02-22-2017, 08:26 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: some where in india
Member: 350232 Status: Offline Thanks Meter: 207 | 6582 cpu flashing prob Phone found! [ 3 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 15010051375853414201FD23EE7EB105 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BASX7 [eMMC] : FLASH_CID : 15010051375853414201FD23EE7EB105 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x7998EDB34D07FCB8F5A1EA54A6CC85C6 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6582 , Project : lcsh82_wet_hz_kk , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 4168 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000001400000-0x0000000000100000 Erase : 0x0000000003100000-0x00000000EB200000 Flash Pre-Erase Done, time used : 00:00:02 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_lcsh82_wet_hz_kk.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0012 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:05:52 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Error! Something went wrong! ErrCode : 0xC599 sir i face this prob in almost every second 6582 set model micromax aq5000 prob virus some few sets as miromax a104 and a106 have same prob and these set secuss fully flash by factory tool .and even no need to full earse . i think there is some kind bug in mtk ... |
02-23-2017, 12:52 | #2 (permalink) |
Member: 350232 Status: Offline Thanks Meter: 207 | next victim htc 526g read info and read firmware ok 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 150100513732534D420083BB9AC29271 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x40000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMS27 [eMMC] : FLASH_CID : 150100513732534D420083BB9AC29271 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x7998EDB3226BBF0D07733DD6F3FB70A7 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : htc ProdName : v02_htc_europe ProdModel : HTC Desire 526G dual sim Device : htc_v02_dug AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : 1.02.401.8 SECURITY : IMEI_SW [1] : 358233067621701 IMEI_SW [2] : 358233067634324 BTMAC Addr : 90E7C4B4B8A2 WiFi MAC : 90E7C4A9B556 MODEM : BaseBand : MT6582_S00_MOLY_WR8_W1315_MD_WG_MP_V62_1_wg_n EXTRA : LCD [0] : ili9807_qhd_dsi_vdo LCD [1] : hx8389c_qhd_dsi_vdo_tcl LCD [2] : hx8389b_qhd_dsi_vdo_tm LCD [3] : ili9807_qhd_dsi_vdo_bld LCD [4] : dummy_lcm LCD Res : 960x540 TOUCH [0] : ft6436l TOUCH [1] : msg2142 CAM [0] : s5k4h5yx_mipi_raw CAM [1] : ov8858_mipi_raw CAM [2] : gc2355_mipi_raw CAM [3] : ov2680_mipi_raw MODEM : mt6582kk_hspa_18_2015_7_31 LOCALE : en_US af_ZA in_ID ms_MY ca_ES cs_CZ da_DK de_DE de_AT de_CH de_LI en_GB en_AU en_CA en_IE en_IN en_NZ en_SG en_ZA es_ES es_US tl_PH fr_FR fr_BE fr_CA fr_CH hr_HR zu_ZA it_IT it_CH sw_TZ lv_LV lt_LT hu_HU nl_NL nl_BE nb_NO pl_PL pt_BR pt_PT ro_RO rm_CH sk_SK sl_SI fi_FI sv_SE vi_VN tr_TR el_GR bg_BG ru_RU sr_RS uk_UA iw_IL ar_EG ar_IL fa_IR am_ET hi_IN th_TH my_MM km_KH ko_KR zh_CN zh_TW zh_HK ja_JP ar_SA hb_IL he_IL et_EE hy_AM kk_KZ en_MY Done! Elapsed: 00:00:16 Reconnect Power/Cable! Finish at : [2/22/2017 / 4:51:12 PM] Start at : [2/22/2017 / 4:52:00 PM] Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 150100513732534D420083BB9AC29271 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x40000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMS27 [eMMC] : FLASH_CID : 150100513732534D420083BB9AC29271 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x7998EDB3226BBF0D07733DD6F3FB70A7 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... USBDL : Init HSUSB Ok! Brand : htc ProdName : v02_htc_europe ProdModel : HTC Desire 526G dual sim Device : htc_v02_dug AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : 1.02.401.8 [Read Ok] : preloader_huaqin82_cwet_b2_kk.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : EBR2 [Read Ok] : cota.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6582 / V1.1.1 / huaqin82_cwet_b2_kk / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 1315 MiB Scatter saved to : D:\MT6582__htc__HTC_Desire_526G_dual_sim__htc_v02_ dug__4.4.2__1.02.401.8\ but flashing failed ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 150100513732534D420083BB9AC29271 Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x40000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMS27 [eMMC] : FLASH_CID : 150100513732534D420083BB9AC29271 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x7998EDB3226BBF0D07733DD6F3FB70A7 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6582 , Project : huaqin82_cwet_b2_kk , Storage : EMMC Setting : Flash Pre-Erase : Off ( Write Flash Only ) Setting : AFF verify : Enabled Setting : HW verify : Enabled Switching to HSUSB HSUSB Init Ok BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Skip checking by User request! BL : BatteryLevel : 3647 mV BL : BatteryLevel Ok SecCfg Passed , 179A BMT remark not need. Will skip Preloader Download skipped by user request! PartCount : 0014 Update PMT by user request Repartition Done! Use FLS Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : EBR2 Image Flash Ok Flash now : COTA Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:05:18 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Error! Something went wrong! ErrCode : 0xAE97 Operation Failed Elapsed: 00:05:41 Reconnect Power/Cable! |
