11-30-2014, 13:07 | #17 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,346 | Quote:
This Uart S7070 isn't detected from 6.7.3 version and if you try with Old version you I9300 must need to be in 4.1.2 version only . It's all. P.d. remember that in my shop are entered I9300 with OLD fw 4.0.4 with Imei to default and Baseband Unnknow. WHY?, easy, becouse this person never had updated his I9300 and 4.0.4 not working more with Original Ota version, have repaired just with one flash to 4.3 version, Imei/bband all ok w/o any issue. BR allumts | |
11-30-2014, 14:28 | #21 (permalink) | |
Too much worlds, post log and screenshoot. BR | |
11-30-2014, 16:48 | #23 (permalink) | |
Freak Poster Join Date: Feb 2002 Location: Sheffield
Member: 9372 Status: Offline Thanks Meter: 10 | Quote:
11-30-2014, 19:40 | #24 (permalink) |
Member: 9372 Status: Offline Thanks Meter: 10 | I have tried v6.7.2 with 4.3 and it gets stuck on Uart connection, and I have tried 4.1.2 with version 6.7.0 and still get the same message Both on XP 2 machines tested so I guess that this function no longer works seems to me the Uart part of it is not working at all with i9300 |
11-30-2014, 22:20 | #25 (permalink) |
Member: 9372 Status: Offline Thanks Meter: 10 | ok tried a fresh install and this time ns pro v6.7.0 phone v4.1.1 and stuck again on Uart operation failed. So I ask the question what ns pro version and software version cant someone just answer the question. |
12-01-2014, 20:32 | #28 (permalink) | |
Set good this phone, you not know *#7284# command? put this command and set USB on PDA. *#9090# not know too?, ok goes in Samsung general section and read a little of post about command fron Diag and Dial window, install all drivers samsung. | |
12-01-2014, 21:19 | #29 (permalink) |
Member: 9372 Status: Offline Thanks Meter: 10 | yep done all that still same, flashed phone with Odin with 4.1.2 used ns pro to root it and tried it again still gets stuck on uart. I have tested the cable with a multi meter and the resistance is fine. also unlocked a D500 so I know the rj45 port is working fine. also made sure the dock port was cleaned and that's fine too. changed the USB port speeds and installed and the drivers and ns pro on another pc, fresh install also tried many versions of ns pro still same. and its not spam just looking for answers. so my question is can some test their version of ns pro with a rom and let me know whats working its simple. ever one is saying its working but has anyone tested it up to know no! Last edited by mRC; 12-01-2014 at 21:27. |
