12-01-2008, 09:24 | #1 (permalink) |
Major Poster Join Date: Dec 2005
Member: 206840 Status: Offline Thanks Meter: 37 | 2 units SE T303 unlock done COM1 [Serial0] selected Device: Sony-Ericsson-T303 "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection... Check connection done Set baud... 115200 Set baud done Check hardware... flash: 89890400040089:89890400000000 flash: Intel ST [def 0080x040000] 32Mb Check hardware done Read data... reading Sony-Ericsson-T303_eeprom_calibration-1... warning: wrong cs at 0x07F00000, retry... read error recovered file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-T303_eeprom_calibration-1_20081201-154348.80E.bin Read data done Check data... Check data done Writing... ........................... flash: 89890400040089:89890400000000 Write: simlock Writing done Finished, time used: 202 sec Remove/Install battery now ! COM1 [Serial0] selected Device: Sony-Ericsson-T303 "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection... Check connection done Set baud... 115200 Set baud done Check hardware... flash: 89890400040089:89890400000000 flash: Intel ST [def 0080x040000] 32Mb Check hardware done Read data... reading Sony-Ericsson-T303_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-T303_eeprom_calibration-1_20081201-154854.80E.bin Read data done Check data... Check data done Writing... ........................... flash: 89890400040089:89890400000000 Write: simlock Writing done Finished, time used: 200 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to wiltelcom For This Useful Post: |
12-01-2008, 14:26 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @wiltelcom Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. |
12-01-2008, 16:36 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @darksin I don't think that it may be something more easy to use than Infinity-Box. As many people reported during more that 3 years the Infinity-Box is very very easy to use. p.s. Here is Infinity-Box support section. We have no reason to talk here about something else. |
se t303 unlock done with cruiser suite... | adreesas | Cruiser Suite | 1 | 01-09-2010 23:00 |
SE T303 Unlocked DONE with ****34 | hamdindiaye | SETool2 | 7 | 09-09-2009 07:28 |
