05-09-2009, 04:10 | #1 (permalink) |
Freak Poster Join Date: Sep 2007 Location: GSMPHILIPPINES
Member: 580978 Status: Offline Thanks Meter: 35 | 5310 8 pins straight new flashfiles detected COM67 [VCP0] selected module v2.81 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:4E03:0006 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18A59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18A59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: EC257E25082501:18A59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: EC257E25082501:18A59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation ==================== New firmware detected (v.2.81, database date: 13.04.2009): TK10_PCB01_GPRS_MT6225_S00.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished identification#1 protocol ver: 04 ver. sw 1: TK10_PCB01_GPRS_MT6225_S00.BIN ver. sw 2: TK10_V15_1205, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: EC257E25082501:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: TK10_PCB01_GPRS_MT6225_S00__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\TK10_PCB01_GPRS_M T6225_S00__ffs_20090509-102006.B0E.bin flash: EC257E25082501:18A59F00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: EC257E25082501:18A59F00000000 Finalization Done Finished, time used: 345 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! COM67 [VCP0] selected module v2.81 Action: imei imei write method: mode-2 imei write channel: imei #1 for dual sim/mono CPU new imei: 350448011234710 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:4E03:0006 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: TK10_V15_1205 Version: TK10_HW_V01 detecting structure #2... 0 done 44 byte(s) read imei: 35044801123456 connection Ok detecting structure #2... 0 done 44 byte(s) read verification... verification done: 35044801123471 Finished, time used: 10 sec Remove/Install battery now ! http://w1.uploadmb.com/dw.php?id=1241758932 read fullflash http://www.uploadmb.com/dw.php?id=1241841259 |
The Following User Says Thank You to marcdashale3126 For This Useful Post: |
Cables to Go - Serial extender - 8 pin mini-DIN (M) - 8 pin mini-DIN (F) - 10 ft - mo | IPMART | ipmart WebShop | 0 | 06-30-2009 14:40 |
5310 new firmware detected send to infinity support | marcdashale3126 | Infinity-Box | 5 | 02-22-2009 19:30 |
All in one 10 pins to 8 pin converter 8 pins to 10 pins FREE | TDKI | Nokia Base Band 5 ( BB-5 ) | 15 | 01-31-2009 11:59 |
5310 new fw detected done, & new pinouts here.... | JHUN PANABO | Infinity-Box | 1 | 12-29-2008 01:39 |
Cable converter -Prodigy 10 pin to UFS 8 pin... | omega_plus | UFS2 + UFS3-Tornadoflasher | 2 | 03-28-2006 09:44 |
