Old 02-16-2009, 13:18   #1 (permalink)
Member: 366606
6300 chinesmiracle lcd white after flash
my chines nokia 6300 rm 17 became whith white lcd after flash all thiks are good but problem lcd please help me infinity team
Old 02-16-2009, 17:14   #2 (permalink)
asad_nomy7's Avatar
Member: 570093
Thanks Meter: 1,067
try other same firmwares from support for flashing.
The Following User Says Thank You to asad_nomy7 For This Useful Post:
Old 02-16-2009, 18:29   #3 (permalink)
Member: 366606
thak you
but i tray severel tims withe other flash and its work i think that eeprom is damaged the phone work perfect but lcd always white any sugestion will be apreciated excuse me for my english
Old 02-16-2009, 19:10   #4 (permalink)
sharif_tell's Avatar
Member: 789364
Sonork: 100.1585484
Thanks Meter: 191
firmware mismatch brother .flash with correct firmware.
Old 02-16-2009, 19:23   #5 (permalink)
nishaon's Avatar
Member: 225229
Thanks Meter: 90
If everything is ok, then why not you change the LCD and check?
Old 02-16-2009, 21:13   #6 (permalink)
taieeb's Avatar
Member: 781262
Thanks Meter: 90
if you have the anther same set then copy ful flash file from this and flash this file to the fualt set and then see
Old 02-17-2009, 12:27   #7 (permalink)
Member: 366606
thank's for reply
the lcd wher good befor flashing and i flashed the phone with same flash in suport but nothing change the phone had chines and eglish language befor format with infinoty after that i found only chines
Old 02-17-2009, 13:05   #8 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
add here fw details.. did u check the support for flash..?
Old 02-18-2009, 19:18   #9 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Try to set another language by codes: http://www.infinity-box.com/wiki/ind...Keyboard_codes
E250d lcd white after changing charger block lucky_gsm Samsung Hardware Repair 2 02-21-2010 20:03
lcd white after change sockt charge sia_hassan Samsung Hardware Repair 4 04-19-2009 20:51
6300 no lcd light after network problem indoponzel Nokia Hardware & Hardware Repair 2 03-20-2009 16:27
6820 LCD goes white after flashing sunny_cool Nokia Digital Core Technology 4 ( DCT-4 ) 7 06-13-2007 10:22
LCD goes white after flashing with nokia6100 tangthanat Nokia Digital Core Technology 4 ( DCT-4 ) 3 04-21-2007 10:14
Page generated in 0.16509 seconds with 10 queries
