Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > powerflasher
Old 02-24-2005, 18:01   #1 (permalink)
Member: 112459
Unhappy Help Help and Help
I just bought Power flasher but I can't install the slaver driver. I tried to install the drievr from the cdrom but still not work. Iam new with this.
The master is OK. I connected the slaver usb to pc and pc detected it with new usb device and ask for driver installation. There is usb port in and com port at the slaver and usb-com out and comport out. What is it for. and at the master there are 2 usb port out. This is also for what.
Thanks a lot for your kind of help.
Old 02-25-2005, 10:03   #2 (permalink)
systemworm's Avatar
Member: 68498
Thanks Meter: 152
Are you here?I can help you
Old 02-25-2005, 10:10   #3 (permalink)
systemworm's Avatar
Member: 68498
Thanks Meter: 152
In your main setup disc,in slaver part there is a pl 2303 usb to serial driver.Install it and windows will find your box.USB in the master box are additional usb hubs.And slaver box the ports:One is com in com out the other is usb to com port.
softworm
Old 02-27-2005, 02:53   #4 (permalink)
Member: 112459
Thanks softworm. i can't find the file in the disc. How can i use the slaver as for the master I just connect the usb to pc (at the back master) and the service cable to the phone (in front of the master). But for the slaver where do I have to connect to pc and to phone. What and where the ports at the slaver use for and connected to and usb and the master connectes to where. thanks a lot for your help.
Old 02-27-2005, 07:52   #5 (permalink)
systemworm's Avatar
Member: 68498
Thanks Meter: 152
Listen in the main disc in the slaver part there is a setup called ''PL-2303 Driver Installer''.Install it and then connect slaver box to your pc by means of usb cable which comes with the package.Computer will find a new com port.Usb to serial port.There are two rj 45 ports.The first one from the left is usb to comport.The other one is com port in com port out.For example you attach a com cable from the back part and from the front part you attach your cables.
Old 02-27-2005, 16:16   #6 (permalink)
Member: 112459
thanks. But I can't find the file in teh CD. maybe do you know where the place I can download it. Thanks.
Old 02-27-2005, 16:29   #7 (permalink)
Member: 53556
if u wanted to help pipinf den upload pl2303 driver installer if still he does not comprehend den its his problem.its matter of helping if not then what r we 4.
Old 02-28-2005, 00:00   #8 (permalink)
Cheater -Don't Deal with him-
descovery's Avatar
Member: 45854
Sonork: 100.78435
Thanks Meter: 29
sir u can found all this files in power flasher support ftb
br
descovery
Old 03-02-2005, 11:19   #9 (permalink)
Member: 112459
Thanks descovery. U mean in the cdrom. I dun have it because bought this PWR FLASER from my friend as he migrated abroad now so these all what I have now. Any home page I can downloas becos I can't find it in the PWR FLSHR homepage.
Old 03-02-2005, 13:01   #10 (permalink)
systemworm's Avatar
Member: 68498
Thanks Meter: 152
Sorry bros late.I was ill.pipinf here is your driver.Download it and install.And about software you can use any software you can find with it.For example I am using USR sometimes.
softworm
Old 03-02-2005, 13:03   #11 (permalink)
systemworm's Avatar
Member: 68498
Thanks Meter: 152
I think you are right
Old 03-02-2005, 16:27   #12 (permalink)
Member: 112459
thanks a lot softworm. I hope you are well now. I just downloaded the software already and the slaver driver already been installed now. I hope you are well now. To use the slaver is it the same like I use the master as at the master I just connect the usb at the back and connect the service cable in front. In the slaver do I have to connect both the usb and com and the back to the PC both?. In front weher do I have to connect the service cable from usb-com out or comport out. For example when I want to connect the motorola acer ufs it said no ufs found?.
Old 03-02-2005, 16:41   #13 (permalink)
Member: 112459
Sorry guys especially you softworm as I keep asking questions because Iam relly new with this stuff. But thanks a lot for your kind of help and everybody in this forum.
Old 03-03-2005, 14:14   #14 (permalink)
systemworm's Avatar
Member: 68498
Thanks Meter: 152
With slaver box you cannot connect ufs,because it's not a ufs box.It's like unibox using comport.and about the ports.It doesn't matter which com port u are using u can use virtual com port,that's from the left.And if u use the other then you must connect com-in com out cable which comes with your box(one end to back of computer and the other to box) Then connect the cables and do work.Remember master box is for nokia,sony ericsson,siemens,acer,samsung and slaver for the others.You can't use master cables with slave box!!!
Enjoy
softworm
Old 03-03-2005, 16:39   #15 (permalink)
Member: 112459
thanks. What program do I have to use to make a flash in the slaver.
want to help mxkey and make more faster and easier to fix contact service how? ilaw MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 02-06-2010 05:03
Can Anyone At All Help, ***MODERATORS AND CODE BREAKERS***** HELP REQUIRED (MEGANE) pazza198 CAR Electronics 3 04-06-2007 20:06
Can Anyone At All Help, ***MODERATORS AND CODE BREAKERS***** HELP REQUIRED (MEGANE) pazza198 CAR Electronics 0 03-14-2007 17:48
Help! VB, And Samsung Mobiles through IrDA and mscomm ocx due GSM Programming & Reverse Engineering 0 09-25-2004 02:46
Page generated in 0.25716 seconds with 10 queries
