direct Unlock, Rebuild IMEI in normal way.
QUALCOMM
S3370,S5350M added (FL,CUNL,UNFR)
S5350 added (CUNL,UNFR)
Increased Speed in Communications (NVM Read/Write, RAM Read)
BROADCOM
B5310U added (FL)
i6230,S3653M added (CUNL,FL,BRP)
Combo Cable (USB+RJ45) Support added, not need Manipulations
with Cable when use [QCDI Info]
Corrected CSC,APP,PFS flashing for BCM2153 platform (B5310,..)
[Boot Change] Product will Restart after success Boot Change,
if Failed, will stay in Download Mode to Allow Retry.
[Full Download] will Write All without Restart after Boot Change.
COMMON
[Refresh] will Show Avalaible Ports List with Full Names.
HWK_Suite_Setup_v02.0.10.004
Download Here
Download Here
GTS-Box.org
The Following 2 Users Say Thank You to MicrostarGSM® For This Useful Post:
Old 10-26-2010, 07:03   #21 (permalink)
Member: 18855
Thanks Meter: 1,938
WARNING !!!
UFS_SAMs v2.0.10.5
TRIDENT VISION
M2513 added (UNL,CUNL,IM,FL)
SWIFT
Added MCU_Id and Type Display.
Increased Preloader boot speed.
QUALCOMM
More Versions Support of Hidden Sysinfo models CUNL (S3370,..)
A877,M7600H,M8800H,S5603T,S7120H,S8300T added.
QUALCOMM+LSI
M8910,M8910B,M8910H,M8910U,S8000,S8000B,S8000C,S80 00H,S8000U,
S8003,S8500,S8500C added (FL)
BROADCOM
C3510T,M3710,S5560H added (FL)
S3650H,S5230C added (FL,CUNL,UNFR,BRP)
INFINEON
Infineon Platform Introduced, See on [Sky/INF] Tab.
E1151 added (CUNL,FL)
DHLT Engine will ask about additional DHLT tables generation.
COMMON
[Refresh] will Auto Select Ports, be sure that Right Model
and Mode is Selected (Untick [QualComm mode] when Flashing !)
Users who not want to wait few hours for 3rd DHLT table generation can download the files from our Official Rapidshare mirror. The files should be placed into x:\Program Files\SarasSoft\UFS\UFS_SAMs\_DHT
HWK_Suite_Setup_v02.0.10.005a
Download Here
Download Here
GTS-Box.org
Old 10-26-2010, 07:20   #22 (permalink)
Member: 18855
Thanks Meter: 1,938
WARNING !!!
LG_GSM v 2.1.0.6 (HWK Required)
1. Added NSCK,SPCK,CCK,SIM codes Display for GS10x
UFS_SAMs v2.0.10.6
TRIDENT
X427 added (DUNL,IM,FL)
TRIDENT VISION
M2520 added (UNL,CUNL,IM,FL)
Display of USER LOCK Key for All Models.
SWIFT
E2550,E2550D,E2558 added (UNL,SECT,IM)
Notes:
1.Chinese Versions E2550Zxxx select as E2558 for UNL,SECT,IM.
2.E255x PRAM Flashing not Supported yet, use Original Flasher.
B3410C,E2510C,S5050C added (UNL,IM,FL)
Note: Chinese Versions B3410Zxxx select as B3410C.
SWIFT-AEROFONE
C3300D,C3300K,C3303,C3303K added (UNL,SECT,IM,FL) use 530Kom Cable.
E1107-DX,E1107L,E1117-MEA-IND,E1130,E1130B,E1150-MEA-SEA,E1153,
E1160-DX,E1220,E2120i,E2120L,E2121,E1252,E2121B,E2210T,E 2152,
E2370 added (CUNL,PUNL,PIM,FL)
Note: Mixing of DX MEA SEA Models causes Blinking or Dead Sets.
[Restart] Button now Exit TAT mode with Battery.
Auto Exit from TAT Mode when Flashing, not need
Cable or Battery Reconnect after UI functions (Info,IM,..)
SWIFT-3G
J808,S5550,S5550U added (CUNL,SECT,FL)
B7722,B7732 DUOS added (CUNL,SECT,FL) Flashing only Master Part.
C3630C,C3730C,S3930C TD-SCDMA added (FL) use 530Kom Cable.
QUALCOMM
A657,A887,A897,M7600L,S5530,T559 added.
BROADCOM
A697,B3410W added (FL,CUNL,UNFR,BRP)
S5250,S5253,S530,S5333 added (FL)
Boot Repair Enabled for All Broadcom models, use 530Kom Cable.
Some Models have encrypted Boot2.img and don't have uart_boot,
for these models use our released Boot_Repair packs.
Note: S562x with OneNand Flash Chip, Cannot be Repaired.
Added Unlock support(CUNL) for Hidden Sysinfo models (S5560,..)
if have no succes in SysInfo search, need ReFlash, to have untrashed FS
COMMON
Reduced/Full Log of TFS file list progress for OM/Swift.
Improved FileOpen dialog, to Override suggested path
to last used on same model.
Used Abbrevations List can be seen at the Bottom of this page.
DOCUMENTS
Samsung B7722 How to Rev.1
Samsung C3300_C3303 How to Rev.1
Samsung S523x Warning Rev.1
Samsung S7070 How to Rev.1
Samsung Swift-Aerofone MSL3 Models How to Rev.1
Many thanks to all those who have supported us!!!
HWK_Suite_Setup_v02.0.10.006
Download Here
Download Here
GTS-Box.org
Old 11-04-2010, 10:56   #23 (permalink)
Member: 18855
Thanks Meter: 1,938
UFS_SAMs v2.0.10.7
SWIFT-AEROFONE
E2152 FULL, _RD, E2P Write Bug Fixed.
Note: E2152 DX Firmwares cannot be Properly Flashed.
QUALCOMM
B2710,S3370E added.
QUALCOMM+LSI
S8000L added (FL)
BROADCOM
S5620B,S5628i added (FL)
COMMON
HWK_Suite_Setup_v02.0.10.007
Download Here
Download Here
GTS-Box.org
Old 05-23-2011, 10:58   #24 (permalink)
Member: 18855
Thanks Meter: 1,938
HWK Release 22/05/2011 Release Date: 22/05/2011
The Official release is ready in our download area http://sarunasoftware.com
WARNING !!!
You MUST update your HWK using client 2.2.0.0, old client versions will no longer work.
You MUST be running HWK software 2.2.0.0 to access support.
DCTxBB5 V 2.2.0.0
1. BB5 products: RM-576,RM-577 (6700s,6700s-1c) added.
2. Local RPL Service Fixed for ASIC 2,5,6,7,11 (UEM_PASW is Correct now)
Note: Need Confirm [Readout and Use UEM IMEI] when do [Rd UEM].
3. [Check Ask/Rpl] Renamed to [Calc Ask/Rpl] as can Calculate RPL now.
4. [Calc Ask/Rpl] Function will Generate Real RPL from ASK file (ASIC 2,5,6,7,11)
Note: When Reading UEM, do not Forget Set Right [UEM Changed] Status !
5. RSA Lock/Unlock for All DCT4+ products (not need Patch)
6. Life Timer added to [PM Edit]
7. DCT4 INFINEON Based Products USB Flashing / UI support added:
RH-111,RH-125,RH-126,RM-607,RM-608,RM-643,RM-644,RM-647,RM-653,
RM-669,RM-689,RM-704,RM-732,RM-733 (1202,1616-2,1616-2b,C1-01,C1-01.1,
C1-02,C1-02.1,1280,1800,1800b,C1-00,C2-00,X1-00,X1-00.1)
8. BB5 RAP3Gv40 Based Products USB Flashing / UI support added:
RM-509,RM-510,RM-511,RM-540,RM-598,RM-604,RM-615,RM-638,RM-721,RM-722
(3710a-1,3710a-1c,3711a-1,X3-00,7230-1c,7230-1,5330-1d,6303ci,C2-01,C2-01.5)
9. BB5 RAPU Based Products USB Flashing / UI support added:
RM-582,RM-596,RM-601,RM-609,RM-610,RM-627,RM-629,RM-632,RM-634,
RM-639,RM-640,RM-645,RM-648,RM-658,RM-659,RM-662,RM-675,RM-682,
RM-688,RM-691,RM-697,RM-699,RM-707,RM-718,RM-719,RM-720,RM-749
(Vertu CQ,N8-00,C6-01,E6-00,E6-00.1,X5-01,5230-1d,E5-00,E5-00.2,X3-02,C3-01,
C5-00.X5-01.2,E73,X7-00.1,C3-01m,C7-00,6702s,C5-00.1,C7-00b,C5-03,E5-00m,
X7-00,C6-01.3,C5-03.2,C5-04.1,C7-00s)
10.BB5 RAPIDO Based Products USB Flashing / UI support added:
RM-484,RM-485,RM-486,RM-551,RM-552,RM-559,RM-588,RM-593,RM-594,
RM-612,RM-624,RM-625,RM-684
(N86-1,N86-3,N86-5,X6-00.1,X6-00m,X6-00,5230-1,5230-1c,5230-1b,C6-00,
C6-00.1,5288,5250)
11.BB5 JUNO (BCM21351) Based Products USB Flashing / UI support added:
RM-497,RM-586,RM-614,RM-618,RM-709,RM717
(7020a-2,2710c-2,C3-00,X2-00,X2-01,X2-01.1)
12.Original SX4 Card Support Added (Use Any PCSC Compatible Card Reader)
LG_GSM v 2.2.0.0
1. Infineon:
A110,A130,A133,A133GO,A170,A180,C100,C105,C300,C30 0GO,C305,
C310,GB220,GB220nGO,GB230,GB280,GD350,GD510,GD510N ,GM360,
GM360i,GM600,GS170,GS290,GS290GO,GS290N,GS390GO,GS 500,GS500g,
GS500gx,GS500v,GT350,GT350GO,GT350i,GT360,GT365,GU 220,GU230,
KC550,KC550d,KF510,KF510d,KF600,KF600d,KM380,KM380 c,KM380d,
KM385d,KM386c,KP500,KP500N,KP501,KP502,KP502GO,KP5 05,KP550,
KP570q,KS360,KS365,T300,T310,T310i,T310N,T315,T315 i,T320,
T320e,T320g,T325 added.
Notes:
1. To See Unlock Codes and Instructions, Press [BOOT]
2. To Flash Dead Phones, Tick [Emerg. Boot]
3. FLS and BIN files supported for Flashing.
2. USB Support for Infineon SGOLD3, SGOLDRADIO, XGOLD213.
Note: To use USB Select USB in [Baud] ComboBox.
3. ADI: G210,G220,G232,G233,G259,G262,G263,G610,G622,G632, G635,
G639,G660,G672,G677,C682,G688,G810,G822,G828,G912, GM200,GM205,
GM205GO,GM210,KF245,KG296,LG8930,MG235,MG295,MG296 added.
4. TI: C1300i,C2000,G850,L1400i,MG191a,MG191b,MG200c,MG20 0d added.
5. MTK: A120,A155,A160,A165,GB160a,GB160b,GB161,GB190a,GB2 70,
GS190,GS200,GS205 added.
6. BT Address Write Added for ADI, Infineon and MTK platforms.
SAMs V 2.2.0.0
TRIDENT
A127,i626,T719,X475 added (DUNL,IM,FL)
OM(SYSOL)
T209,T319 added (DUNL,IM,FL,SECT)
SWIFT
A436,A437,A516,A517,T229,T249,T339,T349-LTA-USA,T369,
T409,T619,T739 added (DUNL,IM,SECT,FL)
Added Multi Drive support for TFS Read.
Fixed SLAVE Boot Bug on some models (D980,D980F,D988)
TFS Extractor and TFS Builder added, Allows to Edit TFS files.
SWIFT-AEROFONE
Added [Patch MSL] Function to Patch without MCU Part Flashing.
C3300i,T109,T119 added (DUNL,IM,FL)
E1050,E1055G,E1055T,E1080F-IND-MEA-SEA,E1080W,
E1081T-EU-IND-MEA-SEA,E1083C,E1085F,E1085F-MEA,E1087T,E1105F,
E1150i,E1160i,E1170i,E1170T,E1172,E1175T-EU-IND,E1178,E1225F,
E1225T,E1225T-IND,E2121L added (PUNL,PIM,FL)
Notes:
1.Mixing of EU IND MEA SEA Files causes Blinking or Dead Sets.
2.E1081T EU E2P Image is not Compatible with IND, MEA or SEA.
3.For Cross Flashing Select Model Name Extension by File type.
4.Before Unlock, Info to see Codes or Rebuild IMEI use
[Patch MSL] Button or Flash with [Patch MSL] Option Enabled.
C3222,C3222W added (DUNL,CUNL)
Note: C3222 Flashing not Supported yet, use Original Flasher.
SWIFT-3G
C5010E,E3210 added (CUNL,SECT,FL)
QUALCOMM
A597,A847,A927,B2710D,C5180,S5520,S5580,S6700T,S68 88,T359,T479,
T746,T749 added.
More Versions Support of Hidden Sysinfo models CUNL and UNFR:
A597,A706,A707,A717,A727,A847,A887,A897,A927,B2710 ,B2710D,S3370,
S5530,T359,T469,T479,T559,T659,T746,T749
QUALCOMM+LSI
S8500B,S8530 added (FL)
BROADCOM
S5230N added (FL,CUNL,UNFR,BRP)
S3850,S5260,S5263,S5330L,S5560i,S5750E,S5753E,S723 0B,S7230E,
S7230W,S7233E added (FL)
S5250,S5253,S5330,S5330L,S5333 Boot Repair (BRP)
[QCDI Info] Renamed to [BCMBL Info] for BroadCom Models.
INFINEON
B3310i,C3200,C3200G,C3200L,C3530,C3530L,E2230,E223 0M,E2232,
E2330,E2330B,E2330C,E2530,E2652,E2652W,S3310i,S335 0,S3353,
S3550,S3550C,S3550L added (CUNL,PUNL,PIM,FL,UFL)
Note: for USB Flashing select 'USB0' in [BaudRate] box.
E1151, Now Possible to Flash Read BIN Dump (Size: 007F0000)
HWK_Support_Suite_Setup_v02.20.0.000
HWK_Major_Suite_Setup_v02.20.0.000(FULL)
HWK_Major_Suite_Setup_v02.20.0.000 (FULL)
HWK_Major_Suite_Setup_v02.20.0.000 (PART 1)
HWK_Major_Suite_Setup_v02.20.0.000 (PART 2)
HWK_Major_Suite_Setup_v02.20.0.000 (PART 3)
HWK_Major_Suite_Setup_v02.20.0.000 (PART 4)
HWK_Major_Suite_Setup_v02.20.0.000 (PART 5)
HWK_Major_Suite_Setup_v02.20.0.000 (PART 6)
HWK_Major_Suite_Setup_v02.20.0.000 (PART 7)
HWK_Major_Suite_Setup_v02.20.0.000 (PART 8)
HWK_Major_Suite_Setup_v02.20.0.000 (PART 9)
HWK_Major_Suite_Setup_v02.20.0.000 (PART 10 - Last Part)
★★DHT1 & 2 - Extract to x:\Program Files\SarasSoft\UFS\UFS_SAMs\_DHT
Download _DHT.part01.rar
Download _DHT.part02.rar
Download _DHT.part03.rar
Download _DHT.part04.rar
Download _DHT.part05.rar
Download _DHT.part06.rar
★★★DHT3 - Extract to x:\Program Files\SarasSoft\UFS\UFS_SAMs\_DHT
Download _DHT3.part1.rar
Download _DHT3.part2.rar
Download _DHT3.part3.rar
HWK Old Version 2.1.0.00
HWK_Support_Suite_Setup_v02.10.000
HWK_Suite_Setup_v02.10.000
HWK_Suite_Minor_v02.10.001
HWK_Suite_Minor_v02.10.002
HWK_Suite_Minor_v2.10.003
HWK_Suite_Minor_v02.10.004
HWK_Suite_Minor_v02.10.005a
HWK_Suite_Minor_v02.10.006
HWK_Suite_Minor_v02.10.007
Download Here
GTS-Box.org
The Following 6 Users Say Thank You to MicrostarGSM® For This Useful Post:
Old 07-11-2011, 07:11   #25 (permalink)
Member: 18855
Thanks Meter: 1,938
04-07-2011 HWK Minor Release 2.2.0.1
HWK Release 04/07/2011 Release Date: 04/07/2011
WARNING !!!
You MUST be running HWK software 2.2.0.1 to access support.
Since this is a minor update release, there is no need to update your HWK if you have already updated on the v2.2.0.0 release.
DCTxBB5 V 2.2.0.1
1. DCT4+ ASIC2 Unlock Bug Fixed
(RH-92,RH-93,RH-94,RH-95,RM-189,RM-190,RM-225)
2. Wrong Locks Status Indicator Fixed (RH-86,RH-87)
3. Detail Description Message on Bad VPL File Exception.
4. BB5 RAPU Based Products USB Flashing / UI support added:
RM-744,RM-745,RM-775 (C5-00.3,C5-00.2,X3-02.5)
LG_GSM v 2.2.0.1
1. Infineon:
A100,A100a,A175,A175a,A175b,A180a,A180b,GB102GO,GB 105a,
GB107a,GB125a,GB126a,GS101a,GS101GO,GS107a,GS107b, GS117,
GS155,GS155a,GS155b,GS500f,GU200,GU200a,GU200b,KF5 10c,
KF600c,KF600d,KM570,KM570f,KP105a,KP106a,KP106b,KP 107a,
KP107b,T325g,TE350GO added.
2. ADI:
KP115a,KP130b,KP215a,KP260c,KP265d added.
SAMs V 2.2.0.1
SWIFT
Some DUOS models Slave Boot bug Fixed.
SWIFT-AEROFONE
E1050,E1055T,E1080W,E1170i E2P Size Fixed.
Max Section Size Increased.
E1182 added (DUNL,PUNL,PIM,FL)
C3303i,C3322,C3500 added (CUNL,DUNL,IM,SECT,E2P)
Note:
C3322,C3500 TFS and CSC Flashing not Supported yet,
SWIFT-3G
C5010B added (CUNL,SECT,FL)
QUALCOMM
A885,A886,F406,S3370B,S3370L added.
INFINEON
E2652,E2652W USB Flahing bug Fixed.
E2152i added (CUNL,PUNL,PIM,FL,UFL)
XGOLD213 BIF file Write bug fixed.
XGOLD213 Patch bug fixed.
BROADCOM
B5310R,C6712,S3853,S5250W added (UFL)
COMMON
HWK_Suite_Minor_v02.2.0.1
Download Here
GTS-Box.org
Old 08-23-2011, 06:59   #26 (permalink)
Member: 18855
Thanks Meter: 1,938
HWK Release 22/08/2011 Release Date: 22/08/2011
WARNING !!!
DCTxBB5 V 2.2.0.2
1. BB5 RAPU Based Products USB Flashing / UI support added:
RM-776 (C3-01.5)
2. DCT4 INFINEON Based Products USB Flashing / UI support added:
RM-692,RM-693,RM-702,RM-713 (C2-02,C2-02.1,C2-03,X1-01)
LG_GSM v 2.2.0.2
1. Infineon:
A108,A190,A190a,A190b,A210,A210b,GB125R,GC900fGO,G T350f,
KS360GO added.
2. EGV V3-32 and EGV V3-64 Direct Unlock and IMEI enable added.
Note: Use [Unlock] before IMEI rebuild.
3. EGV V3-64 new Flash Chips Support.
SAMs V 2.2.0.2
TRIDENT VISION
<CODE CORRUPTED> for non 8 Digits PCK Fixed.
SWIFT-AEROFONE
E1050-CHN,E1050V,E1086i,E1150-CHN,E1155L,E1180,E1190,E1220i
added (PUNL,PIM,FL)
E1182L added (DUNL,PUNL,PIM,FL)
E1225T,E1182 TFS Flashing bug Fixed.
C3322 Unlock, IMEI, Sections bug Fixed.
B7722,B7732 Slave Part Flashing/Read/E2P added.
QUALCOMM
T669 Added.
INFINEON
C3011,C3560,C3750,C3752 added (CUNL,PUNL,PIM,FL,UFL)
E2232 Flashing bug Fixed.
HWK_Suite_Minor_v02.2.0.2
Download Here
GTS-Box.org
Old 11-06-2011, 11:59   #27 (permalink)
Member: 18855
Thanks Meter: 1,938
06-11-2011 Hwk Minor Suite v2.2.0.3
HWK Release 06/11/2011 Release Date: 06/11/2011
WARNING !!!
DCTxBB5 V 2.2.0.3
RM-670,RM-679,RM-681V,RM-701,RM-730,RM-750,RM-763,RM-774,RM-779,
RM-781,RM-814,RM-815,RM-816
(700,T7-00,Vertu Con.T,600,702T,500,303,701,603,300,C5-08,C5-05,C5-06)
2. DCT4 INFINEON Based Products Flashing / UI support added:
RH-130,RH-131,RM-724,RM-725,RM-769 (100,100.1,C2-05,C2-05.1,101)
3. Vertu products names changed to RM-582V, RM-681V to keep compatibility
with DataPackageManager application.
4. New Flashloaders included.
5. Fixed BSOD bug on W7 x64 when Connect Box.
LG_GSM v 2.2.0.3
1. Infineon:
A190,A190a,A190b Read Lock Keys, Unlock, Dual IMEI Fixed.
2. Infineon EgoldVoice64_ULC2:
KG370,KG375,KG376,MG370a,MG370b added (FL,CUL,DUL,IM)
3. Infineon XMM2130: LG500G,LG800G added (FL)
4. Infineon XMM2150:
A200,A225,A230,A250,A255,A258,C330,T500,T505,T510, T515,
T530 added (FL,DUL)
S365 added (FL,CUL,DUL,IM)
SAMs V 2.2.0.3
SWIFT-AEROFONE
E1080T-SEA,E1175T-MEA,E1190-CHN,E1195,E1195-CHN,E1230
added (PUNL,PIM,FL)
E1055G info/unlock bug fixed.
xx-DX models renamed to xx-SEA (note: DD is IND not SEA)
E2222 (UNL,SECT,IM)
SWIFT-3G
(CUNL,SECT) fixed for C3630C,C3730C,S3930C
E3213K,i6320C,i6330C,S3710,S3770,S3778,S3830U,S561 0,
S5610K,S5630C added (CUNL,SECT,FL)
INFINEON
IMEI2 Rebuild added for DUOS models.
Minor bugs in AT protocol fixed:
(not read Codes and IMEI Rebuild fails on some models)
Notes:
Some S3550 units stucks on DFFS (CSC) Flashing,
Solution: Untick [Use EBL from FLS Pack] CheckBox.
COMMON
HWK_Suite_Minor_v02.2.0.3
Download Here
GTS-Box.org
24.03.2010 SagemEG_V14.8 released Oxo_Boxo SAGEM JTAG UNLOCKER 12 04-30-2010 19:47
need Hwk Support Suite v2.0.10.1 nepoleanl n-Box 7 04-26-2010 12:06
HWK Release 24/03/2010 Odia The Ultimate Service Products News & Updates 0 03-24-2010 23:04
24.03.2010 SagemEG_V14.8 released Oxo_Boxo Service Products News & Updates 0 03-24-2010 13:26
Help Me. Can v use JAF 7-Pin Cables in Hwk Suite v2.0.6.0 & In Original UFSxHwk Box? gsm_surya HWK 18 12-25-2007 10:53
Page generated in 0.41083 seconds with 10 queries
