03-29-2016, 10:14 | #1 (permalink) |
Junior Member Join Date: Aug 2013
Member: 2012075 Status: Offline Thanks Meter: 1 | I9300 Emergency Calls After IMEI Repair Many thanks |
03-29-2016, 11:59 | #2 (permalink) |
No Life Poster Join Date: Sep 2014 Age: 46
Member: 2260435 Status: Offline Thanks Meter: 118 | If got signal, check is reading the sim card and test with other one. If not work, dial *#2263#, select gsm band preference, then GSM ALL to force 2G signal. if not work IMEI is black listed. |
03-30-2016, 03:42 | #3 (permalink) |
Insane Poster Join Date: Nov 2012
Member: 1835006 Status: Offline Thanks Meter: 7 | Hi, Ive had this issue a lot of times with the i9300's all you need to do is use the 4.1.2 firmware from support and flash to phone, then just do imei repair and will be fine. also to be sure imei is not blacklisted just purchase a checkmend report. https://www.checkmend.com/uk/ BR Syed |
03-30-2016, 18:41 | #4 (permalink) |
Freak Poster Join Date: Jun 2004 Age: 48
Member: 69631 Status: Offline Thanks Meter: 42 | Save your money on checkmend and just change the imei for a known working one, if it works and dials out the the imei is blocked ! If so change it back to original and give customer phone bach. |
03-31-2016, 03:42 | #5 (permalink) |
Member: 1835006 Status: Offline Thanks Meter: 7 | or use CleanCheck.me - Free Online IMEI Check against lost and stolen databases for free imei check. |
03-31-2016, 21:26 | #6 (permalink) |
Crazy Poster Join Date: Nov 2010 Location: BiH
Member: 1447720 Status: Offline Thanks Meter: 10 | type on dialpad *#0011# if its say tha IMEI CERT: FAIL as i belive becouse ns pro can only repair imei corect with working network on 4.1.2 on 4.3 ther is imei certificate then only way to do this is repair with z3x or octopus with option patch certificate. |
