08-01-2008, 12:23 | #1 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Harare, Zimbabwe/ South Africa Age: 44
Member: 46546 Status: Offline Sonork: 100.1577435 Thanks Meter: 85 | problem with A706 and F700v unlocking |
The Following User Says Thank You to Tinotenda For This Useful Post: |
08-01-2008, 13:04 | #2 (permalink) |
Cheater -Don't Deal with him- Join Date: May 2008 Age: 36
Member: 770769 Status: Offline Sonork: 100.1579718 Thanks Meter: 339 | try this solution dwnload 3g patch file for f700 flash ur f700v with f700 3g patch after flashing connect power on fone with ur box , and click unlock for sure it ll unlock ur fone , if still fone locked than do not do any thin jus dwnload f700 firmware frm support and flash ur fone with firmware and after that go for unlock it ll wrk plz post results |
08-01-2008, 13:27 | #5 (permalink) |
Member: 46546 Status: Offline Sonork: 100.1577435 Thanks Meter: 85 | [QUOTE=gsm_era;3529984]why cant flash ? is there any prob[/Q getting flash format failed on f700 on a706 i get reading acknowledge failed, |
08-01-2008, 13:36 | #6 (permalink) |
Member: 770769 Status: Offline Sonork: 100.1579718 Thanks Meter: 339 | go to ns pro forum http://www.nsdongle.com/forum/index.php/board,15.0.html and search for mutiloader flasher flash ur phone with this soft , or dwnload frm here http://www.sendspace.com/file/5e97b3 plz post results |
08-01-2008, 13:39 | #7 (permalink) |
Member: 770769 Status: Offline Sonork: 100.1579718 Thanks Meter: 339 | and for a706 there is also 3g patch solution , with original firmware u ll get acknowledge fail , flash it with patch file |
The Following User Says Thank You to gsm_era For This Useful Post: |
08-01-2008, 14:04 | #8 (permalink) |
Member: 46546 Status: Offline Sonork: 100.1577435 Thanks Meter: 85 | i have multi loader, i have patched firmware for a706, and f700 but i still get errors, on multi loader i am getting invalid address... |
08-01-2008, 15:39 | #10 (permalink) | |
Member: 46546 Status: Offline Sonork: 100.1577435 Thanks Meter: 85 | Quote:
thanx a lot man , fixed with multi loader.... | |
08-02-2008, 06:49 | #13 (permalink) |
Member: 46546 Status: Offline Sonork: 100.1577435 Thanks Meter: 85 | please can u compare the start addresses on the attachments, the F700 patched files have wrong start address and the original ones have a different one, and they are being detected as files for A747 |
08-02-2008, 22:54 | #15 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Romania
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | use nspro to flash that files on phone, fallowing the nspro helper instructions and will work fine. The patch was not made for multiloader. Was made for NsPro. |
The Following User Says Thank You to Elco For This Useful Post: |
Problem with A706 | DJiCE | NSPRO | 1 | 07-14-2008 16:44 |
Problems with U830 and U900 unlock | Rhamses | FuriousGold | 14 | 10-18-2007 10:33 |
Problem With 5200 And 5300 Unlocking With Free Method | strangerboy | MT-BOX | 52 | 09-13-2007 15:35 |
a problem with 342i and x300 unlock | marmouta | Infinity-Box | 9 | 06-10-2005 23:25 |
Problem with Dongle and 2.3 Unlocker HELP needed | GsmProf | Infineon C16X M51 & ARM7 M52 BASED | 4 | 09-03-2003 12:15 |
