08-11-2011, 15:01 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Bangladesh
Member: 621121 Status: Offline Thanks Meter: 366 | 0bd6:s_da_nor_block_data_unstable flash read log Code: ==== [8/11/2011 11:12:28 AM] ==== COM38 [VCP1] selected module v3.99 Device: _Autodetect MT6253 NOR Checking data, wait... Action: read firmware NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[00C0]: 0098:009E00000000 [TOSHIBA] TC58FYM7T8C chip size: 16Mb otp status/size: S_DA_NOR_OTP_EXIST/00020000 NAND flash chip: not installed internal RAM size: 00020000 external RAM: absent done Set baudrate (921600)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... detect custom parameters... detect project-id... project-id: S003_XKL_DUAL_BF3603_V1.4_0903 detect NOR info... number of areas/bytes to read: 1:00050000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: XKSSTEL53_09B_GEMINI_PCB01_GPRS_MT6253_S00.S003_XKL_DUAL_BF3603_V1_4_0903.BIN_FLNTY5701111183KC project-id: S003_XKL_DUAL_BF3603_V1.4_0903, 00000000 code offset: 00000000 ffs offset/size [02]: 00E00000/00200000 rom info structure: [standard] type (07) TCL-ID is absent ===> done ==================== New firmware found (v.3.99, database date: 04.08.2011): XKSSTEL53_09B_GEMINI_PCB01_GPRS_MT6253_S00.S003_XKL_DUAL_BF3603_V1_4_0903.BIN_FLNTY5701111183KC This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== area size: 14Mb number of areas/bytes to read: 1:00E00000 reading (HW_STORAGE_NOR)... file saved: C:\Users\AlaM\Desktop\XKSSTEL53_09B_GEMINI_PCB01_GPRS_MT6253_S00.S003_XKL_DUAL_BF3603_V1_4_0903.BIN_FLNTY5701111183KC__firmware_20110811-112002.B0M.bin Disconnect... done Finished, time used: 7 min 53 sec Remove/Install battery now ! Code: ==== [8/11/2011 11:24:09 AM] ==== COM38 [VCP1] selected module v3.99 Device: _Autodetect MT6253 NOR Checking data, wait... Action: reset settings ("format ffs") NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[00C0]: 0098:009E00000000 [TOSHIBA] TC58FYM7T8C chip size: 16Mb otp status/size: S_DA_NOR_OTP_EXIST/00020000 NAND flash chip: not installed internal RAM size: 00020000 external RAM: absent done Set baudrate (921600)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... detect custom parameters... detect project-id... project-id: S003_XKL_DUAL_BF3603_V1.4_0903 detect NOR info... number of areas/bytes to read: 1:00050000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: XKSSTEL53_09B_GEMINI_PCB01_GPRS_MT6253_S00.S003_XKL_DUAL_BF3603_V1_4_0903.BIN_FLNTY5701111183KC project-id: S003_XKL_DUAL_BF3603_V1.4_0903, 00000000 code offset: 00000000 ffs offset/size [02]: 00E00000/00200000 rom info structure: [standard] type (07) TCL-ID is absent ===> done ==================== New firmware found (v.3.99, database date: 04.08.2011): XKSSTEL53_09B_GEMINI_PCB01_GPRS_MT6253_S00.S003_XKL_DUAL_BF3603_V1_4_0903.BIN_FLNTY5701111183KC This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== Format... autodetection mode... Format done Disconnect... done Finished, time used: 1 min 19 sec Remove/Install battery now Code: ==== [8/11/2011 11:50:37 AM] ==== COM38 [VCP1] selected module v3.99 Device: _Autodetect MT6253 NOR Checking data, wait... Action: write flash write: Firmware XKSSTEL53_09B_GEMINI_PCB01_GPRS_MT6253_S00.S003_XKL_DUAL_BF3603_V1_4_0903.BIN_FLNTY5701111183KC__firmware_20110811-112002.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nor area detection... interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[00C0]: 0098:009E00000000 [TOSHIBA] TC58FYM7T8C chip size: 16Mb otp status/size: S_DA_NOR_OTP_EXIST/00020000 NAND flash chip: not installed internal RAM size: 00020000 external RAM: absent done Set baudrate (921600)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... detect custom parameters... detect project-id... project-id: S003_XKL_DUAL_BF3603_V1.4_0903 detect NOR info... number of areas/bytes to read: 1:00050000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: XKSSTEL53_09B_GEMINI_PCB01_GPRS_MT6253_S00.S003_XKL_DUAL_BF3603_V1_4_0903.BIN_FLNTY5701111183KC project-id: S003_XKL_DUAL_BF3603_V1.4_0903, 00000000 code offset: 00000000 ffs offset/size [02]: 00E00000/00200000 rom info structure: [standard] type (07) TCL-ID is absent ===> done ==================== New firmware found (v.3.99, database date: 04.08.2011): XKSSTEL53_09B_GEMINI_PCB01_GPRS_MT6253_S00.S003_XKL_DUAL_BF3603_V1_4_0903.BIN_FLNTY5701111183KC This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== startup code area #1 check... done number of cores: 1 loading files... number of areas: 1 done write... write core... error: can not write flash (0): 0FA8:S_FT_DOWNLOAD_FAIL error: last error: 0FA8:S_FT_DOWNLOAD_FAIL Disconnect... done Finished, time used: 4 min 0 sec Remove/Install battery now ! |
08-11-2011, 15:10 | #2 (permalink) |
No Life Poster Join Date: Jun 2010 Location: Green Forest
Member: 1316000 Status: Offline Sonork: 100.1624093 Thanks Meter: 348 | Dear, da_nor_block_data_unstable it's spiderman warning. rehote or shake flash ic can solve this problem. tested many times. BR |
08-11-2011, 15:18 | #3 (permalink) |
Member: 621121 Status: Offline Thanks Meter: 366 | see my another log Code: ==== [8/11/2011 6:33:34 PM] ==== COM38 [VCP0] selected module v3.99 Device: _Autodetect MT6253 NOR Checking data, wait... Action: write flash write: Firmware XKSSTEL53_09B_GEMINI_PCB01_GPRS_MT6253_S00.S003_XKL_DUAL_BF3603_V1_4_0903.BIN_FLNTY5701111183KC__firmware_20110811-112002.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nor area detection... interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[00C0]: 0098:009E00000000 [TOSHIBA] TC58FYM7T8C chip size: 16Mb otp status/size: S_DA_NOR_OTP_EXIST/00020000 NAND flash chip: not installed internal RAM size: 00020000 external RAM: absent done Set baudrate (230400)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... detect custom parameters... detect project-id... project-id: S003_XKL_DUAL_BF3603_V1.4_0903 detect NOR info... number of areas/bytes to read: 1:00050000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: XKSSTEL53_09B_GEMINI_PCB01_GPRS_MT6253_S00.S003_XKL_DUAL_BF3603_V1_4_0903.BIN_FLNTY5701111183KC project-id: S003_XKL_DUAL_BF3603_V1.4_0903, 00000000 code offset: 00000000 ffs offset/size [02]: 00E00000/00200000 rom info structure: [standard] type (07) TCL-ID is absent ===> done ==================== New firmware found (v.3.99, database date: 04.08.2011): XKSSTEL53_09B_GEMINI_PCB01_GPRS_MT6253_S00.S003_XKL_DUAL_BF3603_V1_4_0903.BIN_FLNTY5701111183KC This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== startup code area #1 check... done number of cores: 1 loading files... number of areas: 1 done write... write core... error: can not write flash (0): 0BD6:S_DA_NOR_BLOCK_DATA_UNSTABLE error: last error: 0BD6:S_DA_NOR_BLOCK_DATA_UNSTABLE Disconnect... done Finished, time used: 1 min 13 sec Remove/Install battery now ! |
help on chinnese miracle 0BD6:S_DA_NOR_BLOCK_DATA_UNSTABLE | mentari | Infinity-Box | 4 | 04-06-2011 20:07 |
