01-10-2017, 03:08 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Santiago de Cuba Age: 46
Member: 220595 Status: Offline Thanks Meter: 355 | alcatel 5056O allura looks like supported Code: [Operation : Identify [ v1.08 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8909] ID_BLOCK_S : 0146BE9F ID_BLOCK_I : 009600E1 ID_BLOCK_L : B162517CADD3823BA1FAE30AFC7AC4BC ID_BLOCK_L : 82E2F50F7B8B7F6FD021DBB645945E92 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Brand : TCL ProdName : Alcatel_5056O ProdModel : Alcatel_5056O Device : Pop355 AndroidVer: 5.1.1 Manufact. : true QLMxCPU : MSM8909 Done! Elapsed: 00:00:09] Code: Operation : Reset Settings [ v1.08 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8909] ID_BLOCK_S : 0146BE9F ID_BLOCK_I : 009600E1 ID_BLOCK_L : B162517CADD3823BA1FAE30AFC7AC4BC ID_BLOCK_L : 82E2F50F7B8B7F6FD021DBB645945E92 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP ( Google Reset Protection ) FRP removed! Done! Elapsed: 00:00:22 Reconnect Power/Cable! |
02-03-2017, 20:28 | #2 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | Now.. read firmware Code: Operation : Read Flash [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 0146BE9F ID_BLOCK_I : 009600E1 ID_BLOCK_E : 0146BE9F ID_BLOCK_L : B162517CADD3823BA1FAE30AFC7AC4BC ID_BLOCK_L : 82E2F50F7B8B7F6FD021DBB645945E92 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Brand : TCL ProdName : Alcatel_5056O ProdModel : Alcatel_5056O Device : Pop355 AndroidVer: 5.1.1 Manufact. : true QLMxCPU : MSM8909 DevInfo : MSM8909__true__TCL__ANDR_v5.1.1__Alcatel_5056O__Pop355__Alcatel_5056O Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : NON-HLOS.bin [Read Ok] : nvram.img [Read Ok] : perso.img [Read Ok] : sbl1.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : secro.img [Read Ok] : fs_gc.img [Read Ok] : sec.dat [Read Ok] : emmc_appsboot.mbn [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : system.img [Read Ok] : persist.img [Read Ok] : splash.img [Read Ok] : tctperso.img [Read Ok] : cache.img [Read Ok] : misc.img [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin Android Info saved! Read finished! Configuration : MSM8909 / eMMC Firmware Size : 2022 MiB Done! Elapsed: 00:04:29 Reconnect Power/Cable! Code: Loading firmware ... Created by Infinity-Box (c) Chinese Miracle II (c) 2017 Device Brand : TCL Device Manufact.: true Device Model : Pop355 Device CPU : MSM8909 Device IntName : Alcatel_5056O Device Version : 5.1.1 CU_SWVer : true Device Compile : 16/03/2016 20:02:06 Device ExtInfo : Alcatel_5056O Load Ok! Operation : Flash [ v1.10 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 0146BE9F ID_BLOCK_I : 009600E1 ID_BLOCK_E : 0146BE9F ID_BLOCK_L : B162517CADD3823BA1FAE30AFC7AC4BC ID_BLOCK_L : 82E2F50F7B8B7F6FD021DBB645945E92 Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Files in Chain : 39 Flashing now Flashing : gpt_main0.bin Flashing : NON-HLOS.bin Flashing : sbl1.mbn Flashing : sbl1.mbn Flashing : rpm.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : tz.mbn Flashing : sec.dat Flashing : emmc_appsboot.mbn Flashing : emmc_appsboot.mbn Flashing : boot.img Flashing : recovery.img Flashing : system.img Flashing : persist.img Flashing : splash.img Flashing : cache.img Flashing : misc.img Flashing : userdata.img Flashing : gpt_backup0.bin Boot settings configured! Flashing done! Done! Elapsed: 00:04:28 Reconnect Power/Cable! |
02-03-2017, 20:33 | #3 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | SO, because am trying to find a working firmware to unbrick the 5056O, I tried to read firmware from 5056N and this is the result Code: Operation : Read Flash [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 063E05E1 ID_BLOCK_I : 009600E1 ID_BLOCK_E : 063E05E1 ID_BLOCK_L : 3E09C55E272CA08130DC8C953536B788 ID_BLOCK_L : 4A040DBDB05AB2CC3D48542F2D801E8D Use CM2 Internal Loader Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! Reconnect Power/Cable! Anybody can try and read 5056O firmware from working phone and upload it slsewhere ? |
