09-23-2008, 12:12 | #1 (permalink) |
Freak Poster Join Date: May 2007
Member: 499081 Status: Offline Thanks Meter: 44 | tat mode problems |
09-24-2008, 09:15 | #2 (permalink) |
Member: 499081 Status: Offline Thanks Meter: 44 | is there no body out there?or am i d only one with these problem...elco im expecting a response from u plzzz...these phones i mentioned only enter tat mode for a second and i get operation failed.... |
09-24-2008, 09:39 | #3 (permalink) |
No Life Poster Join Date: May 2001 Location: U.K Age: 54
Member: 4611 Status: Offline Thanks Meter: 68 | If you are using the latest version of ns-pro, then either change the rj45 cable, or bridge out the zener diode inside of it. Also one problem I had with ns-pro was the USB lead. Works fine with other boxes, just didn't agree with ns-pro. The usb lead fault caused a slightly different error though. TAT MODE was displayed, then the ns-pro software would shut down. |
09-24-2008, 16:54 | #4 (permalink) |
Freak Poster Join Date: May 2005 Location: Tiaret Age: 39
Member: 145088 Status: Offline Thanks Meter: 13 | i bay a new box , that is in attached image i have the same problem, the phone can't go on TAT mode, but flashing is OK, and that for all models and for qualcomm phones, the soft can't detect the modem so what must i do then but i have no shematics to remove the diode, and if i open the box i loose the waranty |
09-24-2008, 22:53 | #5 (permalink) |
Member: 4611 Status: Offline Thanks Meter: 68 | When I said bridge the zener diode inside of it, I was refering to the cable, not the box itself. With the Qualcomm, the phone is switched on? if so connect it to the Ns-Pro, go into device manager / modems, and then delete all Samsung modems shown there. Disconnect then reconnect the phone and let the drivers reinstall. Lastly check the com port number for the nspro box and the samsung modem. They should be less than or equal to 10 to avoid certain problems. |
09-26-2008, 02:46 | #6 (permalink) |
Member: 145088 Status: Offline Thanks Meter: 13 | this instruction for uninstalling is already done but no good result, the problem persist, only flashing is allowed, when i try to unlock or do some service it's not possible then phone show charging and shut down then rebooting, and the service can't be done |
09-27-2008, 03:49 | #8 (permalink) |
Member: 145088 Status: Offline Thanks Meter: 13 | it's not a cable problem because they works fine with UFS+HWK, and for driver i already uninstall them and reinstall again, i don't know what is it realy |
10-01-2008, 20:42 | #10 (permalink) |
Member: 145088 Status: Offline Thanks Meter: 13 | already done bro, i try to connect my box in other pc that other ns work fine and i get same error, i think it is hardware problem because the other box work fine and my box still giving error Mr Elco i need some help here |
11-03-2009, 19:42 | #12 (permalink) | |
No Life Poster Join Date: Dec 2002 Location: Romania
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | Quote:
all nspro boxes have 6 months waranty | |
11-04-2009, 06:31 | #13 (permalink) | |
No Life Poster Join Date: Nov 2004 Location: Capetown
Member: 91045 Status: Offline Thanks Meter: 8,696 | Quote:
ask ur reseller if he allows u to open the BOX check the Rj 45 connecter inside and its Connectivity... I bet Bad Soldered PCB RJ 45 female Connecter u not need to repair just to make Sure so that u can claim Authenticaly as Its Factory Fault | |
Tat Mode Problem | ian20essex | NSPRO | 1 | 10-29-2007 16:38 |
d600 tat mode problem | whaleyworld | NSPRO | 6 | 08-05-2006 11:50 |
Problems entering TAT mode on D500! | James_S | NSPRO | 18 | 10-29-2005 19:55 |
problem loading TAT mode | ladascv | TST Dongle | 4 | 06-23-2005 21:38 |
Problem getting into TAT mode on a E800 | gaz_0001 | SYSOL Platform | 4 | 05-12-2005 17:23 |
