03-30-2008, 06:05 | #1 (permalink) |
No Life Poster Join Date: Feb 2005 Location: El M'Hayssar Age: 48
Member: 116657 Status: Offline Thanks Meter: 56 | 5310 nmm3 can't write imei chinease 5310 nmm-3 cant' format and can't write imei it's not dead phone see the two logs COM6 [VCP0] selected Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:7C03:0005 Connecting, wait... Release Power button now ! Phone detected, wait... warning: can't read software version, probably unknown firmware detecting structure #2... 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18warning: wrong packet cs 19 20 21 22 23 24 25error: detection failed (26 tries), read flash and send to support connection Ok building list... done no items found error: operation failed ! Finished, time used: 21 sec COM6 [VCP0] selected Action: imei imei write method: mode-2 new imei: 359400801029017 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:7C03:0005 Connecting, wait... Release Power button now ! Phone detected, wait... warning: can't read software version, probably unknown firmware detecting structure #2... 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18warning: wrong packet cs 19 20 21 22 23 24 25error: detection failed (26 tries), read flash and send to support connection lost error: operation failed ! Finished, time used: 14 sec it seems to be new version not supported "SHINEC25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_1 6_L5_MP4_MY_V1_2" backup full flash readed and upload in progress to send to infinitysupport COM6 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read NOR flash Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:7C03:0005 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: SHINEC25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_16 _L5_MP4_MY_V1_2.BIN ver. sw2: MAUI.06B.W07.16_L5_mp4_MY_V1.2, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 01227E22202200:18E59F00000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [flash[SHINEC25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_16 _L5_MP4_MY_V1_2.BIN]]... file saved: D:\Program Files\InfinityBox\ChineseMiracle\5310\backup_flash[SHINEC25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_16 _L5_MP4_MY_V1_2.BIN]_20080329-174600.B0M.bin Finished, time used: 700 sec Remove/Install battery now ! strange thing when i fill the 14 digit number in infinity soft the 15 number don't fit with the one written in the back side of the phone under the battery ??????? wait for help !!!!!!!!! |
03-30-2008, 15:00 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | it is calculated by correct algo, some chinese phones have wrong last digit this also can cause faulty work in some networks Infinity soft use correct way to calculate this digit, so dont worry if it does not match original |
ks360 can't write imei | gorgans | VygisToolbox | 3 | 08-12-2011 17:07 |
Failed to write imei..????? | sky_finder | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-30-2010 15:45 |
TVN995 Can't write IMEI (FW Inside) | 3stanGsm | Infinity-Box | 4 | 03-26-2010 16:30 |
c520 can't write imei | ruvanw1979 | UST Pro II | 5 | 11-10-2009 18:34 |
can't write imei (INFINITY) | MARK26 | Infinity-Box | 3 | 09-14-2008 18:47 |
