07-25-2008, 11:59 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Skopje, Macedonia Age: 36
Member: 472933 Status: Offline Sonork: 100.1590967 Thanks Meter: 1,331 | E570 after flash imei - 00000000000000, BT - FFFFFF-FFFFFF when i try to write new imei i give this error: Entering Test mode... Checking Security Type... MSL Security Detected!!! Calculating MSL... Operation failed! where can i find eeprom or special imei repair files for this samsung? before flashing phone don't remmember last dialed numbers, but it's have imei :/ |
The Following User Says Thank You to Boshko_Alfa For This Useful Post: |
07-25-2008, 12:30 | #3 (permalink) |
Member: 472933 Status: Offline Sonork: 100.1590967 Thanks Meter: 1,331 | in c400 mode no result: Entering Test mode... Checking Security Type... Bypasing MSL Security... Operation failed! |
07-25-2008, 12:50 | #5 (permalink) |
Member: 472933 Status: Offline Sonork: 100.1590967 Thanks Meter: 1,331 | yes, yes... i select C400 on ns pro, connect the phone with battery and type 3333333333333 on tab with imei write. result is: Entering Test mode... Checking Security Type... Bypasing MSL Security... Operation failed! then go to e570 and type imei 352997014970140 and log is: Entering Test mode... Checking Security Type... Bypasing MSL Security... Operation failed! |
07-26-2008, 19:51 | #8 (permalink) |
Member: 472933 Status: Offline Sonork: 100.1590967 Thanks Meter: 1,331 | khm... i have 1 problem with my box always when i start up the program get this: i try to uninstal complete NS pro, delete ns pro folder in program files and instal from begin, try with switch off firewall protection but without any result |
07-26-2008, 20:12 | #9 (permalink) |
No Life Poster Join Date: Sep 2007 Location: iran-shushtar
Member: 592636 Status: Offline Thanks Meter: 674 | my brother t had sam poroblem 4 u 600 i instal ns 4.2 then select c400 write orginal imei then ok go select u600 and chengh imei best regurd elco best samaung tool nspro |
07-26-2008, 20:13 | #10 (permalink) |
07-26-2008, 21:45 | #11 (permalink) | |
No Life Poster Join Date: Dec 2002 Location: Romania
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | Quote:
Allow from firewall to nspro to connect to internet. | |
M620 after flash ,imei 00000000000000 | dominik1 | NSPRO | 9 | 12-29-2008 22:50 |
E900 after flash imei (00000000000000) .. BT ( FFFFFFFFFFFF) | bimen | NSPRO | 6 | 07-26-2008 23:15 |
N-Gage: after flash Imei ???????????? | Essential GSM | Griffin | 2 | 06-04-2004 18:30 |
