06-01-2009, 07:29 | #1 (permalink) |
No Life Poster Join Date: Sep 2004
Member: 82423 Status: Offline Thanks Meter: 1,203 | A200 NKTEL Off On Press Sound Recorder Option I Have A200 NKTEL when I Press sound recorder option set go to black LCD then on In Set version is “N66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_5CDGB_ S5LCD_V1_6_6.BIN” I am using latest version 2.82. I try to format I get this message: New firmware detected (v.2.82, database date: unknown): N66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_5CDGB_ S5LCD_V1_6_6.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send "system_log_..." file to support: [email protected] - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) I can’t read this file because set is not work properly. I read flash file another phone and write flash on this phone with this version “[N66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_6CDGB_ S5LCD_V1_4_8.BIN]_20090409-184432.B0M”. Now sound recorder work perfect, but hand shack not working any solution or any one have working phone version “N66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_5CDGB_ S5LCD_V1_6_6.BIN” so please share it. Its urgent. BR. |
06-01-2009, 16:08 | #3 (permalink) |
Member: 82423 Status: Offline Thanks Meter: 1,203 | I flash A200 NKTEL this version "“N66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_5CDG B_ S5LCD_V1_6_5.BIN”" but phone not get power one I flash after this version "“N66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_5CDG B_ S5LCD_V1_6_6.BIN”" phone live but still same on off recorder when I flash this version “[N66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_6CDGB_ S5LCD_V1_4_8.BIN]_20090409-184432.B0M”. Phone hand shack not work (When I move phone right left phone screen chage not work) sound recorder work fine. any solution. |
06-02-2009, 12:19 | #5 (permalink) |
Member: 82423 Status: Offline Thanks Meter: 1,203 | Mate! Here is format FFS logs I think its new phone software version therefore I get format FFS error Please see below logs ==== log opened: [10/6/2002 4:22:49 AM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] Chinese Miracle v2.82 S/N: XXXXXXXX Wait... Device: Autodetect 6205-6227 NOR Done ==== log: [10/6/2002 4:23:01 AM] ==== COM13 [VCP0] selected module v2.82 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:8403:000B status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... warning: can't read software version, probably unknown firmware detecting structure #2... 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18warning: wrong packet cs 19 20 21 22 23 24 25 26 27 28 29error: detection failed (30 tries), read flash and send to support connection lost error: operation failed ! Finished, time used: 10 sec Remove/Install battery now ! ==== log: [10/6/2002 4:23:22 AM] ==== COM13 [VCP0] selected module v2.82 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:8403:000B status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... warning: can't read software version, probably unknown firmware detecting structure #2... 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18warning: wrong packet cs 19 20 21 22 23 24 25 26 27 28 29error: detection failed (30 tries), read flash and send to support connection lost error: operation failed ! Finished, time used: 10 sec Remove/Install battery now ! ==== log: [10/6/2002 4:25:28 AM] ==== COM13 [VCP0] selected module v2.82 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:8403:000B status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... warning: can't read software version, probably unknown firmware detecting structure #2... 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18warning: wrong packet cs 19 20 21 22warning: wrong packet cs 23 24 25 26 27 28 29error: detection failed (30 tries), read flash and send to support connection lost error: operation failed ! Finished, time used: 15 sec Remove/Install battery now ! ==== log: [10/6/2002 4:25:55 AM] ==== COM13 [VCP0] selected module v2.82 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:8403:000B status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... warning: can't read software version, probably unknown firmware detecting structure #2... 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18warning: wrong packet cs 19 20 21 22warning: wrong packet cs 23 24 25 26 27 28 29error: detection failed (30 tries), read flash and send to support connection lost error: operation failed ! Finished, time used: 53 sec Remove/Install battery now ! ==== log opened: [10/6/2002 4:29:25 AM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] Chinese Miracle v2.82 S/N: 723B:0112 Wait... Device: Autodetect 6205-6227 NOR Done ==== log: [10/6/2002 4:30:16 AM] ==== COM13 [VCP0] selected module v2.82 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! error: can't activate test mode error: operation failed ! Finished, time used: 1 sec Remove/Install battery now ! ==== log: [10/6/2002 4:30:29 AM] ==== COM13 [VCP0] selected module v2.82 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:8403:000B status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... warning: can't read software version, probably unknown firmware detecting structure #2... 0 1 2 3 4 5 6 7 8 9 10 11 12 13warning: wrong packet cs 14 15 16 17 18 19 20 21 22 23warning: wrong packet cs 24 25 26 27 28 29error: detection failed (30 tries), read flash and send to support connection lost error: operation failed ! Finished, time used: 11 sec Remove/Install battery now ! ==== log: [10/6/2002 4:30:53 AM] ==== COM13 [VCP0] selected module v2.82 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:8403:000B status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... warning: can't read software version, probably unknown firmware detecting structure #2... 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18warning: wrong packet cs 19 20 21 22 23 24 25 26 27warning: wrong packet cs 28 29error: detection failed (30 tries), read flash and send to support connection lost error: operation failed ! Finished, time used: 14 sec Remove/Install battery now ! ==== log: [10/6/2002 4:31:17 AM] ==== COM13 [VCP0] selected module v2.82 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:8403:000B status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... warning: can't read software version, probably unknown firmware detecting structure #2... 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18warning: wrong packet cs 19 20 21 22 23 24 25 26 27warning: wrong packet cs 28 29error: detection failed (30 tries), read flash and send to support connection lost error: operation failed ! Finished, time used: 15 sec Remove/Install battery now ! |
06-05-2009, 16:05 | #8 (permalink) |
Member: 82423 Status: Offline Thanks Meter: 1,203 | Mate! Here is FFS in Compltete mode logs. ==== log opened: [6/5/2009 9:02:23 PM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] Chinese Miracle v2.82 S/N: xxxxxxxxxx Wait... Device: Autodetect 6205-6227 NOR Done ==== log: [6/5/2009 9:02:39 PM] ==== COM7 [VCP0] selected module v2.82 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:0A03:000C status: FF Connecting at 19200, wait... error: can not finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 61 sec Remove/Install battery now ! ==== log: [6/5/2009 9:03:50 PM] ==== COM7 [VCP0] selected module v2.82 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:0A03:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... warning: can't read software version, probably unknown firmware detecting structure #2... 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18warning: wrong packet cs 19 20 21 22 23 24 25 26 27warning: wrong packet cs 28 29error: detection failed (30 tries), read flash and send to support connection lost error: operation failed ! Finished, time used: 10 sec Remove/Install battery now ! ==== log: [6/5/2009 9:04:21 PM] ==== COM7 [VCP0] selected module v2.82 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:0A03:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... warning: can't read software version, probably unknown firmware detecting structure #2... 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22warning: wrong packet cs 23 24 25 26 27 28 29error: detection failed (30 tries), read flash and send to support connection lost error: operation failed ! Finished, time used: 12 sec Remove/Install battery now ! |
06-12-2009, 08:30 | #13 (permalink) |
Member: 82423 Status: Offline Thanks Meter: 1,203 | Mate! Thanks for you supporting Here is "ffs: complete" COM7 [VCP1] selected module v2.82 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:6703:000B status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #02 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #03 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.572CB3B7.[N66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_5CDGB_ S5LCD_V1_6_6.BIN_7444D22F].rpl ==================== New firmware detected (v.2.82, database date: unknown): N66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_5CDGB_ S5LCD_V1_6_6.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send "system_log_..." file to support: [email protected] - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished device-id: 572CB3B7 identification#1 protocol ver: 04 ver. sw 1: N66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_5CDGB_ S5LCD_V1_6_6.BIN ver. sw 2: N66_ABROAD_5CDGB_S5LCD_V1.6.6, D02DBB8B ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 98000300000001:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: N66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_5CDGB_ S5LCD_V1_6_6__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\N66_ABROAD_PCB01_ GPRS_MT6225_S00.N66_ABROAD_5CDGB_S5LCD_V1_6_6__ffs _20090612-132744.B0E.bin flash: 98000300000001:18E59F00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 98000300000001:18E59F00000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\N 66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_5CDGB_S 5LCD_V1_6_6__system_log_572CB3B7_7444D22F_20090612-132946.B0X.bin Finished, time used: 234 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! But Problem Still Same. I need this fimeware "N66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_5CDGB _S5LCD_V1_6_6.BIN" If you share it.Becuse I read other phone version "N66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_5CDGB _S5LCD_V1_6_5__fullflash_20090601-174013.B0M" write to phone phone is dead I flash again phone with this version 1.6.6 phone live but same problem. I hope you undersdand my problem. Last edited by irfanamin2; 06-12-2009 at 08:39. |
06-13-2009, 08:48 | #15 (permalink) |
Member: 82423 Status: Offline Thanks Meter: 1,203 | Mate! Thanks for you reply I m searching same firmware phone when I found I write full backup in my phone & send you to. If you found so please tell me asap. Again thanks for you support. BR. |
Voda 125 switched off on pressing call button | chhoton | Various | 1 | 02-28-2010 09:28 |
Iphone turn off everytime press on/off button for put sleep mode | jzelaya | iPhone 2 / iPhone 3G / iPhone 3GS | 0 | 08-25-2009 22:36 |
6275 look like hang on camera option but take photo on pressing camera click button | kripalu | Nokia CDMA | 2 | 04-15-2009 17:35 |
D900 powers on and off when press power... | Burnt Cobba | NSPRO | 7 | 04-09-2007 20:43 |
8210 Turns ON when battery inserted & OFF on key press | Tsunami | Nokia Hardware & Hardware Repair | 4 | 10-28-2003 23:37 |
