10-25-2007, 22:39 | #1 (permalink) |
Freak Poster Join Date: Aug 2005 Location: here :) Age: 41
Member: 176010 Status: Offline Thanks Meter: 12 | 4 @ll,, strange problem.. need help infinity team! phone with: cm_Nokia_N95_PDA_E553_XZY1ARTHUTR_E553_GPRS_MT6226 _S01.01 all works ok, camera not working at all. also video recorded caused the phone to hang-up message: camera module not ready appears when press on camera icon. note, trying safe format, complete format and flash a phone with flash file from supported area (same version as on it) plz plz plz anyhelp and tips thanks to all |
10-26-2007, 18:11 | #5 (permalink) |
Member: 176010 Status: Offline Thanks Meter: 12 | thanks 4 all support... but now i open the set and replace the module back one to front and front cam to back.. but the problem still so i think it is not a cam module right ??? for other sw which one do u recommended as i mentioned its software in it ? may u help thanks for all |
10-26-2007, 22:32 | #7 (permalink) |
Member: 176010 Status: Offline Thanks Meter: 12 | thanks sir, for support but really is it true a software problem ??? as i mentioned trying replace the cam module with same problem ? so , is it true a software problem ?? thanks a lot for support us! regrds |
10-27-2007, 17:12 | #9 (permalink) |
Member: 176010 Status: Offline Thanks Meter: 12 | thanks for support... about hardware.. i already changed many cam module,, with the same result. about software.. trying much more flashes with the same result ? so, what's ur advice, with best regards ! |
11-18-2007, 16:25 | #14 (permalink) | |
you can try to use this method: http:///vbb/showthread.php?t=447277 | |
