12-22-2008, 12:39 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Ghana Age: 40
Member: 563167 Status: Offline Thanks Meter: 39 | LG KP100 Unlocked okkk.. module v1.57 Device: LG-KP100 Checking data, wait... Action: unlock direct unlock method #2 (Airtel etc.) Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .01 ULC2GL O2 KP100 04 FL 49 V10a 262-07 FEB-12-2008 +2 ^ Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-static_20081222-112809.B1E.bin loading data... data loaded imei: 35588202876423300 reading eeprom-security_35588202876423300... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-security_35588202876423300_20081222-112811.B1E.bin reading eeprom-complete_35588202876423300... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35588202876423300_20081222-112817.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: eeprom-security Writing: eeprom-security probably you need to restore original imei after unlock process Write Done Finished, time used: 30 sec Remove/Install battery now ! thanksssssssss to infinity team........... |
The Following User Says Thank You to cllins For This Useful Post: |
12-22-2008, 12:53 | #2 (permalink) | |
Freak Poster Join Date: Sep 2007 Location: BanglaDesh
Member: 597570 Status: Offline Sonork: 100.1590733 Thanks Meter: 159 | Quote:
12-22-2008, 18:24 | #3 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Quote:
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. | |
LG KP100 Unlock | h4mza | LG | 8 | 07-03-2011 01:51 |
Lg KP100 unlocked sucessfull by n-box | randr | LG | 0 | 09-13-2008 09:59 |
lg kp100 unlock | newerno | Infinity-Box | 10 | 09-12-2008 09:26 |
LG KP100 unlock problem | msashami | Infinity-Box | 1 | 09-02-2008 12:04 |
LG KP100 Unlock OK | Amir-SkillZ | Infinity-Box | 0 | 08-12-2008 08:21 |
