10-10-2008, 12:05 | #1 (permalink) |
Freak Poster Join Date: Feb 2007
Member: 447656 Status: Offline Thanks Meter: 5 | Problem installing NSpro freeze I'm trying to install nspro first time. I remove all drivers and programs samsung from the PC and downloaded the last version from the web site. I install all correctly but when try to open the program the first menu freeze in startup and don't let me do anything. I try with another cable but is the same. |
10-15-2008, 03:48 | #6 (permalink) |
No Life Poster Join Date: Jun 2006 Location: JAMAICA
Member: 293299 Status: Offline Thanks Meter: 266 | Reinstall NSPRO software on the one already installed when the window pop up asking to remove drivers select yes after that uninstall NSPRO and delete folder from program files then restart computer then reinstall NSPRO again and make sure you have internet.also delete NSPRO software you downloaded and download it again incase it is bad packagethe do the above steps. |
10-24-2008, 10:39 | #10 (permalink) |
Member: 447656 Status: Offline Thanks Meter: 5 | Hello, After install drivers manually i have a windows error that says that NSPRO find a problem and it will be closed, i don't now what to do more. Help urgent.... I already unnistall everyting and install again, delete the past the program files and install again, etc. What to do more? |
10-01-2009, 17:52 | #13 (permalink) |
Major Poster Join Date: Jan 2007 Location: Bahamas
Member: 426005 Status: Offline Thanks Meter: 0 | nspro freeze my nspro freezes at initial screen: i tried three pc's and six cable reinstall nspro over a few times (different software version) still same problem please help br. dagr8one |
10-31-2010, 15:41 | #14 (permalink) |
Freak Poster Join Date: May 2005
Member: 146092 Status: Offline Thanks Meter: 9 | i have the same problem. i dont' want to reinstal the windows. the ns pro work ok on other pc but in this with the problem i have tried all kind of things and just one work until one point. it work like this. unintstal ns pro, detele from program files, restart pc and reinstall ns pro but when asked you in what folder to put the files put another by example nsproo, not the original nspro. at my pc work this until i've tried to install the blackberry soft for drivers and after that it's not working ns pro and z3x, both freeze at start, must to restart pc...i'm waiting another solution. dont tell me something like install driver corect...i've installed ns pro thousand times and i know ho |
NSPRO freeze | gophone | NSPRO | 3 | 09-21-2008 07:04 |
Still having problems with installing NSPro | Mastah-GSi | NSPRO | 28 | 03-02-2008 22:10 |
