Old 10-01-2008, 12:36   #1 (permalink)
Member: 333872
Thanks Meter: 32
Haier HG-A8
hi me friends need pinout to this phone, is mini USB like motorola,,,
Salu2
Old 10-02-2008, 10:17   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Where is Gnd and +Charge pins at phone connector ?
Old 10-02-2008, 12:04   #3 (permalink)
Member: 333872
Thanks Meter: 32
LOG reead in chinece miracle !!New firmware detected!!!
this is mi log an sen flash reed to [email protected] please check...
[email protected]
COM1 [Serial0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: read/check detailed information
Boot...
19200 fixed
Connecting, wait...
Initializing[6226:8A02:8A01]...
CPU: MT6226
high speed boot disabled
chip: 0031:1F41:514C
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: 2088C4FFFFFFFF:2088C400000000
flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
115200
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area#1 is Ok
security area#1 backup saved: C:\Archivos de programa\InfinityBox\ChineseMiracle\backup_securit y\id.DDF22B4A.[E660_VEN_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_28.BIN _6E1E62E1].rpl
New firmware detected:
- make "Read full flash" operation
- send "system_log_..." file to support: [email protected]
- send flash backup file(s) to support: [email protected]
- include in your e-mail full text from phone back label (phone name etc.)
identification#1 detection finished
device-id: DDF22B4A
identification#1 protocol ver: 04
ver. sw1: E660_VEN_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_28.BIN
ver. sw2: MAUI.05C.W06.28, 1E9DE191
ffs offset/size: 00D00000/00300000
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00D00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00D00000
detecting eeprom/ffs size...
eeprom/ffs size: 00300000
ffs chip: 00
eeprom/ffs area: 00000000:00D00000-00FFFFFF
detecting ffs structure pass 1...
detect standard fat location pass #1...
detect extended fat location pass #1...
detect standard fat offset pass #1...
detect standard fat data...
fat layout detection complete
ffs element #1 detected ok
detecting ffs structure pass 2...
detect standard fat location pass #2...
detect extended fat location pass #2...
detect standard fat offset pass #2...
ffs element #2 detected ok
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
file saved: C:\Archivos de programa\InfinityBox\ChineseMiracle\backup_securit y\system_log_DDF22B4A_E660_VEN_PCB01_GPRS_MT6226_S 01.MAUI_05C_W06_28.BIN_6E1E62E1_20081001-084900.B0X.bin
Finished, time used: 98 sec
Remove/Install battery now !
please support!!!! to unlock
Old 10-02-2008, 12:30   #4 (permalink)
Member: 130995
Hello,
Thanks, we will check it ASAP !
What pinout you have used ?
Old 10-03-2008, 05:39   #5 (permalink)
Member: 333872
Thanks Meter: 32
the pinout is
/12345\
_______
1: Gnd
3: Box Rx/Phone Tx (RJ45 pin-3)
4: Box Tx/Phone Rx (RJ45 pin-2)
or change
3 to 2
4 to 3
Salu2
Old 10-03-2008, 12:10   #6 (permalink)
Member: 333872
Thanks Meter: 32
infinitysupport need solution
infinity is de best box in the world!!!!
Old 10-03-2008, 16:29   #7 (permalink)
Member: 130995
Hello,
Thank you !
We have received flash backup file, need some time to check it carefully.
Please, try to keep phone with you one more day and we will try to give you software for test.
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 10-04-2008, 04:43   #8 (permalink)
Member: 333872
Thanks Meter: 32
OK infinity is great ox an waiting...
Salu2
Old 10-04-2008, 08:24   #9 (permalink)
Member: 333872
Thanks Meter: 32
remember need Unlock!!
Thank you !
Old 10-04-2008, 16:51   #10 (permalink)
Member: 130995
Hello,
Please, use this new software:
http://rapidshare.com/files/15087603...v2.34.rar.html
Try to unlock phone by "standard" method.
In case of any problems try to unlock phone with other methods.
Waiting for your results.
The Following 2 Users Say Thank You to InfinitySupport For This Useful Post:
Old 10-05-2008, 05:45   #11 (permalink)
Member: 333872
Thanks Meter: 32
Thumbs up Thank you !
Thank you !
The Haier wass unloked on the flay in standar methot.....wala phone is unloked
Thank you !
best support of the all box
Grasias amigos, el telefono esta libre, a la primera!!!!!!!!!!!!!!!!!!!!!!!
Salu2
Old 10-05-2008, 07:39   #12 (permalink)
Member: 694494
best support of the all box very good
Old 10-05-2008, 08:24   #13 (permalink)
Member: 333872
Thanks Meter: 32
This is Mi log
Device: Haier HG-A8
Action: "sp-unlock"
unlock method: standard
Boot...
19200 fixed
Connecting, wait...
CPU: MT6226
boot step size: 0400
Boot Done
Initialize...
Initialize Done
Set baud...
115200
Set baud Done
security area (startup code #1) is Ok
security area (startup code #1) backup saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\id.DD F22B4A.[E660_VEN_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_28.BIN _6E1E62E1].rpl
device-id: DDF22B4A
Detecting security area (startup code #2)...
security area (startup code #2) is absent
reading: eeprom[E660_VEN_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_28.BIN]...
file saved: C:\Archivos de programa\InfinityBox\MModule\eeprom[E660_VEN_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_28.BIN]_20081005-003326.B0E.bin
Backup required data Done
Patch required data...
detection procedure, wait...
detection procedure completed
Patch required data Done
Special operation...
detecting additional parameters...
Write: area 0/1
additional parameters detected Ok
Special operation Done
Write...
Write: eeprom
Write Done
Finalization...
Finalization Done
file saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\syste m_log_DDF22B4A_E660_VEN_PCB01_GPRS_MT6226_S01.MAUI _05C_W06_28.BIN_6E1E62E1_20081005-003434.B0X.bin
Finished, time used: 375 sec
The Following User Says Thank You to edlho For This Useful Post:
Old 10-05-2008, 11:07   #14 (permalink)
Member: 130995
Thank you very much for test report !
Each test report with attached logs is very important for us so we can see how is Infinity-Box
software works and what is possible problems and successfully done work.
Old 10-05-2008, 23:45   #15 (permalink)
Member: 333872
Thanks Meter: 32
at your service infinitysupport..
unlock sucefully Haier-HG-A8 jmr Infinity-Box 2 01-09-2009 19:29
06 Oct 2008: Haier-HG-A8 model supported InfinitySupport Infinity-Box 8 10-08-2008 20:59
Infinity-Box: Haier-HG-A8 model supported InfinitySupport Service Products News & Updates 0 10-06-2008 19:38
Haier HG-A8 yurais Infinity-Box 2 08-05-2008 13:30
Haier HG-T60 Unclocking m3ntal170 GSM Mobile Links 1 02-02-2008 11:00
Page generated in 0.22118 seconds with 9 queries
