after safe ffs formate- display shows upside down , i don't have backup as i thought safe ffs formate will not harm fone,,
i did safe ffs format bcos mmc does'nt detect on fone .
and again i try with complete ffs format but it can't solve my pb
complete ffs format logs:- Quote:
COM13 selected
module v3.20
Device: Autodetect 6205-6239 NOR
Checking data, wait...
Action: reset settings ("format ffs")
Do you want to make ffs/eeprom backup before format ?
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
high speed boot On
chip: 0011:2F2B:000C
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: EC257E25082501:2BEA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
otp offset: 00000000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [protected] type, 1 record(s)
TCL-ID is absent
startup code area #1 is Ok
startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.5E5B2DD9.[PROWAVE23C_GEMINI_08A_PCB01_GPRS_MT6223_S00.A319_0 2_958A_R1_0_20_2.BIN_E0A03B92].rpl
rom info detection finished
device-id: 5E5B2DD9
rom info ver: 04
sw version: PROWAVE23C_GEMINI_08A_PCB01_GPRS_MT6223_S00.A319_0 2_958A_R1_0_20_2.BIN
project-id: A319_02_958A_R1.0.20.2, 923BA0E0
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
firmware area: 00000000-00DFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: PROWAVE23C_GEMINI_08A_PCB01_GPRS_MT6223_S00.A319_0 2_958A_R1_0_20_2__ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\sharp\PROWAVE23C_ GEMINI_08A_PCB01_GPRS_MT6223_S00.A319_02_958A_R1_0 _20_2__ffs_20100904-170726.B0E.bin
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\P ROWAVE23C_GEMINI_08A_PCB01_GPRS_MT6223_S00.A319_02 _958A_R1_0_20_2__system_log_5E5B2DD9_E0A03B92_2010 0904-170752.B0X.bin
Finished, time used: 2 min 19 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
how to make the phone in his previous condition, pls help me bro..
