02-01-2016, 11:14 | #1 (permalink) |
Freak Poster Join Date: Sep 2005 Location: Manchester, UK
Member: 180873 Status: Offline Thanks Meter: 80 | NS Pro on windows 10 I couldn't find any threads on this, so is it possible to install NS PRO on windows 10? Has anyone successfully done this and if so which drivers are needed for this? br |
The Following User Says Thank You to javakiller For This Useful Post: |
02-01-2016, 11:41 | #2 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Romania Age: 37
Member: 607365 Status: Offline Sonork: 100.1590583 Thanks Meter: 294 | Works fine on Windows 10, first you need to disable driver signature in Windows: 1. Press the Win + C and click on PC settings. 2. Switch over to the “Update & recovery” section. 3. Then click on the Recovery option on the left hand side. 4. Once selected, you will see an advanced startup section appear on the right hand side. You will need to click on the “Restart now” button. 5. Once your Computer has rebooted you will need to choose the Troubleshoot option. 6. Then head into Advanced options. 7. Then Startup Settings. 8. Since we are modifying boot time configuration settings, you will need to restart your computer one last time. 9. Here you will be given a list of startup settings that you can change. The one we are looking for is “Disable driver signature enforcement”. To choose the setting, you will need to press the F7 key. |
02-11-2016, 11:06 | #3 (permalink) |
Junior Member Join Date: Feb 2016
Member: 2528264 Status: Offline Thanks Meter: 0 | win 10 Nspro only win10 32 bit [QUOTE=javakiller;11592708]Hi guys, I couldn't find any threads on this, so is it possible to install NS PRO on windows 10? Has anyone successfully done this and if so which drivers are needed for this? use win 10 32 bit only will worck perfectly not 64 bit ! |
