11-01-2007, 10:16 | #1 (permalink) |
Freak Poster Join Date: Dec 2005 Location: Chennai, Tamilnadu, India
Member: 205776 Status: Offline Thanks Meter: 53 | Help Me. Can v use JAF 7-Pin Cables in Hwk Suite v2.0.6.0 & In Original UFSxHwk Box? |
11-01-2007, 10:46 | #2 (permalink) | |
Cheater -Don't Deal with him- Join Date: Jan 2002 Age: 48
Member: 8879 Status: Offline Sonork: 100.84016 Thanks Meter: 327 | Quote:
Yes, this has already been covered by Odia! Now it is ok to use 5pin and 7pin for HWK! | |
11-01-2007, 10:47 | #3 (permalink) | |
Freak Poster Join Date: Mar 2007 Age: 51
Member: 459838 Status: Offline Thanks Meter: 0 | brother Quote:
please note what product soporter says.... UFS_DCTxBB5 v2.0.6 -------------------- 1. Dual Line flashing for BB5 introduced (Required UFS firmware V2.8 2007) 2. All avalaible phones supported (including RAPIDO v1.12, v1.13) 3. "Verify" function for BB5 added. 4. Latest Flash Update pack (7.40.35.29728) supported. 5. Support of Muxed Nand. Do not use external VPP adapter with RX2 enabled cables, since this will put VPP direct to RX2 and its possible to KILL the phone. This has always been the case with 7 pin cables, but from this release 7 pin cables are supported by UFS+HWK. http:///vbb/...=442589&page=2 | |
11-02-2007, 06:52 | #7 (permalink) | |
No Life Poster Join Date: Apr 2001 Location: Where dreams become reality. Age: 54
Member: 4042 Status: Offline Thanks Meter: 24,043 | Quote:
Odia. | |
11-02-2007, 11:26 | #8 (permalink) |
Junior Member Join Date: Dec 2002 Age: 45
Member: 18346 Status: Offline Thanks Meter: 0 | @Odia Thanks, I have more question. 1. What if I will not upgrade my ufs firmware (stick with v2.6) and just use the latest Hwk Software and 5 pins cable? Is is safe to flash BB5 phones? 2. I will upgrade my firmware to latest v2.8, does 5 pins cable still ok to flash BB5 phones? 3. Do I need to use the VPP adaptor when using 5 pins cable? |
11-02-2007, 14:05 | #9 (permalink) | ||
With the later phones (new NAND type) these is no need for external VPP. Odia. | ||
11-02-2007, 21:05 | #10 (permalink) |
Freak Poster Join Date: Apr 2005 Age: 44
Member: 142161 Status: Offline Thanks Meter: 8 | Many thanks to Odia for clarifying those important questions. As I can see in all forums there is a lot of dudes about flashing BB5 phones. Mostly becouse of we are not sure about what cable to use for each BB5 phone. Odia, you should pain attention to this. Maybe it's time to update you "UFSx Cable Schemas". Whe need to know what cable whe can use for each BB5 phone. I'm sure you will get all the help you need from your customers in the forum. Resuming your answers (Correct me, please): --- Would not advise this. --- It’s important to update UFS firmware and use the latest HWK software to flash BB5 phones to reduce phone damage and increase the BB5 phone supported for flashing.--- Some phones need dual-line to flash, so long as you dont want to flash the latest models all will be ok. NOTE make sure dual-line is not ticked when using single RX cables. --- With the later phones (new NAND type) these is no need for external VPP. --- We can classify the BB5 phones in 2 groups (if we want to flash them): single-line phones (older BB5) and dual-line phones (newest BB5)Please Odia, be more specific about: what phone are sinlge-line or dual-line, in what single-line phones you have to use external VPP, what's the resistor values in BSI lines for each BB5 phones, etc. Thanks in advance. |
11-02-2007, 21:46 | #11 (permalink) |
No Life Poster Join Date: Dec 2005 Location: In My Dreams
Member: 210304 Status: Offline Sonork: 100.1573283 Thanks Meter: 1,455 | I HAVE problem With p-key when opening jaf useing ufsx interface IT'S ONLY SAY I THINK problem WITH latest firmware latest v2.8 |
11-03-2007, 03:46 | #13 (permalink) | |
Again with resistor values, this is dependant on the phones firmware version, for example you can have a 6630 at version 3 which will enter all modes without issue local, test and normal, but then you flash to version 5 and you get local mode failed, this is because the BSI threshold was changed on the later flash version, 3.3k will work on old, but now new, 5.1k will work on new or old, but still this resistor value is dependant on the phone type can be between >5.0k <10.1k (suggested values being 3.3k, 5.1k, 7.5k and 10k) Odia. | |
11-03-2007, 11:16 | #14 (permalink) |
Member: 18346 Status: Offline Thanks Meter: 0 | About Dual Line 1.Since we don't know which phone needs dual line, is it ok If I try first not ticking the dual line, then If I fail in erase, then I should try in dual line? 2. What if the phone doesn't need dual line but I tick it, does it have a irreversible effect in phone? |
11-04-2007, 04:43 | #15 (permalink) | ||
Odia. | ||
bb5 jaf 7 pin cable schemtic and pinouts here | gilani4_all | Nokia Base Band 5 ( BB-5 ) | 8 | 04-07-2010 23:56 |
Help me please. I use JAF (Thomus) sx4 problem. | ratthaphon1 | J.A.F. By Jafsupport.com | 1 | 01-13-2009 19:19 |
HWK 2.0.6.0 , 7 Pin cable - How to init local mode ? | FreeMaind_next | HWK | 14 | 05-27-2008 15:37 |
error in update hwk v2.0.6.0 for v2.0.7.0 | cariocacelular | HWK | 2 | 03-27-2008 10:13 |
