Old 03-23-2009, 16:03   #1 (permalink)
ZIYAAD STRYKER's Avatar
Member: 175945
Sonork: ziiyyaad
Thanks Meter: 704
a950 restart with sim, imei incorrect
format ffs safe not fully completed, something in chinese is written and phone stays as same, help please!!
COM12 [VCP0] selected
module v2.78
Action: reset settings
Model: Autodetect 6205-6227 NOR
Checking data, wait...
19200 autodetect
Initializing [6226:8A02:8A01]...
CPU: MT6226
high speed boot Off
chip: 0031:36AA:8B99
status: FF
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6226,E02
Date: 2005.04.12
Version: 1.0
Version: Y600.TL.1.9
Version: YW26_05C_HW
detecting structure #2...
done
60 byte(s) read
imei: 13579024681122
warning: current phone imei is incorrect !
It's need to repair imei for correct phone functionality !
connection Ok
building list...
done
items to clear: 168
warning: wrong packet cs
flashed backup firmware...
still same
module v2.78
Device: Autodetect 6205-6227 NOR
Action: write NOR flash
"smart write" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
ffs/eeprom backup enabled, it may takes several minutes !
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed boot Off
status: FF
high speed boot Off
boot packet size: 0002
Boot Done
Initialize ...
flash: EC22E000000000:29EA0000000000
flash: Samsung AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb
detecting chip #01 in region #00...
flash: EC22E000000000:02307600000000
detecting chip #02 in region #00...
detecting chip #03 in region #00...
detecting chip #04 in region #00...
detecting chip #05 in region #00...
detecting chip #06 in region #00...
detecting chip #07 in region #00...
number of flash chip/regions detected: 08/01
Initialize Done
Set baud ...
921600
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
number of flash chip/regions detected: 02/01
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area (code #1) is Ok
security area (code #1) backup saved: D:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.9243B568.[Y600_TL_PCB01_GPRS_MT6227_S01.Y600_TL_1_5.BIN_5494 33C5].rpl
identification#1 detection finished
device-id: 9243B568
identification#1 protocol ver: 04
ver. sw 1: Y600_TL_PCB01_GPRS_MT6227_S01.Y600_TL_1_5.BIN
ver. sw 2: Y600.TL.1.5, 3ACC6BAB
ffs offset/size: 00E00000/00200000
detect device identification#2...
detect device identification#2 finished
detecting ffs/eeprom area in 2 chip(s)...
standard ffs/eeprom offset detected: 00E00000
checking area [00000000]: 00000000-007FFFFF...
checking area [00800000]: 00000000-007FFFFF...
ffs/eeprom found near: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 01
ffs/eeprom area: 00800000:00600000-007FFFFF
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
reading: eeprom[Y600_TL_PCB01_GPRS_MT6227_S01.Y600_TL_1_5.BIN]...
file saved: D:\Program Files\InfinityBox\ChineseMiracle\eeprom[Y600_TL_PCB01_GPRS_MT6227_S01.Y600_TL_1_5.BIN]_20090323-120248.B0E.bin
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
security area (code #1) calculation...
done
detecting security area (code #2)...
security area (code #2) is absent
file saved: D:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_9243B568_Y600_TL_PCB01_GPRS_MT6227_S01.Y 600_TL_1_5.BIN_549433C5_20090323-120258.B0X.bin
Area: Firmware
Write: Firmware
jump to next chip: 01
Write: Firmware
Write Done
Finalization ...
Finalization Done
file saved: D:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_9243B568_Y600_TL_PCB01_GPRS_MT6227_S01.Y 600_TL_1_5.BIN_549433C5_20090323-120404.B0X.bin
Finished, time used: 268 sec
Remove/Install battery now !
tried complete format, same!!!
module v2.78
Action: "format ffs"
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed boot Off
status: FF
high speed boot Off
Boot Done
Initialize ...
Initialize Done
Set baud ...
921600
Set baud Done
device-id: 9243B568
ffs/eeprom chip: 01
Write ...
Write Done
Finalization ...
formatting...
Finalization Done
file saved: D:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_9243B568_Y600_TL_PCB01_GPRS_MT6227_S01.Y 600_TL_1_5.BIN_549433C5_20090323-122120.B0X.bin
Finished, time used: 148 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 03-23-2009, 17:58   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
1. power on phone
2. enter *#0044# and press green (Send) key
3. try to make 112/emergency call without sim card
what is the results ?
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 03-23-2009, 18:58   #3 (permalink)
Member: 175945
Sonork: ziiyyaad
Thanks Meter: 704
language is set to english and emergency called can be made!!!! but stll restart with sim!!
Old 03-23-2009, 20:25   #4 (permalink)
ton1x's Avatar
Member: 258858
Thanks Meter: 96
format the phone using software. if still restart, im sure the problem is on the cpu. rehot or reball. if still restart, change it and flash it again.
Old 03-23-2009, 23:44   #5 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
please make full backup of your existing firmware and try thisflash file:
[bin] flashfiles/ChineseMiracle/_MT6227/CM_Cect-M1818_K795-PDA_Y600_TL_PCB01_GPRS_MT6227_S01.Y600_TL_1_5_16m_ En_Cn.B0M.bin
Old 03-24-2009, 03:51   #6 (permalink)
Member: 175945
Sonork: ziiyyaad
Thanks Meter: 704
Thanks infinity help, without your help would have not be able to do it!!!
not ok still same with this firmware...
Tried with another firmware CM_A950_Y600_RUS_PCB01_GPRS_MT6227_S01.Y600_RUS_1_ 5_16m_En_Ru-corrected.B0M ... seems ok now!!!
module v2.78
write: Firmware
skip: Customization
skip: Eeprom/ffs
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed boot Off
status: FF
high speed boot Off
Boot Done
Initialize ...
Initialize Done
Set baud ...
921600
Set baud Done
device-id: 9243B568
ffs/eeprom chip: 01
file saved: D:\Program Files\InfinityBox\ChineseMiracle\eeprom[Y600_TL_PCB01_GPRS_MT6227_S01.Y600_TL_1_5.BIN]_20090324-073403.B0E.bin
Write ...
done
file saved: D:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_9243B568_Y600_TL_PCB01_GPRS_MT6227_S01.Y 600_TL_1_5.BIN_549433C5_20090324-073510.B0X.bin
Area: Firmware
Write: Firmware
Write: Firmware
Write Done
Finalization ...
Finalization Done
file saved: D:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_9243B568_Y600_TL_PCB01_GPRS_MT6227_S01.Y 600_TL_1_5.BIN_549433C5_20090324-074129.B0X.bin
Finished, time used: 636 sec
Motorola W375 restart with sim, & without sim ok nakshatra Infinity-Box 8 12-11-2009 08:03
E250D Hang or Restart with sim... w/o sim OK coldGin HWK 6 06-30-2009 08:46
LG KG 110 alway's RESTART with sim OR W/sim amol_sm Infinity-Box 1 08-21-2008 19:28
How to reapair restart with sim card, N95 with 2 sim? .:RAGE:. Infinity-Box 13 11-30-2007 14:56
GD87 works fine without SIM, restarts with SIM seth_ro Panasonic 9 11-23-2005 17:42
Page generated in 0.18051 seconds with 9 queries
