07-11-2020, 11:41 | #1 (permalink) |
No Life Poster Join Date: Jul 1999 Location: Netherlands Age: 57
Member: 334 Status: Offline Thanks Meter: 120 | Alcatel 1SE 5030D frp support I have here a Alcatel 1 SE 5030D with frp on. Is support for this phone possible? i have here a phone for test, see log. Card found : XXXXXXX , v0143 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.05 Load IDBase v42913 Ok! Operation : Format FS / Reset Settings [ v2.05 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9863x_BASE : SC9863_eMMC_2GB_RS Sending Init Boot ... Boot sent! Kick FDL ... ERROR : FDL NOT started! Error : Fail to boot FDL! Unsupported device with selected fdl or settings! Change settings! Reconnect Power/Cable! |
07-12-2020, 00:23 | #2 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,785 | Quote:
b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
The Following User Says Thank You to Brka For This Useful Post: |
07-12-2020, 12:15 | #3 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
Unpack in CM2SP2 folder, start SW and select TCL -> TCL_SC9863_A10 Let know rersult, should work. Hello. It is exactly SC9863A device , seems as something wrong on their support side | |
07-13-2020, 10:15 | #4 (permalink) |
Member: 334 Status: Offline Thanks Meter: 120 | Hello all, I found the flashfile for this phone and now working see log. I upload the flashfile to support. Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.05 Load IDBase v42913 Ok! VER : BP_R2.0.1 LEN : 1F3D3EEA ( 499,83 MiB ) CPU : s9863a1h10 VER : 5030D_EEA_ALWE_2SIM_V1.8_20200225_UNLOCK Operation : Identify [ v2.05 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : PAC : 5030D_EEA_ALWE_2SIM_V1.8_20200225_UNLOCK.pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Device info : Patch Level : QP1A.190711.020 Display ID : 5030D_EEA_ALWE_2SIM_V2.7_20200413_UNLOCK Ver. Incmt : 5030D_EEA_ALWE_2SIM_V2.7 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2020-03-05 Build Time : 1586770471 Product Info : 5030D_EEA Product Board : sp9863a_1h10 Board Platform : sp9863a UserData : STATE : PLAIN [EXTFS] Done! Elapsed: 00:02:19 |
07-14-2020, 01:15 | #6 (permalink) | |
Even latest version files are unavailable ... b.r. Alex
02-06-2021, 15:28 | #7 (permalink) | |
Freak Poster Join Date: May 2014 Location: italy
Member: 2188821 Status: Offline Sonork: TECHNOLOGYFORLIFE Thanks Meter: 60 | Quote:
hi i tried the same procedure with the same pac firmware, but nothing doesn't start ... what keys do you press? | |
02-06-2021, 15:29 | #8 (permalink) | |
hi i tried the same procedure with the same pac firmware, but nothing doesn't start ... what keys do you press ? thx | |
02-06-2021, 15:29 | #9 (permalink) | |
04-08-2021, 14:30 | #11 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Download flash file from Infinity support area. Try Firmware File Finder via Telegram @FlashFileSearchBot |
04-11-2021, 11:04 | #13 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | direct Infinity support area download link alcatel 5030d for you https://www.infinity-box.com/support/?r=15&a=0&fid=3365 Please check all pages with files at given link |
12-07-2021, 16:55 | #14 (permalink) |
Crazy Poster Join Date: Apr 2016
Member: 2553878 Status: Offline Sonork: [email protected] Thanks Meter: 16 | Card found : 35B4C871 , v0148 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.09 Load IDBase v8331 Ok! Operation : Format FS / Reset Settings [ v2.09 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9863x_BASE : SC9863A_eMMC_3GB_0S Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:33 |
The Following User Says Thank You to BOUAGSM For This Useful Post: |
12-07-2021, 16:56 | #15 (permalink) |
Member: 2553878 Status: Offline Sonork: [email protected] Thanks Meter: 16 | Frp alcatel 5030d for spd2 infinity Card found : 35B4C871 , v0148 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.09 Load IDBase v8331 Ok! Operation : Format FS / Reset Settings [ v2.09 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9863x_BASE : SC9863A_eMMC_3GB_0S Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:33 |
