08-08-2009, 07:50 | #1 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Beetel EC003 SP lock problem--- I have Beetel EC003 locked with BSNL. I tried to do SP Unlock with latest module but no success, here is the log- COM3 [VCP0] selected module v2.83 Device: Beetel-EC003 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:2FBE:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E221A2201:2AEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #01 in region #00... flash: 01227E221A2201:2AEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #02 in region #00... flash: 01227E221A2201:2AEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #03 in region #00... flash: 01227E221A2201:2AEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation ==================== New firmware detected (v.2.83, database date: 04.08.2009): BEETEL_EC003_PCB01_GSM_MT6223_S00.KAAEC003_INE_EN_ HI_0_90_501.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished identification#1 protocol ver: 04 ver. sw 1: BEETEL_EC003_PCB01_GSM_MT6223_S00.KAAEC003_INE_EN_ HI_0_90_501.BIN ver. sw 2: KAAEC003_INE_En_Hi_0.90.501, 00000000 ffs offset/size: 00320000/000E0000 ffs address assigned: 00320000 detect device identification#2... detection phase #1... . detect device identification#2 finished sim-lock status: unknown Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: Beetel-EC003_BEETEL_EC003_PCB01_GSM_MT6223_S00.KAAEC003_I NE_EN_HI_0_90_501__ffs... file saved: C:\Program Files\InfinityBox\MModule\Beetel-EC003_BEETEL_EC003_PCB01_GSM_MT6223_S00.KAAEC003_I NE_EN_HI_0_90_501__ffs_20090808-112928.B0E.bin flash: 01227E221A2201:2AEA0000000000 Backup required data Done Patch required data ... detection procedure, wait... detection procedure completed detection procedure, wait... detection procedure completed Patch required data Done Special operation ... Special operation Done Write ... flash: 01227E221A2201:2AEA0000000000 Write: eeprom error: wrong write first sector at 0x00F20000 Write Fail Finished, time used: 302 sec Remove/Install battery now ! I have uploaded the full flash for Infinity Team so that they can work on this model for SP unlock, I also have sent copy of this full flash read to [email protected]. Link- http://rapidshare.com/files/26499909...part_1_of_1_20 Hope Infinity Box will support this firmware for this model for SP unlock ASAP!!! Last edited by PASSIONATE_BOYS; 08-08-2009 at 07:55. |
08-19-2009, 09:55 | #5 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Thanks again to Infinity team for this good update, tested and working with 2.84, here is the log- COM3 [VCP0] selected module v2.84 Device: Beetel-EC003 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:2FBE:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E221A2201:2AEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device rom info... detection phase #1... detect device rom info finished rom info structure: 2nd [standard] generation rom info detection finished rom info protocol ver: 04 ver. sw 1: BEETEL_EC003_PCB01_GSM_MT6223_S00.KAAEC003_INE_EN_ HI_0_90_501.BIN ver. sw 2: KAAEC003_INE_En_Hi_0.90.501, 00000000 ffs offset/size: 00320000/000E0000 ffs address assigned: 00320000 detect device sec info... detection phase #1... . detect device sec info finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: Beetel-EC003_BEETEL_EC003_PCB01_GSM_MT6223_S00.KAAEC003_I NE_EN_HI_0_90_501__ffs... file saved: C:\Program Files\InfinityBox\MModule\Beetel-EC003_BEETEL_EC003_PCB01_GSM_MT6223_S00.KAAEC003_I NE_EN_HI_0_90_501__ffs_20090819-141641.B0E.bin flash: 01227E221A2201:2AEA0000000000 Backup required data Done Patch required data ... detection procedure, wait... detection procedure completed detection procedure, wait... detection procedure completed Patch required data Done Special operation ... detecting parameters to apply patch area 0... ....... flash: 01227E221A2201:2AEA0000000000 flash: 01227E221A2201:2AEA0000000000 Write: area 01 ......... area 0 patch applied Ok Special operation Done Write ... flash: 01227E221A2201:2AEA0000000000 Write: eeprom Write Done Finalization ... Finalization Done Finished, time used: 167 sec Remove/Install battery now ! |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
12-01-2009, 19:25 | #7 (permalink) | |
This file can be downloaded from Infinity-Box support area: Beetel-EC003_BEETEL_EC003_PCB01_GSM_MT6223_S00.KAAEC003_I NE_EN_HI_0_90_501_En_Hi.B0M.bin | |
Motorola C140 Sp-lock Problem | SHIJILFONOTLY | Infinity-Box | 12 | 02-11-2017 15:13 |
lg kp 100 sp lock problem | deepaksawdia | Infinity-Box | 7 | 11-02-2013 09:03 |
G600 SP Lock problem | banditdave | Samsung Flashers, Software, Firmware. | 1 | 01-17-2009 21:36 |
smadel a300 sp lock problem | farhahmed | Chinese Models & Cloned Phones | 1 | 08-16-2008 08:33 |
zte 2010 sp lock problem | jay k sundrani | Infinity-Box | 1 | 09-19-2007 10:57 |
