09-02-2010, 21:54 | #2 (permalink) | |
How to write flash (upgrade/downgrade firmware, change language): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Flash" page and load required files 8. press "Write" button and follow instruction given by software How to read flash: 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "Read flash" (or "Read full flash") button and follow instruction given by software How to unlock (remove sp-lock, provider lock etc.): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "SP-Unlock" button and follow instruction given by software How to reset/format ffs (reset setting to default values, repair freez/restart etc.): - at first try to make "safe format" (if this option exist) - if "safe" option is not works try to make "complete" format (if this option exist) 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. select format mode "safe" or "complete" (if mode is available) 9. press "Reset" or "Format" button and follow instruction given by software | |
I need flash to Alcatel One Touch Viev db: Be 3, 2 mb,16A | sosin | Alcatel & TCL Old Models | 0 | 02-13-2002 03:47 |
Alcatel BE$ pinouts | GSM Coolhawk | Alcatel & TCL Old Models | 0 | 12-08-2001 15:44 |
NOKIA, ALCATEL EEprom site | Orbital - GSM | GSM Mobile Links | 0 | 04-09-2001 10:31 |
Alcatel One Touch cable needed!!! | tati | Alcatel & TCL Old Models | 0 | 05-17-1999 22:05 |
