07-07-2008, 10:23 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Heart of love
Member: 252713 Status: Offline Sonork: 1581550 Thanks Meter: 159 | 3 pieces of kp130 unlocked succecfully thanks to infinity team Checking data, wait... advanced flash detection active Action: unlock unlock method: standard Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud... 115200 Set baud Done Check flash... current eeprom imei: 352126022777830 file saved: C:\Program Files\InfinityBox\LGA\eeprom_352126022777830_LG KP130_20080707-005550.B1E.bin ........ version: - Check flash Done Check space... current eeprom imei: 352126022777830 ................................ finalization done Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... write: lock area-1 Write Done Finished, time used: 45 sec |
07-07-2008, 10:24 | #2 (permalink) |
Member: 252713 Status: Offline Sonork: 1581550 Thanks Meter: 159 | Device: LG KP130 Checking data, wait... advanced flash detection active Action: unlock unlock method: standard Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud... 115200 Set baud Done Check flash... current eeprom imei: 352126022775321 file saved: C:\Program Files\InfinityBox\LGA\eeprom_352126022775321_LG KP130_20080707-010200.B1E.bin ........ version: - Check flash Done Check space... current eeprom imei: 352126022775321 ................................ finalization done Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... write: lock area-1 Write Done Finished, time used: 44 sec Remove/Install battery now ! |
07-07-2008, 10:25 | #3 (permalink) |
Member: 252713 Status: Offline Sonork: 1581550 Thanks Meter: 159 | Device: LG KP130 Checking data, wait... advanced flash detection active Action: unlock unlock method: standard Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud... 115200 Set baud Done Check flash... current eeprom imei: 352126023662627 file saved: C:\Program Files\InfinityBox\LGA\eeprom_352126023662627_LG KP130_20080707-010022.B1E.bin ........ version: - Check flash Done Check space... current eeprom imei: 352126023662627 ................................ finalization done Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... write: lock area-1 Write Done Finished, time used: 44 sec |
07-07-2008, 21:14 | #5 (permalink) |
No Life Poster Join Date: Mar 2008 Location: infinity-box
Member: 720034 Status: Offline Thanks Meter: 213 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
07-17-2008, 08:10 | #9 (permalink) |
Insane Poster Join Date: Aug 2005 Location: BANGLADESH Age: 50
Member: 170700 Status: Offline Thanks Meter: 8 | Current device: LG KP130 Testing COM3 at 921600... COM3 [VCP0] selected Device: LG KP130 Checking data, wait... advanced flash detection active Action: unlock unlock method: standard Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! error: unexpected answer during boot procedure Boot Fail Finished, time used: 39 sec Remove/Install battery now ! Testing COM3 at 460800... COM3 [VCP0] selected Device: LG KP130 Checking data, wait... advanced flash detection active Action: unlock unlock method: standard Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud... 460800 Set baud Done Check flash... current eeprom imei: 352126024090380 file saved: C:\Program Files\InfinityBox\LGA\eeprom_352126024090380_LG KP130_20080717-125505.B1E.bin ........ version: - Check flash Done Check space... current eeprom imei: 352126024090380 ................................ finalization done Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... write: lock area-1 Write Done Finished, time used: 63 sec Remove/Install battery now ! |
The Following User Says Thank You to mohin_ic For This Useful Post: |
07-18-2008, 11:22 | #11 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @mohin_ic Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
Let's Give Thanks To Infinity Team For Chinese Miracle.. | 3lsheikh | Infinity-Box | 39 | 11-05-2008 20:36 |
Thanks to infinity team | jins jisha | Infinity-Box | 0 | 09-27-2008 06:38 |
pin finder..special thank to infinity team.... | traxgsm | Infinity-Box | 11 | 03-04-2008 09:34 |
thank to infinity-team | SYSTEM_GSM | Infinity-Box | 1 | 11-17-2007 17:18 |
Thanks to Infinity Team | freewaycomms | Infinity-Box | 3 | 01-27-2006 23:21 |
