07-26-2008, 17:31 | #1 (permalink) |
Registered User Join Date: Jul 2007 Location: in the world Age: 40
Member: 550472 Status: Offline Thanks Meter: 6 | E900 after flash imei (00000000000000) .. BT ( FFFFFFFFFFFF) E900 after flash imei (00000000000000) .. BT ( FFFFFFFFFFFF) when i try to write new imei i give this error: Entering Test mode... Checking Security Type... MSL Security Detected!!! Calculating MSL... Operation failed! how can i fix it ? |
07-26-2008, 18:44 | #4 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Guangzhou-China
Member: 468587 Status: Offline Sonork: 100.1612429 Thanks Meter: 682 | Quote:
write NVM file, then write imei, will be ok. | |
07-26-2008, 19:32 | #6 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Romania
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | Solution 1: 1. write E900 NVM file on phone. You can find NVM file on NsPro support area. 2. Write IMEI on the phone. Solution2: 1.Select C400 on NsPro and write any IMEI on the phone. 2. Select E900 and write back the original IMEI on the phone. Make sure that you are using last nspro version from www.nsteam.org. Make sure that you use firmwares from nspro support area. Your problem was caused by a wrong firmware for that phone or improper use of NsPro software. Allways read the nspro assistant instructions before using any operation on NsPro. |
The Following 3 Users Say Thank You to Elco For This Useful Post: |
07-26-2008, 23:15 | #7 (permalink) | |
Member: 550472 Status: Offline Thanks Meter: 6 | Quote:
Thanks Mr.Elco Thanks for help | |
M620 after flash ,imei 00000000000000 | dominik1 | NSPRO | 9 | 12-29-2008 22:50 |
E570 after flash imei - 00000000000000, BT - FFFFFF-FFFFFF | Boshko_Alfa | NSPRO | 13 | 07-31-2008 08:29 |
E900 After Flashing Problem | nomangsm | UST Pro II | 1 | 09-24-2006 00:46 |
E900 after flash chinese no keypad tone | dkny_chau | UST Pro II | 2 | 08-04-2006 09:11 |
