12-08-2009, 09:15 | #1 (permalink) |
Insane Poster Join Date: Oct 2009
Member: 1132412 Status: Offline Thanks Meter: 5 | Alcatel ot-203e cannot power on after unlock module v2.98 Device: Alcatel-203X, 203A, 203E Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:6107:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E221A2201:2BEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info protocol ver: 05 ver. sw 1: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN ver. sw 2: MAUI.08A.W08.36.SP1.V28.F1, 00000000 code offset: 00000000 ffs offset/size: 003A0000/00058000 TCL-ID identification version: 37D provider: 203EX-2AVRGB1 customization: CM37CN35 customization: XM37CN35 TCL-ID identification done ffs/eeprom address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, part #2) calculation... identification header detected Can not calculate required data ! Find original simfree model, read full flash and send to support flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, part #2) error: no any expected answer error: flash write error: 003FA000:00002000 error: can't write required area security area (sec info, part #2) calculation failed security area (sec info, part #1) calculation... .error: no any expected answer error: security area (sec info, part #1) calculation aborted due to communication fault at step A error: can't calculate security area (sec info, part #1) Check firmware integrity Fail file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-203X,203A,203E__system_log__00000000_20091207-233422.B0X.bin Finished, time used: 96 sec Remove/Install battery now ! PHONE became lock for vergin sim now it is not power on some one help me please |
12-08-2009, 09:30 | #2 (permalink) |
Member: 1132412 Status: Offline Thanks Meter: 5 | try to write the firmware also failed COM7 [VCP2] selected module v2.98 Device: Alcatel-203X, 203A, 203E Checking data, wait... advanced flash detection enabled Action: write NOR flash "format ffs" active write: Firmware 203X-2AAHNL1-377_XM37CF31_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MA UI_08A_W08_36_SP1_V28_F1_2009-06-26_En_Nl_Fr_De_Tr.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:6107:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E221A2201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: .old firmware type w/o rom info data .damaged firmware .damaged hardware if phone works fine just ignore this warning ffs/eeprom address can not be detected, value from database assigned: 003A0000/00058000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: .old firmware type w/o rom info data .damaged firmware .damaged hardware if phone works fine just ignore this warning ffs/eeprom address can not be detected, value from database assigned: 003A0000/00058000 sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... startup code area #1 fixed Area: Firmware flash: 01227E221A2201:FFFFFF00000000 Write: Firmware error: no any expected answer error: flash write error: 00000000:00002000 sec info (fast) detection... searching sec info#1... error: unexpected termination/freez: 00000000 search sec info#1 finished Write Done ====> Finalization ... ffs formatting... error: no any expected answer error: no any expected answer : wrong answer after chip id request error: no any expected answer error: no any expected answer error: no any expected answer : wrong answer after chip cfi request error: no any expected answer error: no any expected answer : wrong answer after chip id request error: erase: can't detect chip at required chip base Finalization Fail Finished, time used: 75 sec Remove/Install battery now ! |
Alcatel OT-660 E100 Flip dead after unlock, Supporter Please Help | brokendreem | Infinity-Box | 25 | 01-26-2012 14:57 |
Alcatel OT-660 E100 Flip dead after unlock, Supporter Please Help | dauyeuqn | Infinity-Box | 9 | 10-24-2010 00:05 |
D500/E800 cannot power on after flash | egreen1956 | NSPRO | 3 | 02-11-2007 13:46 |
k300i dead also cannot power on after sucessful flashing | saily | Cruiser Suite | 4 | 07-31-2005 09:53 |
A52 not power on after Unlock with feria !!! | Dynamitor | E-Gold Based Phones | 2 | 04-19-2005 15:01 |
