11-01-2005, 17:37 | #1 (permalink) |
Junior Member Join Date: Jun 2004 Age: 54
Member: 67793 Status: Offline Thanks Meter: 0 | Problem Using JAF and Twister Samsung Cable 1.Open NSDongle 2. Choose Jaf as connection 3.plug in Twister A300 Samsung Cable 4.press get info and during power process pluged in cable and then atached battery to the phone 5.Phone going in to TEST mode and i get info . I used for instance E-316 Now im trying X426 ,doing absolutly same as outlined above ,wouldnt go in to TEST mode ,phone charging and NSD says FAILEd then i open xCellPhone and try to get info from X-426 and it works just fine ,i close xCellPhone and now trying in the NSD and it also works , but if i switch back to E-316 i have to repeat the whole process to get it to work . Elco i think there is a setting changes problem in the JAF or in Windows . Please review that as i'm probably not the only one who experience that . Thanks xSpyder |
11-02-2005, 04:38 | #2 (permalink) |
Freak Poster Join Date: Dec 2004 Location: Inside my brain
Member: 97242 Status: Offline Thanks Meter: 14 | my experience is that you have to connect cable to phone after request operation, when program search phone ... if do it before sometimes works, sometimes not |
problem in jaf and twister reg. dct3 | nilda | J.A.F. By Jafsupport.com | 0 | 10-08-2009 01:36 |
is cyclone and jaf and twister same flash file | KING29 | Cyclonebox | 7 | 08-10-2009 01:47 |
dct4 using jaf and twister | jsp2005 | AdvanceUFS | 1 | 06-10-2008 19:39 |
6600 ok with jaf and twister not with UB | eureka8888 | Universalbox | 12 | 12-12-2006 16:32 |
problem using the new twister | florin_m | Twisterflasher | 14 | 04-06-2005 21:43 |
