05-25-2007, 18:21 | #2 (permalink) |
Freak Poster Join Date: Nov 2005 Location: Tukiye/izmir Age: 39
Member: 204211 Status: Offline Thanks Meter: 41 | what is the condition of phone. if its working try to uninstall and then reinstall nspro 3.0.0 if not help press write button then inset the cable to box. |
05-25-2007, 22:53 | #4 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Romania
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | Install NsPro drivers correctly, make sure thaty NsPro port is on Com port lower than COM 20 and everything will work without any problem. Using SEARCH function on forums will speare you from waiting for answers on such questyions. Because i posted solution for this problem hundrets times before. |
05-26-2007, 09:29 | #5 (permalink) |
Registered User Join Date: Feb 2004 Location: MERSIN, TURKEY
Member: 55026 Status: Offline Thanks Meter: 53 | Dear ELCO, if I could find a way I would not post you. my NS PRO com port is 6, and appr. 10 times I uninstalled and reinstalled NS PRO and its drivers, erased all folders too. no result. with and without cable or phone, when press "write" immediatelly shows this error. regards. |
05-26-2007, 10:45 | #6 (permalink) | |
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | Quote:
05-26-2007, 10:49 | #7 (permalink) | |
No Life Poster Join Date: Feb 2006
Member: 235471 Status: Offline Thanks Meter: 57 | Quote:
its always been like this for me... i think you have to do something elco... i have tried your solution but still after somwtime its back again... need reliable and permanent solution... keep it up, brgds.... | |
05-26-2007, 11:09 | #8 (permalink) |
Member: 55026 Status: Offline Thanks Meter: 53 | Thankyou Elco, Problem Solved Now..But now phone hang on startup logo.. I flashed U600XEGD3.s3, could you please tell us for what is that U600XEGD3_cts.cts, and how to flash it? Last edited by KUBAT1; 05-26-2007 at 11:22. |
05-26-2007, 11:21 | #9 (permalink) |
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | read flash from that phone (to have a backup) then flash the phone again with Repair mode checked and differences only checked. If the phone have IMEI 0046.... after flashing, flash back the backup and phone will be OK. Some U600 phones get IMEi problem after flashing on repair mode. And some phones hang on startup after normal flashing. I am working on solution for that problem. |
06-21-2007, 19:47 | #11 (permalink) | |
Junior Member Join Date: May 2006
Member: 282145 Status: Offline Thanks Meter: 0 | Quote:
E52 RM-469 Flashing problem.Flash ID not supported for this loader (RAPUv11_algo_xsr1 | rafik2533 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 04-04-2010 20:38 |
u600 to u600b possible? or a way for fix u600 flashed by u600b? | SLIPLOCK | Trident/AGERE Platform | 0 | 04-02-2009 01:10 |
U600 Flashing Problem | coolarooney | NSPRO | 3 | 07-27-2008 14:11 |
u600 flash problem | mobile_2003 | UST Pro II | 2 | 07-27-2007 12:59 |
hi siroya u600 flashing ok imei problem help | cellman899 | UST Pro II | 3 | 07-14-2007 15:26 |
