05-16-2007, 15:59 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, It's no need to attach screenshot, more easy way: copy/paste text from "operation.log" file. It can be flash chip problem (damaged or bad soldered flash chip). |
05-16-2007, 16:56 | #4 (permalink) |
Freak Poster Join Date: Apr 2001 Location: EVRYWERE
Member: 4365 Status: Offline Thanks Meter: 39 | operation log: Press and HOLD Power button... Release Power button ! Connect Done Boot... Boot Done Set Baud... 921600 Set Baud Done Check Flash-1... SW version: HW version: imei otp: 359808009307086 Check Flash-1 Done Check Flash-2... reading ... file saved: backup_eeprom_calibration_359808009307086_20070516-185227.18E.bin imei eeprom: 359808009307086 Check Flash-2 Done Write... Writing: all flash areas startup mode adjusted Err: write [00000000]: Err: write [00000000]: FF Err: write [00000000]: 00 Err: write [00000000]: by the way i changed flash ic 1&2 also changed cpu same error any sol. |
to infinity support , pls we need alcatel 203ex simfree file in support | segun4u | Infinity-Box | 21 | 11-22-2009 14:33 |
how to send file to infinity supporter | jignesh269 | Infinity-Box | 1 | 03-06-2008 19:28 |
to infinity support | doudiunlocker | Infinity-Box | 4 | 12-07-2006 21:43 |
to infinity support | REALTHOMAS | Infinity-Box | 7 | 06-07-2006 08:20 |
to infinity support | vascof1 | Infinity-Box | 2 | 06-15-2005 08:33 |
