Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > NSPRO
Old 03-26-2009, 17:11   #16 (permalink)
SUUNNYY's Avatar
Member: 885625
Sonork: 100.1589108
Thanks Meter: 2,432
Originally Posted by svchost View Post
all operation completed but phone now show samsung logo and restart , what to do now!!!!
HI FRIEND LOOK AND DO AGAIN
http://rapidshare.com/files/21380303...15.54.gif.html
REGARDS,[COLOR=cyan]SUUNNYY[/COLOR]
Old 03-26-2009, 18:35   #17 (permalink)
Member: 137980
Thanks Meter: 168
i allready tell you Use ns pro select i-450 press unlock after unlock sucsuss /now user code set as 00000000 its tested by me
Old 03-26-2009, 21:08   #18 (permalink)
svchost's Avatar
Member: 841080
Thanks Meter: 177
i test it friend but no sucess tomorow i test again with apollo anfd post result
Old 03-27-2009, 10:53   #19 (permalink)
svchost's Avatar
Member: 841080
Thanks Meter: 177
REGARDS,[COLOR=cyan]SUUNNYY[/color]
definitely not work friend same when start phone show samsung logo and restart............now i have big problem
Old 03-27-2009, 12:30   #20 (permalink)
SUUNNYY's Avatar
Member: 885625
Sonork: 100.1589108
Thanks Meter: 2,432
hi friend flash your phone,this solution was not tested by me,anyway flash the phone,suunnyy
Old 03-27-2009, 13:24   #21 (permalink)
svchost's Avatar
Member: 841080
Thanks Meter: 177
how to flash , sorry friend i ask many question to you brcause i belive you can help me , do you have msn adress to contact ......
Old 03-27-2009, 14:38   #22 (permalink)
New Style's Avatar
Member: 252713
Sonork: 1581550
Thanks Meter: 159
bro you have flash that only with modem file so this happend.now flash with pda image file for this u has to set mobile in pda mode by pressing "4 & 7".and then flash with pda file all will be ok.100% tested.if u have file then ok otherwise i will upload for u so reply soon
Old 03-27-2009, 15:14   #23 (permalink)
svchost's Avatar
Member: 841080
Thanks Meter: 177
friend this operations to do with apollo? and first te set phone in pda mode 4+7 to select modem file to click modem download and second to select pda file and to click pda download true or no , and dou you have any link to sdownload this files-pda+modem!!!!!!
Old 03-27-2009, 15:21   #24 (permalink)
SUUNNYY's Avatar
Member: 885625
Sonork: 100.1589108
Thanks Meter: 2,432
friend this operations to do with apollo? And first te set phone in pda mode 4+7 to select modem file to click modem download and second to select pda file and to click pda download true or no , and dou you have any link to sdownload this files-pda+modem!!!!!!
yes my friend of course with apollo,regards,suunnyy
Old 03-27-2009, 15:27   #25 (permalink)
bigboy85's Avatar
Member: 682554
Sonork: 1601123
Thanks Meter: 222
here is the link
http://forum.gsmhosting.com/vbb/show...postcount=3081
Old 03-27-2009, 15:35   #26 (permalink)
SUUNNYY's Avatar
Member: 885625
Sonork: 100.1589108
Thanks Meter: 2,432
HI FRIEND HERE HOW TO FLASH
1. Download the file from the location
2. Now switch off your mobile then press 1+4+power button you wil enter into a mode where your boot loader information will be given dont do anything
3.after that in your pc you will get a option to instal the driver now at that time go to the folder "ss60_downloader_driver" there you will have two folders called pda driver point the path to that folder so that the driver is installed affter that when you open the phone driver u can see a exe file called setup install that
4.after completing the four steps now open the apollo ver 4.1 zip file and run the file in that you will get two options at the top modem code and pda image
5.now open the folder i450xxhc1 there you will find two files having extension .bin and .img
6.place the .bin file in modem code and .img file in pda image then click pda download
7.after sometime it will say download completed reboot your mobile
NOTE: DONT FORGET TO REMOVE YOUR MEMORY CARD AND DONT REMOVE THE USB CABLE DURING FLASHING PROCESS THANK YOU
FILES
1.DRIVERS
http://www.MegaShare.com/535298
2.APOLLO EXE FILE
http://www.MegaShare.com/535300
3.PDA FILE AND THE MODEM CODE FILE
http://www.mediafire.com/download.php?itmiccz1vfz
I HOPE THIS TIME YOU WILL RESOLVE THIS,REGARDS,SUUNNYY
The Following 5 Users Say Thank You to SUUNNYY For This Useful Post:
Old 03-27-2009, 17:05   #27 (permalink)
svchost's Avatar
Member: 841080
Thanks Meter: 177
FILES
1.DRIVERS
2.APOLLO EXE FILE
solved, thank you very very much bro you are amazing, thnx again
how to reset security code of samsung I450???? svchost Z3X-Team Products 8 05-14-2010 19:52
How to Reset Security Code of LG KM380?(Solved) rajinder1978 FuriousGold 5 10-07-2009 20:36
How to reset security code of F480 (solved) Mobilmannen UST Pro II 5 05-30-2009 22:23
how to reset security code of samsung I450???? svchost UST Pro II 2 03-26-2009 11:09
How to reset security code of ku990 GSM-FUTURE FuriousGold 4 02-14-2009 15:53
Page generated in 0.27511 seconds with 9 queries
