07-30-2008, 14:46 | #1 (permalink) |
Banned Join Date: Sep 2004 Location: msaken Age: 43
Member: 82201 Status: Offline Sonork: 1576982 Thanks Meter: 32 | probleme unlock u700v?????????????? TO DAY I TRY TO UNLOCK 3 U700V i use cable usb for flash flash ok but operation unlock failed in operation unlock i use cable d800 i get (phone not found) this problem I've met the other times look this link http://forum.gsmhosting.com/vbb/showthread.php?t=569442 what is the probleme sir elco ???????????????????? I CHANGE PC BUT SAME PROBLEME I THINK IT IS BUGS IN VERSION 4.2.2 |
07-30-2008, 15:42 | #2 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Romania
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | The phone must be detected on device manager as 'SAMSUNG CDMA MODEM" If the phone is not detected by windows, wont be detected by NsPro. And if is not detected by windows, then there may be a connection problem: cable, phone system connector, etc... Also, if you get "USB POWER EXCEED" message from windows, you can solve it by modifiyng your box or by using Z*** adapter. You can find all the solutions you need by using SEARCH on this forum or checking the instructions and documentations from nspro support area. |
Problems unlocking u700v | zoria | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 2 | 07-17-2009 17:11 |
problem unlocking u700v | hafiz irfan | Ultimate-Sam | 1 | 08-27-2008 11:58 |
Problem With U700v | jose79 | KULANKENDI Server | 8 | 08-06-2008 11:14 |
Problems with u700v | drksnakey | Samsung Hardware Repair | 0 | 07-25-2008 14:24 |
problem flashe u700v | ahmed14 | NSPRO | 8 | 07-14-2008 19:36 |
