02-22-2010, 14:48 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: *P*A*K*I*S*T*A*N
Member: 391445 Status: Offline Sonork: 100.1583575 Thanks Meter: 392 | :::can some one help me with this i780::: Any one can tell how can i reset this device or enter the unlock code NSPRO unlocked this phone and in GET INFO says 01234567 is the code But when the timer ends it says only emergency calls can be made |
02-22-2010, 15:28 | #2 (permalink) |
No Life Poster Join Date: Oct 2008 Location: WHERE THE WORLD ENDS
Member: 885625 Status: Offline Sonork: 100.1589108 Thanks Meter: 2,432 | TRY DOING A HARD RESET OF DEVICE. 1. Turn off the phone. 2. Hold red and green butoon and press the stylus inside the reset hole, when the red light on release the stylus at once but keep the other keys pressed. 3. You will get now the menu to format. REGARDS SUUNNYY |
The Following User Says Thank You to SUUNNYY For This Useful Post: |
02-22-2010, 16:10 | #3 (permalink) |
Member: 391445 Status: Offline Sonork: 100.1583575 Thanks Meter: 392 | I have tried hard reset but that sequence do not help !!! I am unable to enter format screen is there a complete sequence to do hard reset ? please guide me if there is something like this ? |
02-22-2010, 16:30 | #5 (permalink) | ||
Member: 885625 Status: Offline Sonork: 100.1589108 Thanks Meter: 2,432 | Quote:
LOOK THIS VIDEO http://www.youtube.com/watch?v=U9jsXdEfFkU WILL HELP YOU TO DO HARD RESET. REGARDS SUUNNYY | ||
02-22-2010, 16:38 | #6 (permalink) |
Member: 391445 Status: Offline Sonork: 100.1583575 Thanks Meter: 392 | already seen this video but still same i cant do should the phone be on stand by then i should press the 2 buttons then reset the hole ? |
02-22-2010, 16:43 | #7 (permalink) | |
1. Power off the phone----- YES POWER OFF PHONE 2. Hold down the begin call and end call buttons (green & red) 3. Press and hold the power button-----NOW PRESS POWER BUTTON 4. Once the phone’s status LED turns red, “RELEASE” the power button but KEEP the other 2 pushed------Very important to do this !!!!! 5. You will get a prompt to press the space key to format, or any other key to continue. I THINK ITS ALL CLEAR NOW. REGARDS SUUNNYY | |
02-22-2010, 17:02 | #11 (permalink) |
Member: 391445 Status: Offline Sonork: 100.1583575 Thanks Meter: 392 | i just can't i don't know why? the buttons are working fine but i can't just reset my device I know i am doing exactly as you are but no success |
02-22-2010, 17:26 | #12 (permalink) |
Freak Poster Join Date: May 2004 Location: Dream
Member: 64496 Status: Offline Thanks Meter: 76 | try flashing use mirage for remove user code lock here guide for flashing http://rapidshare.com/files/22818959...hing_Guide.pdf if phone wm6.1 just flashing PDA use i780_WM6.1_EFNV3.0.Bin http://rapidshare.com/files/13245775...NV3.0.rar.html and your lock can remove |
can any one help me with this error | hacker1gsm | Genie Universal | 2 | 01-21-2010 14:19 |
can any one help me with this | .::Naseer Al-islam::. | HWK | 5 | 01-19-2009 08:04 |
Can any one help me with this problem. | cell dog | BlackBerry (RIM) | 2 | 08-20-2008 03:37 |
Can some one help me with explaination | doc_j | Sim Cloning and Scaning | 2 | 01-12-2008 18:49 |
