12-01-2016, 22:17 | #1 (permalink) | |
Banned Join Date: Jul 2006 Location: dword ptr [ebp-1C], edx
Member: 322417 Status: Offline Thanks Meter: 940 | 1 Thread 2 problems , need support Maybe i should open 2 thread ? but i though to make easy for me and supporters. 1.Problem. It very hard to find flash for some HUMI m7 Model but on every each time i will get error Code: [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Code: Scatter Load Ok , BaseBand : MT6752 , Project : e561_tyi3 , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Inital Boot Ok! BB_CPU_PID : 6752 BB_CPU_NME : [MediaTek] MT6732|MT6752_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:28 Reconnect Power/Cable! 2.I Have ZTE Apex Blade 2 with Qualcomm Snapdragon 400 MSM8926 ZTE Blade Apex2 - Specifications CM2QLM Was gr8 Update and surprise for supporting Qualcomm CPU. Phone can power on , but after power on i cant work due android message process was stooped , on each ok will appear again.Its impossible to continue with setup Wizard. Formatted Data and Wiped Cache via Recovery Menu but Format and wipe will not help too. I try couple of firmware's found on internet to flash via SD Card but flashing refused. Probably asking same provider which is ZTE Blade apex 2 TIM Italia that i cant find. I try some editing of vendor inside flash didn't help me too. CM2 Part When i connect holding both buttons phone will vibrate , red light will stay turned on, device will be detected as but nothing is happen. Hear is Log Quote:
12-04-2016, 09:01 | #3 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. 1. Secure boot mean that phone uses : Signed FW Own bootloader Due much count of phones and their differences we can't add them all. Sometimes "Both Volume Key" connect mode allow override that problem by force bootrom mode. 2. Install Emergency drivers. http://forum.gsmhosting.com/vbb/f296...pport-1987591/ |
12-04-2016, 19:58 | #4 (permalink) | |
Member: 322417 Status: Offline Thanks Meter: 940 | Quote:
About 1st one its unsupported? Nothing to do with hardware? Second one will try and thanks for support.. Br Sent from my D6503 using Tapatalk | |
