07-18-2007, 14:28 | #1 (permalink) |
No Life Poster Join Date: Jun 2006 Location: manchester, united kingdom Age: 39
Member: 288521 Status: Offline Thanks Meter: 685 | x830 imei problem any advice?? imei change goes through successfully! |
09-30-2008, 10:56 | #4 (permalink) |
Junior Member Join Date: Jan 2007
Member: 422298 Status: Offline Thanks Meter: 21 | If the phone is X830: Select C400 andwrite any IMEI on that phone Then select X830 and write backthe original IMEI. If the phone is X830N: Write the X830N NVM file from support area to that phone then write back the original IMEI to that phone signed by elco |
The Following User Says Thank You to soheib1981 For This Useful Post: |
09-30-2008, 10:59 | #5 (permalink) |
Member: 422298 Status: Offline Thanks Meter: 21 | If the phone is X830: Select C400 andwrite any IMEI on that phone Then select X830 and write backthe original IMEI. If the phone is X830N: Write the X830N NVM file from support area to that phone then write back the original IMEI to that phone |
X830 Keypad Problem | gsmsharing | Samsung Hardware Repair | 5 | 06-14-2008 18:21 |
X830 Flash Problem | jawal | UST Pro II | 4 | 03-10-2008 19:48 |
X830 Repair IMEI , problem | mahcin | Samsung Flashers, Software, Firmware. | 0 | 03-02-2008 16:52 |
x830 spring problem | porn | Samsung Hardware Repair | 1 | 01-31-2008 11:39 |
X830 Flashing Problem W/ NsPro 1.8.0 | mishaelwillo | NSPRO | 6 | 06-03-2007 14:35 |
