03-20-2007, 11:34 | #1 (permalink) |
No Life Poster Join Date: Dec 2004 Location: PHILIPPINES
Member: 101860 Status: Offline Sonork: 100.1582168 100.77603 Thanks Meter: 6,036 | >>> C139 to 900 / 1800 - 100% WORKED <<< TRIED, TESTED & PROVEN 100%. br RNC_EBM |
The Following 21 Users Say Thank You to RNC_EBM For This Useful Post: |
03-20-2007, 12:19 | #3 (permalink) |
No Life Poster Join Date: Jun 2005 Location: insane in da mad brain Age: 46
Member: 154522 Status: Offline Thanks Meter: 48 | thanks i have it one i will try and post the result............. |
The Following User Says Thank You to freakyass For This Useful Post: |
03-20-2007, 12:45 | #5 (permalink) |
No Life Poster Join Date: Feb 2004 Location: inside AFRICA
Member: 56157 Status: Offline Sonork: 100.1573682 Thanks Meter: 171 | very good man i try before but unsuccessfully now i can do it very will thanks |
The Following User Says Thank You to IBMOBILES For This Useful Post: |
03-20-2007, 12:49 | #6 (permalink) |
Member: 101860 Status: Offline Sonork: 100.1582168 100.77603 Thanks Meter: 6,036 | Procedure how to CONVERT 800/1900 to 900/1800: 01 = first check the phone VERSION ( #02# ) - if the phone version is 8.8.17 ( mostly TRACFONE ) then you must read " Infinity-Box_How_to_use_RepairModule " after that then goto 02 - if the phone version is 1.x.xx ( some are CINGULAR ) then goto NEXT STEP 02 = flash the phone using this firmware - FIRMWARE: C139_1.0.06_Main.31M.bin - LP: C139_1.0.06_LPL_LATAM_00F_En_Es_Pt.31P.bin - Flex: C139_1.0.06_Flex_FFL_3S_10F.31F.bin 03 = After FLASHING then UNLOCK 04 = Now it's time modify the PHONE given on FIRST POST 05 = NOW YOUR PHONE IS 900/1800 Tried, Tested & Proven 100% WORKING POSTED ALSO HERE: = GSMPH = GSMGADGET = GSMTOOLS br RNC_EBM |
The Following 2 Users Say Thank You to RNC_EBM For This Useful Post: |
03-20-2007, 12:54 | #7 (permalink) |
Freak Poster Join Date: Sep 2002 Location: Palestine/Germany Age: 53
Member: 15593 Status: Offline Thanks Meter: 19 | C139 Hello RNC_EBM, really great solution. Please make you make a clear picture and where i can get the Flashfiles? Please a downloadlink. thanks noko |
03-20-2007, 13:01 | #9 (permalink) | |
Member: 101860 Status: Offline Sonork: 100.1582168 100.77603 Thanks Meter: 6,036 | Quote:
secondly, the DOWNLOAD LINK you've asking is YOU CAN FIND IT AT INFINITY SUPPORT SITE, about password ?, YOU NEED INFINITY BOX TO LOGIN AT SUPPORT SITE USING " DongleManager " or latest INFINITY SHELL. br RNC_EBM | |
The Following User Says Thank You to RNC_EBM For This Useful Post: |
03-20-2007, 13:36 | #15 (permalink) | |
br RNC_EBM | |
>>> W208: Change BAND Solution 850/1900 TO 900/1800 <<< | RNC_EBM | Infinity-Box | 4 | 01-29-2008 05:41 |
>>> J100 to 900/1800 <<< | RNC_EBM | Infinity-Box | 2 | 05-27-2007 05:13 |
how to convert Imate JAM from 850/1800/1900 to 900/1800/1900 ?? | reo | HTC & PDA WM( With Touchscreen) | 29 | 04-03-2007 20:17 |
>>> HWK Tool 100% WORKING <<< | RNC_EBM | Twisterflasher | 135 | 05-16-2006 21:34 |
>>> K750 to W800 - 100% WORKING <<< | RNC_EBM | HWK | 88 | 05-13-2006 16:49 |
